LinkBack (19) Thread Tools Display Modes
  #61 (permalink)
Old 08-10-2007, 08:23 PM
Dealer : Hudson Toyota
Last Online: 10-23-2009 11:49 PM
john480 is on a distinguished road.
john480's Photo Albums
Default Re: DIY: Oil Change w/ pics. & Reset Maintenance Required Light
Originally Posted by smittystundra View Post
I just finished my first oil change on 2007 Tundra CrewMax and I wanted to say that it is the most different oil change I have done since my '69' Volkswagen with an internal filter. With the help from mhadden-great job and all of you it was really not that bad. The next one will be much easier. I did want to say one thing about adding a tube or hose to the plastic piece for draining the filter cannister. I used a piece of 5/8' heater hose. It was not the tightest fit but it worked without an oil mess. So if you have a 2 ft. piece in your garage it will work. Also I purchased the oil cup at Advance Auto - 65mm/14 flutes. Worked perfect. Be careful like others have said about putting the big O ring in the correct O ring slot. I used 5W20 Mobil 1 and the engine is even smoother running after the oil change. Love my Tundra.
how many mile do you have ??i think im waiting till there is 3000 till mobil1 i will be up to my third oil change by then
  #62 (permalink)
Old 08-11-2007, 01:06 AM
smittystundra's Avatar
Dealer : Peoria Toyota
Last Online: 11-04-2009 01:34 PM
smittystundra is on a distinguished road.
smittystundra's Photo Albums
I changed to Mobil 1 at 1400 miles. Just had the time and was in the mood so I changed it. I have been using Mobil 1 in my other vehicles for years. You never have to worry about using Mobil 1 oil. Heck I even have it my lawn mowers.
  #63 (permalink)
Old 08-13-2007, 12:39 AM
on the 5.7 shouldnt be 7.4 qts?? not 7qts
  #64 (permalink)
Old 08-13-2007, 09:35 AM
mhadden's Avatar
Dealer : Toyota Of Merrillville
2007 Toyota Tundra 5.7 CrewMax
Last Online: 04-08-2008 02:03 PM
mhadden will become famous soon enough.
mhadden's Photo Albums
Toyota does call for 7.4 quarts, but I used 7. Using 7 quarts put the oil level perfectly in the middle of the dipstick ("add" and "full"). Saves me (and you) from having 1/2 quart sitting around for a couple months until the next oil change with an open seal...
2008 Honda CR-V EX AWD
2008 Honda Civic LX
  #65 (permalink)
Old 08-13-2007, 07:22 PM
todcp's Avatar
Dealer : Smithtown Toyota
Last Online: 07-08-2009 10:20 PM
todcp is on a distinguished road.
todcp's Photo Albums
Glad you all had good luck. I did not. Some wise guy at the factory must have put my filter cover on with 300 pounds of torque. The 65//67 14 flute was not up to the task.
Looks like off to the dealer after wasting 7 quarts of Mobil 1 as I had to put everything else back together and did not change the filter element.
Love the truck but this is a very poor design. Why not put the cannister up top like BMW's. Taking the skid plate off and then having oil all over is absurd.
  #66 (permalink)
Old 08-16-2007, 11:10 AM
Dealer : Le Mieux & Son Toyota
1996 Toyota Avalon XLS Gold Pkg.,
2007 Toyota Tundra CM, LTD, 4x4, 5.7
Last Online: 09-27-2009 12:16 PM
dirccooley is on a distinguished road.
dirccooley's Photo Albums
Ecellent directions. It took me about 2 hours first time through. Most of the time spent waiting for oil to drain. I had two catch pans going after about 10 minutes for the bulk and the canister. I did some other chores while waiting for everything to drain....I had no complications and there was very little mess. I used a piece of 1/2" or 5/8" ID tubing on the canister "tool" to help guide the oil to the pan....worked great. My first attempt to use the "tool" was messy. Second attempt, I found by rotating the "tool" as I pushed it up helped it snap into place more easily without any overspill. When I took my canister there was minimal oil in reserve. Probably due to a 20 minute drain period. I did cut my filter open to find the metal filings between the creases. Scary, but nothing of any significant size. 2745 miles at change. Oil will be going to O.A.I for testing. The kit was $20 including shipping from my AMSoil rep who lives down the street. Anyone interested in getting oil from him let me know and I will get you his web contact info. I paid $58 for 2 gallons of 0w-20.
  #67 (permalink)
Old 08-20-2007, 06:03 PM
Dealer : Claremont Toyota Scion
2000 Toyota Tundra,
Last Online: 10-12-2009 09:58 PM
LawyerRon may have some regrets.
LawyerRon's Photo Albums
Just did my CrewMax at 5,000 miles. Wasn’t too bad for the first time. Most of the work is getting the skid plate off, but that was pretty easy too knowing what to expect with the excellent tutorial at the beginning of this thread. Next one will go much faster. One thing I did wrong was I left the small o-ring out of the filter cap when I drained the canister with the little plastic thingy. Got oil all over my hand. You need the o-ring in there when you drain it. Used lots of disposable gloves though and stayed clean.
2007 SR5 CrewMax, SiLver w/5.7 V8
>Bakflip Tonneau Cover.
>Rampage Running Boards.
>Heavy Duty 6 ft. Rubber Bed Mat
out of my 2000 Tundra cut to fit!
  #68 (permalink)
Old 08-21-2007, 11:28 AM
Taylorman's Avatar
Dealer : Hampton Toyota
Last Online: 10-11-2009 10:11 AM
Images: 1
Taylorman is on a distinguished road.
Taylorman's Photo Albums
What is the tool that the pdf shows to remove the filter housing. Is that the 65mm wrench?
  #69 (permalink)
Old 08-22-2007, 09:12 AM
mhadden's Avatar
Yes, it's the 65mm wrench.
2008 Honda Civic LX
  #70 (permalink)
Old 08-22-2007, 10:07 PM
Dealer : Classic Toyota
- Other -
Last Online: 10-27-2009 08:54 PM
tc1001 is on a distinguished road.
tc1001's Photo Albums
This is a cut and paste from another article. I found it interesting.
I am a NASA Engineer at
Marshal Space Flight Center in Huntsville, Alabama. My field of work is
Tribology which is the study of friction, wear, and lubrication. In our
spare time, our group collects and tests different motor oils using the
Shell Four Ball tester. This tester tests the extreme pressure properties
of oils. These areas in a motor are cam to lifter contacts, valve stem to
guild, and piston skirts. Over the years we have found synthetic bases oils
to out perform mineral based oils by a large margin. We test the oils new,
after 1000 miles, 2000 miles, and up to 10,000 miles. In a nut shell, we
found that synthetic oils have better wear properties after being run 10,000
miles then mineral grade oils new. Which synthetic do we use? First any
you will benefit from any synthetic, but we use Mobil 1. Mobil by far puts
more research dollars in motor oils then any other company. They are also
aggressive in racing.
Other notes on motor oils.
Do not run a multi grade oil (10w-30) more then 1000 to 2000 miles -
depending on your driving habits.
This is because a 10w30 oil starts its life as a 10 weight oil and large
polymer chains are added to get the 30 rating. These chains break down very
quickly which produces small chains with an open electron charge at the
ends. These ends attract grim and form sludge.
Do not run synthetics in a new rebuild. A new engine needs the added
friction allowed by mineral oils to set the rings properly. Chevy found
this out on the corvette. These cars came from the factory with Mobil 1 and
owners brought them back because of smoking and oil consumption (rings did
not seat). Run a good single weight oil for the first 2000 miles. We found
Havaline 30 to be a good mineral oil - in fact we use it for our standard.
The reason Mobil 1 can safely be run for 10,000 miles is because the
additive package is well engineered to isolate grim and hold it in
suspension. This also is why Mobil 1 is expensive. You know - you get what
you pay for.
  #71 (permalink)
Old 08-22-2007, 11:31 PM
MOREPOWER's Avatar
Last Online: 09-06-2008 09:56 AM
MOREPOWER will become famous soon enough.
MOREPOWER's Photo Albums
you pay for.
Sounds like a paid add, I tried M1 5w-30 and it shears to god knows what within 3500 miles, the engine revved like I was running 10w, now I have German Castrol 0w-30, I'm currently right a 5k miles and no sign of shearing, I am going to change it, I'm not running any oil over 5 to 7k miles, because of the short trips I run, and the low miles, I usually go 6 months + between changes.
  #72 (permalink)
Old 08-25-2007, 12:47 PM
BJH's Avatar
BJH BJH is offline
Dealer : Dave Edwards Toyota
Last Online: 08-03-2009 02:21 PM
BJH is on a distinguished road.
BJH's Photo Albums
For those of us that prefer WIX oil filters...The part number is 57041
  #73 (permalink)
Old 08-25-2007, 01:32 PM
mhadden's Avatar
'Bout time someone got a filter out! I didn't understand how hard it could be to replicate pleats and media material! Note that the filter does include 2 O-rings, but not the plastic drain thinger-majiggy. Can't find a price anywhere yet.
Just a note to everyone. I can't edit the DIY post anymore (because of expiration??) but there is a new oil filter p/n for the Toyota Kit. 04152-YZZA4
2008 Honda Civic LX
  #74 (permalink)
Old 08-27-2007, 01:39 PM
Gary419's Avatar
Dealer : Toyota and Scion of Louisville
2007 Toyota Tundra Std Cab&Bed,White
Last Online: 05-13-2009 09:04 AM
Gary419 is on a distinguished road.
Gary419's Photo Albums
Great input on oil change, this will really help my 1st, any idea on dealer oil change price with skid plate. I haven't priced mine yet and not ready to go sythetic yet.
Thanks
Gary419
  #75 (permalink)
Old 08-28-2007, 09:13 PM
Dealer : Toyota Scion of Roswell
2007 Toyota Tundra 07 .57 CM Silver
Last Online: 03-20-2009 11:59 PM
tundraexpress is on a distinguished road.
tundraexpress's Photo Albums
The lesson here is: Negotiate free oil changes for life when you buy. I have read that some people have done so. I bet that we wont recieve dealer coupons for 14.99 and 19.99 or even 29.99. Anyone know what the dealers are charing for oil changes?? PS Great Post
LinkBack to this Thread: http://www.tundrasolutions.com/forums/tundra/104260-diy-oil-change-w-pics-reset/
Posted By For Type Date
DIY (Do-It-Yourself) & User Knowledgebase - Tundra Geeks :: The Toyota Tundra Enthusiast Forum This thread Refback 09-17-2009 03:24 PM
DIY (Do-It-Yourself) & User Knowledgebase - IBTO Toyota Tundra Forum This thread Refback 07-02-2009 12:39 AM
DIY (Do-It-Yourself) & User Knowledgebase - IBTO Official Forums This thread Refback 06-25-2009 11:57 PM
Anyone change there own oil? - IH8MUD Forums This thread Refback 04-28-2009 02:26 PM
Bumper Repair In Jacksonville, Bumper Repair 2000 Hyundai Sonata 4 Dr Gls, Bumper Sticker Motorcycle Safety - Dieselmotorcycle This thread Refback 03-08-2009 11:22 AM
White Stripe Power Wheels Ford Mustang Ride On Toy, White Stripe Power Wheels Ford Mustang, White Van Speakers - Dubswheels This thread Refback 03-06-2009 03:36 AM
08 Sequoia oil filter question - Toyota Forums :: Toyota Nation This thread Refback 11-02-2008 12:37 AM
Yesterday's Tractors :: View topic - Tundra message This thread Refback 08-21-2008 10:13 PM
Yesterday's Tractors - Discussion Forum This thread Refback 08-21-2008 08:37 AM
: Tow Vehicles: Tundra 5.7L Oil Changes This thread Refback 02-14-2008 04:15 PM
Woodalls Open Roads Forum: Tow Vehicles: Tundra 5.7L Oil Changes This thread Refback 10-27-2007 09:33 PM
RV.Net Open Roads Forum: Tow Vehicles: Tundra 5.7L Oil Changes This thread Refback 10-26-2007 01:48 PM
RV.Net Open Roads Forum: Tow Vehicles: Tundra 5.7L Oil Changes This thread Refback 10-24-2007 08:28 PM
RV.Net Open Roads Forum: Tow Vehicles: Tundra 5.7L Oil Changes This thread Refback 10-24-2007 04:16 PM
RV.Net Open Roads Forum: Tow Vehicles: Tundra 5.7L Oil Changes This thread Refback 10-24-2007 12:55 PM
Trailer Life Directory Open Roads Forum: Tow Vehicles: Tundra 5.7L Oil Changes This thread Refback 10-23-2007 09:04 PM
Trailer Life Magazine Open Roads Forum: Tow Vehicles: Tundra 5.7L Oil Changes This thread Refback 10-23-2007 03:26 PM
RV.Net Open Roads Forum: Tow Vehicles: Tundra 5.7L Oil Changes This thread Refback 10-23-2007 02:54 PM
RV.Net Open Roads Forum: Tow Vehicles: Tundra 5.7L Oil Changes This thread Refback 10-23-2007 02:49 PM
Currently Active Users Viewing This Thread: 3 (2 members and 1 guests)
boarderchap , SilvLITundra
Oil Filter Change nhparrot Engine & Drivetrain 10 06-07-2009 07:15 PM
too soon for an oil change? john480 Tundra 24 11-29-2007 01:56 PM
Which BRAND of OIL? nhparrot Engine & Drivetrain 9 10-29-2007 01:43 PM
Alternate Oil Filters for I-Force V8: nhparrot Engine & Drivetrain 0 03-24-2002 10:09 PM
