LinkBack (20) Thread Tools Display Modes
  #91 (permalink)
Old 09-10-2007, 07:15 PM
MOREPOWER's Avatar
Last Online: 09-06-2008 09:56 AM
MOREPOWER will become famous soon enough.
MOREPOWER's Photo Albums
Default Re: DIY: Oil Change w/ pics. & Reset Maintenance Required Light
Originally Posted by qwq View Post
"it shears to god knows what within 3500 miles"
What does that mean?
Effects of Shearing
Its been documented that M1 5w-30 can shear to something close to 5w-20,
It was my experience with it. many believe (There have been tests done to confirm it although on only one Extended life grade) its now a group III base stock oil, maybe the reason for the price drop at "China mart"
The man in TC101's article was right - too conservative if anything. Mobil 1 is great. I've been using it for many years. I change it only at 15,000 mile intervals. My Ford F-150 now has over 300,000 miles now and still - knock on wood - runs like new. Likewise in my previous vehicles. In my old VW Beetle I never changed the Mobil 1 oil at all, just replaced what fell out. Beetle also hit 300,000 miles before rust killed it, the engine (and transmission) still running like new.
15k on one, and none on the Beetle? Nice.
  #92 (permalink)
Old 09-11-2007, 03:39 PM
Dealer : Champion Toyota Scion Gulf Freeway
Last Online: 09-11-2007 03:40 PM
JMCNATT is on a distinguished road.
JMCNATT's Photo Albums
Unhappy Re: DIY: Oil Change W/ CORRECT FILTER
I have a 2007 full sized Tundra and I had the oil changed for the first time at a local drive thru oil change place. After having the oil changed my oil pressure gauge started having dramatic increases in oil pressure when accelerating. There was even some mild loss of power while pulling my horse trailer. I took it by the dealer and they said that was normal which I knew it wasn't! I had them change the oil and FILTER that the other place serviced 3 days before and IMMEDFIATELY the truck was happy again and the gauge returned to being stable!!! The truck and engine was conpromised by using a different filter than the special one toyota made for this truck.
Be careful not to make the same mistake and end up with a compromised engine or worse!
  #93 (permalink)
Old 09-12-2007, 01:04 AM
qwq qwq is offline
Last Online: 05-02-2009 11:50 AM
qwq is on a distinguished road.
qwq's Photo Albums
Originally Posted by MOREPOWER View Post
Effects of Shearing
Don't quite follow you. What price drop? I've been using M1 5W30 for over 300,000 miles in my '97 Ford F150, and using the Extended Service Mobil 1 5W30 since it first hit the market a couple of years ago. In between the Beetle and the present Ford I also had some other vehicles including a Toyota Tercel that I sold at ~ 100,000 miles and a Nissan pickup truck that i sold at ~125,000 miles. Same deal with all of them, M1 and M1 filter, changing them at 10,000 mile intervals, now extended to 15,000 mile intervals, except, as I said, the somewhat leaky Beetle which just got oil added to it. All these engines have performed flawlessly.
  #94 (permalink)
Old 09-12-2007, 10:21 AM
Dealer : Hudson Toyota
Last Online: 10-23-2009 11:49 PM
john480 is on a distinguished road.
john480's Photo Albums
just pick up 5-20 at walmart 20 for 5quart
  #95 (permalink)
Old 09-13-2007, 02:30 AM
qwq qwq is offline
qwq's Photo Albums
It's much cheaper in the 5 qt. containers. I see that they are coming out with all sorts of new variations - M1 for trucks, M1 for hi-mileage vehicles, etc. I don't know what that's all about. I just use the extended mileage M1. Not every Walmart has a good selection, though. Also Walmart doesn't sell the M1 oil filters. But you can bring in your own filter and buy the oil there and they'll change it for you for ~$10 - I don't know about your Tundras, though.
  #96 (permalink)
Old 09-14-2007, 03:21 AM
beachbum1's Avatar
Dealer : Rice Toyota
- Other -
Last Online: 02-18-2008 04:50 PM
beachbum1 is on a distinguished road.
beachbum1's Photo Albums
had two oil changes @ 2 different sprawlmarts. wouldn't use their auto dept for an oil change in my push mower. incompetence galore. saw one guy try to torque a fill plug on with an impact. another place i told to use mob 1 10-30 in my jeep, saw the guy try to put the ultra cheap axx sprawlmart oil in there. no thanks, would rather drag my junk over hot coals and then have a russian ballet troupe dance on it.
your correct about the 5 qt jugs. 19.96$ most of the time iirc, though ive never seen 0w-20. but the local place to me has 5-20 most of the time. but that's a debatable oil viscosity argument that i wont tread on lol.
cheers
my garage? jeeps...too many freakin jeeps.
  #97 (permalink)
Old 09-16-2007, 01:55 AM
Afterimage's Avatar
Dealer : Toyota of Puyallup
2007 Toyota Tundra DC TRD LTD 4x4
Last Online: 11-19-2009 03:04 AM
Afterimage is on a distinguished road.
Afterimage's Photo Albums
Cheers to mhadden for the time and effort to post this D.I.Y.
I did the first oil change on my 5.7 a couple hours ago.
Here's a few observations:
I found the entire job to be very easy but a bit more time consuming than most vehicles due to the skidplate and aircraft-type oil filter bowl + plug.
First of all, if you try and do an oil change on this truck using a normal oil catch pan, you are ASKING to have oil splash all over, etc. etc. The low viscosity of the oil this engine uses plus the angle of the oil pan drain are the reasons why. After reading a few of the posts concerning this, it was obvious that a taller container would solve the problem nicely. I used a 4-gallon steel bucket that sits 10.5 inches high at the top. It easily caught the entire 7.5 quarts of hot oil with zero splashing and zero mess. I had the truck's front wheels on a couple short sections of 2" x 12" wooden plank that gave just a little more room to work underneath the truck.
The oil filter bowl is designed a somewhat like the main oil filter on the turbine engine I have for an avatar currently. The plastic drain nipple works just fine if you run a piece of rubber hose from it to your oil catch bucket. Just seat it into the filter bowl quickly and squarely and no oil will run out the sides. The filter bowl O-ring does have a slight tendency to want to roll or pinch when re-attaching the bowl. There are two old techniques used on aircraft oil filter bowl O-rings that can be done beforehand to prevent this: The first is to put a film of vaseline (a.k.a. Petrolatum in aviation maintenance) on the O-ring; it works better than engine oil for getting the O-ring to slip past the bowl housing lip. The second is to take a metal pick (dentist pick), lift the O-ring from its groove, and run the pick around the circumference of the filter bowl 2 or 3 times with the O-ring riding on top of it. This will take any twists in the O-ring out.
IMO, doing this oil change is no big deal. Just plan on some extra time to accomplish it and use an appropriate catch container for the oil.
  #98 (permalink)
Old 09-16-2007, 10:51 PM
Henry T's Avatar
Dealer : St. Charles Toyota
Last Online: Yesterday 09:36 PM
Images: 25
Henry T will become famous soon enough. Henry T will become famous soon enough.
Henry T's Photo Albums
I also noticed this "pinching and rolling" of the bowl O-ring while re-installing the bowl, you could feel and hear it. I just used engine oil to lube it for reinstallation and went slowly. Next time I will use vaseline cause I bet this is were most people run into trouble with leaks after reinstallation. Very good tip.
I should have remembered that from my days in the USAF, but that was a LONG time ago, I crewed F-4s for crying out loud LOL
  #99 (permalink)
Old 09-17-2007, 07:24 AM
Dealer : David Maus Toyota Scion
Last Online: 09-14-2008 04:49 PM
Luisbxync is on a distinguished road.
Luisbxync's Photo Albums
Great job, I got stuck at the hooks, when dropping the peble gard. Once I had it down I removed the hooks, they will not hang me up again. Need the tool for removing the oil filter assembly. Thinking of making a trap door, so filter removal could be done with out removing the peble gard.
  #100 (permalink)
Old 09-17-2007, 05:57 PM
mhadden's Avatar
Dealer : Toyota Of Merrillville
2007 Toyota Tundra 5.7 CrewMax
Last Online: 04-08-2008 02:03 PM
mhadden will become famous soon enough.
mhadden's Photo Albums
Out of curiosity, why did this get unstickied?
2008 Honda CR-V EX AWD
2008 Honda Civic LX
  #101 (permalink)
Old 09-17-2007, 06:01 PM
mxsjw's Avatar
Jedi Ninja in Training
- Other - 2003 VW Passat,
Images: 10
mxsjw's Photo Albums
It is still stickied, kind of. It is contained in the DIY sticky now.
Beer please!
  #102 (permalink)
Old 09-18-2007, 05:31 AM
Afterimage's Avatar
Those are much cooler aircraft than the commercial jetliners I work on.
Here's a small PDF for your amusement.
[/off topic]
  #103 (permalink)
Old 09-18-2007, 08:17 AM
Henry T's Avatar
Images: 25
[/off topic]
LOL looks just like the tundra set up
Yep I would have had it no other way, them F-4's were very cool!! Will never forget that experiance, night launches were the coolest.
In a lot of ways I miss being on the flight line and working on aircraft.
Pic attatched
DIY: Oil Change w/ pics. & Reset Maintenance Required Light-phantom-09.jpg
  #104 (permalink)
Old 09-18-2007, 05:18 PM
R0CKETMAN's Avatar
Last Online: 01-03-2008 03:32 PM
R0CKETMAN is on a distinguished road.
R0CKETMAN's Photo Albums
Got my first oil change at Toy dealer today for $32. They used toy 5w20
07 TUNDRA White Limited DC 4x4 TRD
Mods: Ready Lift, BFG 305/65/18, 5% tint, TRD shifter, Line X, door sill protectors, UWS toolbox, WeatherTech mats / wind deflectors, LifeLong hitch pin, more to follow
  #105 (permalink)
Old 10-04-2007, 01:21 PM
Last Online: 09-12-2009 11:44 AM
jimdowd is on a distinguished road.
jimdowd's Photo Albums
Does anyone know where i could get a 65MM wrench all i see arounf is the 65/67mm
LinkBack to this Thread: http://www.tundrasolutions.com/forums/tundra/104260-diy-oil-change-w-pics-reset/
Posted By For Type Date
Dumb Tundra question - TTORA Forum This thread Refback 11-13-2009 07:22 AM
DIY (Do-It-Yourself) & User Knowledgebase - Tundra Geeks :: The Toyota Tundra Enthusiast Forum This thread Refback 09-17-2009 03:24 PM
DIY (Do-It-Yourself) & User Knowledgebase - IBTO Toyota Tundra Forum This thread Refback 07-02-2009 12:39 AM
DIY (Do-It-Yourself) & User Knowledgebase - IBTO Official Forums This thread Refback 06-25-2009 11:57 PM
Anyone change there own oil? - IH8MUD Forums This thread Refback 04-28-2009 02:26 PM
Bumper Repair In Jacksonville, Bumper Repair 2000 Hyundai Sonata 4 Dr Gls, Bumper Sticker Motorcycle Safety - Dieselmotorcycle This thread Refback 03-08-2009 11:22 AM
White Stripe Power Wheels Ford Mustang Ride On Toy, White Stripe Power Wheels Ford Mustang, White Van Speakers - Dubswheels This thread Refback 03-06-2009 03:36 AM
08 Sequoia oil filter question - Toyota Forums :: Toyota Nation This thread Refback 11-02-2008 12:37 AM
Yesterday's Tractors :: View topic - Tundra message This thread Refback 08-21-2008 10:13 PM
Yesterday's Tractors - Discussion Forum This thread Refback 08-21-2008 08:37 AM
: Tow Vehicles: Tundra 5.7L Oil Changes This thread Refback 02-14-2008 04:15 PM
Woodalls Open Roads Forum: Tow Vehicles: Tundra 5.7L Oil Changes This thread Refback 10-27-2007 09:33 PM
RV.Net Open Roads Forum: Tow Vehicles: Tundra 5.7L Oil Changes This thread Refback 10-26-2007 01:48 PM
RV.Net Open Roads Forum: Tow Vehicles: Tundra 5.7L Oil Changes This thread Refback 10-24-2007 08:28 PM
RV.Net Open Roads Forum: Tow Vehicles: Tundra 5.7L Oil Changes This thread Refback 10-24-2007 04:16 PM
RV.Net Open Roads Forum: Tow Vehicles: Tundra 5.7L Oil Changes This thread Refback 10-24-2007 12:55 PM
Trailer Life Directory Open Roads Forum: Tow Vehicles: Tundra 5.7L Oil Changes This thread Refback 10-23-2007 09:04 PM
Trailer Life Magazine Open Roads Forum: Tow Vehicles: Tundra 5.7L Oil Changes This thread Refback 10-23-2007 03:26 PM
RV.Net Open Roads Forum: Tow Vehicles: Tundra 5.7L Oil Changes This thread Refback 10-23-2007 02:54 PM
RV.Net Open Roads Forum: Tow Vehicles: Tundra 5.7L Oil Changes This thread Refback 10-23-2007 02:49 PM
Oil Filter Change nhparrot Engine & Drivetrain 10 06-07-2009 07:15 PM
too soon for an oil change? john480 Tundra 24 11-29-2007 01:56 PM
Which BRAND of OIL? nhparrot Engine & Drivetrain 9 10-29-2007 01:43 PM
Alternate Oil Filters for I-Force V8: nhparrot Engine & Drivetrain 0 03-24-2002 10:09 PM
