DIY: Oil Change w/ pics. & Reset Maintenance Required Light
NEWS
+ Reply to Thread
Page 1 of 31 1 2 3 4 5 6 11 ... LastLast
Results 1 to 15 of 452
Like Tree3Likes
Thread: DIY: Oil Change w/ pics. & Reset Maintenance Required Light
  1. #1
    Veteran Member mhadden has done just about everything...and then some. mhadden has done just about everything...and then some. mhadden has done just about everything...and then some. mhadden has done just about everything...and then some. mhadden has done just about everything...and then some. mhadden has done just about everything...and then some. mhadden has done just about everything...and then some. mhadden has done just about everything...and then some. mhadden has done just about everything...and then some. mhadden has done just about everything...and then some. mhadden has done just about everything...and then some. mhadden's Avatar
    Join Date
    Dec 2006
    Location
    USA
    Posts
    976
    Liked
    2 times
    Rep Power
    865
    Post DIY: Oil Change w/ pics. & Reset Maintenance Required Light
    Due to a somewhat overwhelming demand, I'm posting a how-to with pics. Hopefully this answer questions about the oil changes. Keep in mind that this is for 5.7. The 4.7 will have the canister filter and will be a helluva lot easier to change. Not sure if the oil filter is in a different location on the 4.7's, either.
    Disclaimer: If you are unwilling or unable, do not perform this maintenance by yourself. Contact your local dealership for service. I cannot be held responsible for any damage incurred during or after this procedure.
    The tools that you’ll need:
    3/8” socket wrench
    3” 3/8” extension
    10 mm socket (or Phillips screwdriver)
    12 mm socket
    14 mm socket
    65/67 mm 14 flute oil filter wrench
    Toyota Oil Filter Kit: P/N 04152-38020
    7 Quarts 0W20 or 5W20
    First thing you’ll need to do is remove the skid plate, if you have one. There are 3 screws (holes identified in yellow) that have Phillips ends, but you can use the 10 mm socket since it’ll be easier and there are 5 2” long bolts (identified by red) holding the skid up. Use your 12 mm socket with extension to get these loose. It’s probably better to remove the front 3 screws and work your way back as the bolts will help hold the skid up until you are ready to remove. I couldn’t get a picture of what to do to remove the skid, but once all bolts are out, you’ll need to push the whole skid up and slide it towards the driver side. Then release and it should come down. Be careful not to whack yourself in the head with the thing…it’s a little heavy.
    Once you remove the skid, you’ll need to identify where the oil filter (in yellow) and bulk oil drain bolt (in red) are located. I’ve indicated them as pictured above.
    You’ll need a 14 mm socket to loosen the oil drain bolt. I use it to break it loose, and then I unscrew it with my hand. Get ready for a mess! Make sure you have your oil pan more towards the front wheel as the oil will shoot that way. Take a break by drinking a beer or whatever; it’ll take some time for the 7 quarts of oil to drain. Once the oil is dripping out of the hole, hand tighten the bolt back into the hole, taking care not to cross-thread the bolt. Then use the 14 mm socket to tighten.
    Use your 3/8” extension to loosen the oil filter drain bolt. Don’t worry; very little oil will come out when you remove the bolt. Above is what it’ll look like with the bolt removed. You will have to use that plastic “tool” to help drain the oil out of the filter area. I’ve been changing my own oil since I’ve been driving and this was the messiest, most pain-in-the-a$$ thing I’ve ever dealt with. I had to push up (and hard!) to get the oil to come out. Even after pushing up and having the oil drain for 5 minutes I still didn’t get it all. It would have been a lot easier if the sway bar wasn’t so close to the filter location.
    After you attempt to drain all the oil out of the filter, wipe the area off with a rag. Make sure you don’t damage the oil filter drain gasket if you plan on using it again (I did). Then using your 65/67 mm 14 flute oil wrench and 3/8” extension, twist the cap off. Once you turn it a couple times you’ll be able to twist it by hand…be prepared for more oil! Drop the whole assembly into your oil pan as it’ll make it easier to clean your hand and the area around the oil filter assembly. Once you have the truck portion cleaned up, remove the old oil filter that remains on the lower assembly and replace it with the new one. They should just pull off and push on. If you plan to change the gasket, do it now. Twist the lower assembly that holds the filter on taking care not to cross-thread. Then use your oil filter wrench to twist it tight. Make sure to put your oil filter drain bolt back on (make sure the gasket it on the lower assembly, then put the bolt on). Once everything is tight, fill your engine up with the motor oil of your choice and check your oil level on the dipstick. I used 7 quarts and it put the oil level perfectly in the middle of the empty and fill portion of the dipstick, which is where I like it. Made it easier not to use half a quart too…
    Start your engine after filling and let it run for 2-3 minutes. Make sure you oil pressure is in the operating range. Check for leaks.
    You’ll need to put the skid back on now. It’s not as bad as everyone says it is. Above are the holes you’ll need to align the hooks of the skid with. Make sure to have the plastic tabs of the front bumper overlapping the skid, otherwise the skid won’t go back into place. Then using the reverse process of removal, hand install the rear bolts into the skid, working your way forward taking care not to cross-thread the bolts. Then tighten the bolts. Finally tighten the screws; watch not to over tighten the screws as it’ll strip the plastic holders on the skid (which can be replaced if you do happen to strip them).
    To reset your maintenance reminder system (even if the light hasn’t come on yet), you’ll need to turn your key to on (but don’t start!) and make sure your odometer is on TRIP A. Then key off. Press and hold the Odometer/Trip button. While holding down on the button, key the ignition to on (Don’t start the engine!) The display panel will count down from “------“ to “-“Continue pressing the button until the Trip A is displayed. After this step, you are done. Drink a couple beers for a job well done!
    Attached Thumbnails Attached Thumbnails DIY: Oil Change w/ pics. & Reset Maintenance Required Light-toolsqw4.jpg   DIY: Oil Change w/ pics. & Reset Maintenance Required Light-boltidentbf9.jpg   DIY: Oil Change w/ pics. & Reset Maintenance Required Light-drainholesgv4.jpg   DIY: Oil Change w/ pics. & Reset Maintenance Required Light-drainingsj2.jpg   DIY: Oil Change w/ pics. & Reset Maintenance Required Light-oilfilterdrainrn2.jpg   DIY: Oil Change w/ pics. & Reset Maintenance Required Light-filterdrainholevp2.jpg   DIY: Oil Change w/ pics. & Reset Maintenance Required Light-fillvg6.jpg   DIY: Oil Change w/ pics. & Reset Maintenance Required Light-skidly1.jpg   DIY: Oil Change w/ pics. & Reset Maintenance Required Light-hookholeshg7.jpg   DIY: Oil Change w/ pics. & Reset Maintenance Required Light-resetstep1xj9.jpg
    DIY: Oil Change w/ pics. & Reset Maintenance Required Light-resetfinalstepyx5.jpg   DIY: Oil Change w/ pics. & Reset Maintenance Required Light-usedfilterew7.jpg   DIY: Oil Change w/ pics. & Reset Maintenance Required Light-oilfilter-and-tool.jpg
    Last edited by Tundradrenalin; 08-21-2010 at 07:38 AM. Reason: saved pictures locally
    houlbex likes this.
  2. Remove Advertisements
    Toyota Tundra Forum
    Advertisements
  3. #2
    Junior Member PaulMerrit is on the right track. PaulMerrit is on the right track. PaulMerrit is on the right track. PaulMerrit is on the right track. PaulMerrit is on the right track. PaulMerrit's Avatar
    Join Date
    Jul 2007
    Location
    Bradenton, FL
    Posts
    139
    Liked
    1 times
    Rep Power
    7
    Default Re: DIY: Oil Change w/ pics.
    Needs to be a sticky....thanks for taking the time. We all appreciate it.
    2007 Toyota Tundra SR5 CrewMax
    2005 Toyota Camry
  4. #3
    Rookie Spanky23 is on a distinguished road.
    Join Date
    Jun 2007
    Location
    Ridgeley,WV
    Posts
    15
    Liked
    0 times
    Rep Power
    0
    Nice post!!!
  5. #4
    Supercharged Member HOGWILD is a glorious beacon of light. HOGWILD is a glorious beacon of light. HOGWILD is a glorious beacon of light. HOGWILD is a glorious beacon of light. HOGWILD is a glorious beacon of light. HOGWILD is a glorious beacon of light. HOGWILD is a glorious beacon of light. HOGWILD is a glorious beacon of light. HOGWILD is a glorious beacon of light. HOGWILD is a glorious beacon of light. HOGWILD is a glorious beacon of light. HOGWILD's Avatar
    Join Date
    May 2006
    Location
    Albuquerque
    Posts
    3,522
    Liked
    1 times
    Images
    12
    Rep Power
    148
    Great post but Toyota puts Torque Specs on bolts they feel that need them and yes you may never strip a thread but the one time you do you will be kicking yourself!! Oil drain plug i think is like only 9 Ftlb and would probably be over torqued very easy!! People that say Torque values are useless have no use working on a vehicle, especially mine!! Had to do retorque after Dealer did ball joints on my 06 DC on the tires and my 150Ftlb Torque wrench would do nothing but click and torque was supposed to be only 83 Ft lb. Stupid Techs get away with this and yes this will warp the brake rotors. My take on DIY Maintenance is ya gotta have a clue on Maintenance or i would advise letting a Qualified Tech do the work if ya can find one!!
  6. #5
    Junior Member mtusrsmith is on a distinguished road.
    Join Date
    May 2007
    Location
    Central IL
    Posts
    135
    Liked
    1 times
    Rep Power
    6
    Well written hadden.
    Regarding the messy filter housing drain 'instrument', I found that removing the o-ring for the filter housing drain plug (after remoinving the drain plug, of course) allowed the plastic thingy to seat properly into the opening and I was then able to walk away, drink another beer, and allow the housing to drain completely. That way when I unscrewed the filter housing there was no mess either.
    SRS
    07 Tundra SR5
    CrewMax 4x4 5.7L
  7. #6
    Join Date
    Dec 2006
    Location
    USA
    Posts
    976
    Liked
    2 times
    Rep Power
    865
    Thread Starter
    Quote Originally Posted by mtusrsmith View Post
    Point taken. I will do this next time...I didn't remove the oil filter plug gasket before using the tool...
  8. #7
    Join Date
    May 2006
    Location
    Albuquerque
    Posts
    3,522
    Liked
    1 times
    Images
    12
    Rep Power
    148
    Craftsman 44595 Torque Wrench, 1/2 in. Drive at Sears.com
    They are on sale and can save you a bunch of money if youhave had one too many beers!! Yes they are expensive but A MUST to use unless ya wanta be like the dealer techs!! worth every penny!!
  9. #8
    Rookie Thunderbutt is on a distinguished road.
    Join Date
    Jun 2007
    Location
    Jacksonville, FL
    Posts
    12
    Liked
    0 times
    Rep Power
    0
    Great post! Pictures are worth a thousand words.
    (Nothing like 27 8x10 color glossies with circles and arrows and a paragraph on the back of each one to get a point across.)
    Many thanks.
    I went to the Sears Torque wrench link on the above post. After reading some of the reviews on them I would not purchase one. Several of the posts say that the locking rings that hold the adjustable handles on break or fail, rendering it useless. Also, it has only a one year warranty.
    I don't mean to stomp on your post, just my observation. I will likely get one that has better reviews for more longevity.
    2007 Crewmax, 4x2, Slate Metallic
  10. #9
    Veteran Member kathyricks is on a distinguished road. kathyricks's Avatar
    Join Date
    May 2007
    Location
    Salem
    Posts
    805
    Liked
    0 times
    Rep Power
    6
    Awesome pics mhadden! Congrats!
  11. #10
    Rookie Keetoman is on a distinguished road.
    Join Date
    Jul 2007
    Location
    Howe, TX
    Posts
    8
    Liked
    0 times
    Rep Power
    0
    Thank you very much!
  12. #11
    Junior Member hoss10 is on a distinguished road.
    Join Date
    Jun 2007
    Location
    Grand Bend
    Posts
    55
    Liked
    0 times
    Rep Power
    5
    Thank You for taking the time to make that, it is the equal of any service manual.
    I would like to add a few additions for changing the oil on a 4.7, 2 wheel drive. Drain the oil, reach in and remove oil filter, replace, fill with oil.
    I'm sorry us 4.7 drivers take a great deal of abuse, and I couldn't resist.
    I do really like your post.
  13. #12
    Junior Member joshp is on a distinguished road.
    Join Date
    Jun 2007
    Location
    Bay Area
    Posts
    399
    Liked
    0 times
    Rep Power
    5
    I have a few comments; great post by the way.
    How much did each of the items below cost and in my manual it says to use 5w-30?
    Anyone else finding the resemblance between this truck and mercedes and bmw? Sucks in some ways. Like that oil filter, I know bmw uses a similar system . The fully electric gas pedal feature various onboard computer systems etc.
  14. #13
    Veteran Member TucsonCrew creates their own distinguished roads. TucsonCrew creates their own distinguished roads. TucsonCrew creates their own distinguished roads. TucsonCrew creates their own distinguished roads. TucsonCrew creates their own distinguished roads. TucsonCrew creates their own distinguished roads. TucsonCrew creates their own distinguished roads. TucsonCrew creates their own distinguished roads. TucsonCrew creates their own distinguished roads. TucsonCrew creates their own distinguished roads. TucsonCrew creates their own distinguished roads. TucsonCrew's Avatar
    Join Date
    Jun 2007
    Location
    Tucson
    Posts
    590
    Liked
    0 times
    Images
    36
    Rep Power
    464
    Where do you get the plastic thingy. I read the post but maybe I missed it. I'm to lazy to read it again.
    2007 Tundra SR5 5.7,2WD White Crewmax
    Toytec 3 Inch lift,18 Monster wheels
    Firestone airbags with compressor
    295/70/18 Tires,Step Rails,Dash Mat
    Bed Extender,Carbon Fiber Dash Kit
    Clazzio seat covers, TRD Sway Bar
  15. #14
    Junior Member hwntundra is on a distinguished road. hwntundra's Avatar
    Join Date
    Jun 2007
    Location
    town
    Posts
    74
    Liked
    0 times
    Rep Power
    5
    That was a great help. I even printed it out for my first oil chang coming up. I will be doing a change at 1000k also. Much appreciated mhadden!!
  16. #15
    Junior Member m3elmo is on the right track. m3elmo is on the right track. m3elmo is on the right track. m3elmo is on the right track.
    Join Date
    Jun 2007
    Location
    Redwood City, CA
    Posts
    140
    Liked
    0 times
    Rep Power
    6
    STICKY!
    The plastic thing comes with the TRD Oil Filter Kit as well as the O Rings.
    '88 M3
    '95 M3
    '04 R1
    '03 R6
+ Reply to Thread
  1. 05-12-2012, 02:04 PM
  2. 05-05-2012, 07:06 AM
  3. 05-02-2012, 03:09 PM
  4. 03-23-2012, 11:14 AM
  5. 02-28-2012, 09:08 AM
  6. 01-24-2012, 05:30 AM
  7. 01-14-2012, 11:21 PM
  8. 12-13-2011, 06:35 AM
  9. -
    Refback This thread
    12-07-2011, 10:03 AM
  10. 12-05-2011, 02:51 AM
  11. 11-26-2011, 03:15 PM
  12. 11-26-2011, 12:17 PM
  13. 10-21-2011, 01:14 AM
  14. 09-14-2011, 03:16 PM
  15. 06-30-2011, 07:27 PM
  16. 06-25-2011, 01:19 AM
  17. 06-24-2011, 12:23 AM
  18. 06-18-2011, 05:33 PM
  19. 03-27-2011, 04:36 PM
  20. 03-15-2011, 08:07 PM
  21. 02-09-2011, 01:00 AM
  22. 02-08-2011, 01:32 PM
  23. 01-28-2011, 04:37 PM
  24. 11-17-2010, 10:11 AM
  25. 09-20-2010, 09:42 AM
  26. 09-13-2010, 03:53 PM
  27. 09-10-2010, 07:25 AM
  28. 07-20-2010, 12:52 PM
  29. 04-18-2010, 10:12 AM
  30. 04-11-2010, 07:47 AM
  31. 04-06-2010, 08:03 AM
  32. 03-16-2010, 05:01 PM
  33. 03-14-2010, 02:50 PM
  34. 02-12-2010, 04:20 PM
  35. 01-15-2010, 03:15 PM
  36. 12-20-2009, 10:48 AM
  37. 11-13-2009, 04:22 AM
  38. 07-01-2009, 09:39 PM
  39. 06-25-2009, 08:57 PM
  40. 04-28-2009, 11:26 AM
  41. 03-08-2009, 08:22 AM
  42. 03-06-2009, 12:36 AM
  43. 11-01-2008, 09:37 PM
  44. 08-21-2008, 07:13 PM
  45. 08-21-2008, 05:37 AM
  46. 02-14-2008, 01:15 PM
  47. 10-27-2007, 06:33 PM
  48. 10-26-2007, 10:48 AM
  49. 10-24-2007, 05:28 PM
  50. 10-24-2007, 01:16 PM
  1. Oil Filter Change
    By nhparrot in forum Engine & Drivetrain
    Last Post: 06-07-2009, 04:15 PM
  2. too soon for an oil change?
    By john480 in forum Tundra
    Last Post: 11-29-2007, 10:56 AM
  3. Which BRAND of OIL?
    Last Post: 10-29-2007, 10:43 AM
  4. Alternate Oil Filters for I-Force V8:
    Last Post: 03-24-2002, 07:09 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
