LinkBack (20) Thread Tools Display Modes
  #31 (permalink)
Old 07-12-2007, 01:55 PM
wilecoyote's Avatar
Dealer : Mossy Toyota Scion
Last Online: 06-08-2009 10:16 AM
wilecoyote is on a distinguished road.
wilecoyote's Photo Albums
Default Re: DIY: Oil Change w/ pics.
Excellent writeup! I think I will continue to have oil changes done at my local dealer - they offer 30min or next one is free and only charged me 35bucks total cost - of course this was using dino oil. I asked them and they told me they use only valvoline at thier dealership - which is what I use - so I may well get every other one for free anyway! Every car company has a few asshats running around deciding things - must have been the "asshats decision day" when toyota decided to "engineer" this ludicrous method to change the oil. They have taken one of the easiest and most vital maintenance operations to perform and turned it into a true brainfart of a deal - way to go toyo. I remember changing the oil in my 97 supra was no picnic either - seems like they are really trying to give thier dealerships more biz This is really a minor irritant however when compared to how much I love my new truck!!!
2007 DC Tundra 5.7L TRD 4X2 Salsa Red - LineX - XM radio - grey leather interior - TRD 18's - Westin oval running boards and bull bar - tow package - tow mirrors
  #32 (permalink)
Old 07-12-2007, 04:33 PM
Dealer : Montrose Toyota
Last Online: 09-17-2009 09:56 PM
Gave_up_my_Bowtie is on a distinguished road.
Gave_up_my_Bowtie's Photo Albums
Nice job on the oil change. Last night I was installing a Truxxx 3" lift on my truck and noticed the oil filter. I wasn't sure what it was, but now I know. Thanks again.
07 Black Crewmax 5.7 4X4 FE, BU, CK, DZ, AA, HM, MG, CF, SIRIUS, K&N CAI, SMITTYBILT SIDE STEPS, SMITTYBILT BULL BAR, TRUXXX 3" FRONT 1" REAR LEVELING KIT, BFG 305*65*18's, JBA DUALS, CHROME HANDLES...BLAH..BLAH..BLAH....
  #33 (permalink)
Old 07-12-2007, 09:15 PM
StatCoder's Avatar
Dealer : Las Cruces Toyota
2007 Toyota Tundra CrewMax Limited
Last Online: 10-15-2009 12:16 AM
StatCoder will become famous soon enough.
StatCoder's Photo Albums
I got mine done this afternoon at 2000 miles. No skid plate on my CrewMax and everything was conveniently near the front of the truck so there was plenty of room. At first the oil from the pan squirted out and bounced into the right front wheel then it splashed the other way. I had some problems with the plastic drainer because I didn't get it snapped in there for a while. This is definitely not a hot-engine friendly procedure. I also pushed the new big gasket too far down the filter housing so it squished out when I was screwing it in but I got it correct after that. Finally, for some reason, I was checking the level while the engine was running (don't do that) and thought I put a little too much oil in there. Probably 7.5 quarts. I saw some clear fluid running out over the old oil puddle and thought I was overflowing oil but it was condensation water.
I took apart the old filter but didn't see any metal pieces larger than small grains of sand. That was about 30 bucks worth of Mobil 1 5W20 from WalMart. I'm thinking of going 10K before the next change.
Be sure to properly seat the rubber O-ring on the filter otherwise all of your oil will leak out and leave your engine dry like the servcie dept did to the guy in one of these other threads. It doesn't belong way far down on the filter. It actually sits a half inch or so above where you might think. You should fee nice consistent resistance as you do your last few turns of the filter housing. You actually feel the rubber of the gasket sliding along like a screw with a rubber band wrapped around it. If you see the gasket squishing out of the edge of the filter as you tighten then it is in the wrong place.
2007 5.7 CrewMax Limited 2WD; Pyrite Mica/ Red Rock Leather
20" Alloy | Nav-JBL | Moonroof | Sonar | Cold Kit | Daytime Running Lights | BedRug | ConsoleVault | SoftTopper | TRD sway bar | Weatherguard Tool Box
NAV Mods: Speed Pulse Generator | AUX video input
Buy your truck outside of the Gulf States Toyota monopoly if you don't want to compromise.
  #34 (permalink)
Old 07-12-2007, 10:24 PM
Dealer : Servco Auto Center
2006 Toyota Avalon
Thrlls is on a distinguished road.
Thrlls's Photo Albums
For $25 you can get your oil analyzed at Blackstone Laboratories and they will let you know if you can extend the oil change intervals with the information and oil sample you send them. They can also tell you if there is any coolant in your oil...possible head gasket leak, or brass, aluminum, steel particles, which may mean bearing going or other related problems. It's a very comprehensive report that you get, and they'll send you a little container to send your oil sample via USPS.
I try to do this every 3rd oil change just to be sure there are no signs of a break down coming my way.
Here's a link: Blackstone Laboratories
  #35 (permalink)
Old 07-13-2007, 11:38 AM
wilecoyote's Avatar
Now that is some good info, much appreciated - thanks for the link as well. This could be an engine saving diagnostic and for only 25bucks well worth it.
  #36 (permalink)
Old 07-14-2007, 01:01 AM
Dealer : Darcars Toyota of Silver Spring
2007 Toyota Tundra SR5 CrewMax,
2005 Toyota Matrix
Last Online: Yesterday 02:32 PM
rootoo2 is on a distinguished road.
rootoo2's Photo Albums
I read earlier in the thread about using a torque wrench to get torque correct when replacing filter and skid plate. Does anyone have the service manual and TRULY know what the recommended torque is as per service manual? Guesses and thoughts about what torque was on an older truck just don't cut it. If we are going to break out the torque wrnech, might as well know the correct setting.
Thanks for all the pics and the step-by-step. Outstanding job.
  #37 (permalink)
Old 07-15-2007, 08:39 AM
Dealer : Hoselton Toyota Scion
2007 Toyota Tundra,
2006 Toyota Camry
Last Online: 04-24-2008 06:28 AM
pkingroch is on a distinguished road.
pkingroch's Photo Albums
Excellent thread for Q&A about this process.
One additional question about the filter. Is there a difference between the 5.7 filter no the TRD vehicle and the non-TRD vehicle? I asked about pricing at my dealer and I was told that there was a diiference. Non-TRD filter being $5,99 and TRD filter in the $20 range.
  #38 (permalink)
Old 07-15-2007, 03:46 PM
StatCoder's Avatar
Look, you paid at least $$30K for your Tundra, so why not pay $14 more to get the proper TRD filter?
Just kidding. There isn't any difference because the engine is exactly the same. There is a TRD oil fill cap, however.
  #39 (permalink)
Old 07-16-2007, 08:03 PM
DSLKSL's Avatar
Dealer : Rick McGill's Toyota
Last Online: 03-05-2009 10:20 PM
DSLKSL is on a distinguished road.
DSLKSL's Photo Albums
Watch out for your dealers! I have spoke to mine 3 times and each time they told me wrong things!
1st They only stock 10w 30 in bulk.
2nd if they tell you $29.00 for an oil change read the fine print they wil add for more than 4-5 quarts of oil.
  #40 (permalink)
Old 07-16-2007, 10:55 PM
Dealer : Courvelle Toyota
Last Online: 10-23-2007 09:06 PM
sardoin is on a distinguished road.
sardoin's Photo Albums
MAN, this is an awesome post. I haven't changed me oil yet but I will def. be refering to it when it comes time. This is as good as any service manual. Thanks soo much.
  #41 (permalink)
Old 07-17-2007, 05:32 PM
Dealer : Stevens Creek Toyota
Last Online: 05-03-2008 06:11 PM
bpittman91 is on a distinguished road.
bpittman91's Photo Albums
oil filter part # change for those who live near dealers that have rookies behind the counter...
04152-YZZA4
  #42 (permalink)
Old 07-18-2007, 12:11 AM
Dealer : Classic Toyota Scion of Round Rock
2007 Toyota Tundra Ltd TRD 2wd crew
Last Online: 11-19-2008 11:35 AM
doc caliban is on a distinguished road.
doc caliban's Photo Albums
Many thanks, great write up.
Did it tonight at 1300 miles with Castrol GTX (dino). Did it to a relatively hot motor and those first couple quarts came out so fast they shot right off my drain pan (same as pictured) and onto the tire lol.
TRD 2wd's do have the skid plate. Wasn't too bad really, but haven't put the skid back on yet.
One question: I noticed a bit of "goop" in a few places. If you've ever used WD-40 on adhesive and you get those little balls of jelly, that's what they looked like. It was mostly on the threads for the filter housing. Anyone else? Assembly lube? Wrong place for the question?
Cleaned them off, but it did make me curious...
Thanks
  #43 (permalink)
Old 07-18-2007, 09:21 AM
Dealer : Rivergate Toyota
Last Online: 08-14-2009 07:55 PM
gator111 is on a distinguished road.
gator111's Photo Albums
How do I get the pictures to display?
  #44 (permalink)
Old 07-18-2007, 02:25 PM
mhadden's Avatar
Dealer : Toyota Of Merrillville
2007 Toyota Tundra 5.7 CrewMax
Last Online: 04-08-2008 02:03 PM
mhadden will become famous soon enough.
mhadden's Photo Albums
They should display automatically, but if you are using a slow connection, you may have to wait a few min for them to load.
Doc Caliban, I didn't have that goop that you were talking about. I would assume that it was assembly lube or the like; I wouldn't worry too much about it.
2008 Honda CR-V EX AWD
2008 Honda Civic LX
  #45 (permalink)
Old 07-20-2007, 07:29 PM
Dealer : Marina Del Rey Toyota Scion
Last Online: 11-15-2009 03:29 PM
crewmaxlover is on a distinguished road.
crewmaxlover's Photo Albums
Unhappy Re: DIY: Oil Change w/ pics.
thank you for this post, i thought i would be the only one that put the o-ring in the wrong place and squashed it!!! the instructions on the oil filter box do not show where it goes and the filter housing leads you to think it may go on the bottom. I think i may have streched/nicked my o-ring as i have a very very tiny leak from the housing, but it still is driving me crazy. Mabey someone post a pic of the 0-ring in the correct place? I know it seems stupid , but i seem to screw up the easy ones!!
And thanks again to the one who started this post. I did not realize it was such a basic tool to remove the filter housing ( 65/67mm 14 flute oil filter wrench ).
And the one who noted the torque settings, im sure i have like 35lbs on the oil drain bolt
Also i narrowly missed spraying my right wheel brake disc with oil while draining.
Wish i would have read this before i did my first one
CML
LinkBack to this Thread: http://www.tundrasolutions.com/forums/tundra/104260-diy-oil-change-w-pics-reset/
Posted By For Type Date
Dumb Tundra question - TTORA Forum This thread Refback 11-13-2009 07:22 AM
DIY (Do-It-Yourself) & User Knowledgebase - Tundra Geeks :: The Toyota Tundra Enthusiast Forum This thread Refback 09-17-2009 03:24 PM
DIY (Do-It-Yourself) & User Knowledgebase - IBTO Toyota Tundra Forum This thread Refback 07-02-2009 12:39 AM
DIY (Do-It-Yourself) & User Knowledgebase - IBTO Official Forums This thread Refback 06-25-2009 11:57 PM
Anyone change there own oil? - IH8MUD Forums This thread Refback 04-28-2009 02:26 PM
Bumper Repair In Jacksonville, Bumper Repair 2000 Hyundai Sonata 4 Dr Gls, Bumper Sticker Motorcycle Safety - Dieselmotorcycle This thread Refback 03-08-2009 11:22 AM
White Stripe Power Wheels Ford Mustang Ride On Toy, White Stripe Power Wheels Ford Mustang, White Van Speakers - Dubswheels This thread Refback 03-06-2009 03:36 AM
08 Sequoia oil filter question - Toyota Forums :: Toyota Nation This thread Refback 11-02-2008 12:37 AM
Yesterday's Tractors :: View topic - Tundra message This thread Refback 08-21-2008 10:13 PM
Yesterday's Tractors - Discussion Forum This thread Refback 08-21-2008 08:37 AM
: Tow Vehicles: Tundra 5.7L Oil Changes This thread Refback 02-14-2008 04:15 PM
Woodalls Open Roads Forum: Tow Vehicles: Tundra 5.7L Oil Changes This thread Refback 10-27-2007 09:33 PM
RV.Net Open Roads Forum: Tow Vehicles: Tundra 5.7L Oil Changes This thread Refback 10-26-2007 01:48 PM
RV.Net Open Roads Forum: Tow Vehicles: Tundra 5.7L Oil Changes This thread Refback 10-24-2007 08:28 PM
RV.Net Open Roads Forum: Tow Vehicles: Tundra 5.7L Oil Changes This thread Refback 10-24-2007 04:16 PM
RV.Net Open Roads Forum: Tow Vehicles: Tundra 5.7L Oil Changes This thread Refback 10-24-2007 12:55 PM
Trailer Life Directory Open Roads Forum: Tow Vehicles: Tundra 5.7L Oil Changes This thread Refback 10-23-2007 09:04 PM
Trailer Life Magazine Open Roads Forum: Tow Vehicles: Tundra 5.7L Oil Changes This thread Refback 10-23-2007 03:26 PM
RV.Net Open Roads Forum: Tow Vehicles: Tundra 5.7L Oil Changes This thread Refback 10-23-2007 02:54 PM
RV.Net Open Roads Forum: Tow Vehicles: Tundra 5.7L Oil Changes This thread Refback 10-23-2007 02:49 PM
Oil Filter Change nhparrot Engine & Drivetrain 10 06-07-2009 07:15 PM
too soon for an oil change? john480 Tundra 24 11-29-2007 01:56 PM
Which BRAND of OIL? nhparrot Engine & Drivetrain 9 10-29-2007 01:43 PM
Alternate Oil Filters for I-Force V8: nhparrot Engine & Drivetrain 0 03-24-2002 10:09 PM
