  #16 (permalink)
Old 08-04-2007, 09:11 AM
Dealer : Gene Reed Toyota
Last Online: 08-17-2009 05:36 PM
turbo8765 is on a distinguished road.
turbo8765's Photo Albums
Default Re: why 4.10s
Originally Posted by joshp View Post
Yeah this doesn't make sense to me, in the past the whole reason behind a 6th gear would be turning low rpm's on highway to get better mpg. 5th gear should be the towing gear on the highway I would think.
Also any news on a computer update for shift points? Mine seems like the transmission shifts and gears that it runs in are too tall at low speed putting too much of a load on the truck causing excessive fuel consumption at least that's what I figure. It's like you are at 30 mph and want to go faster the tranny doesn't shift it stays in the taller gear and you can feel the load on the engine which in turn is going to cause excess fuel consumption. Now the tranny will shift if you put your foot in it and maybe this is what I should do? Almost feels like being too easy on the pedal may actually cause worse mileage because it doesn't use the gears if you ease up in speed, instead it stays in the same gear.
Keeping the revs down is the key factor in reducing fuel consumption. This is why your truck is exhibiting the behavoir you've described.
More agressive gearing almost always equates to better accerleration. Exceptions, however, occur when traction is limiting or the gears are so short that the time spent performing additional gear changes exceeds the time saved with increased acceleration.
The likelihood is that the 4.10s represent an optimization of these two factors with respect to acceleration.
I haven't seen the gears side by side, but the 4.30's may also be larger and heavier. Do you know if this is the case?
  #17 (permalink)
Old 08-07-2007, 04:35 PM
Dealer : Newbold Toyota - Scion
Last Online: 02-22-2008 11:02 AM
litfuse may have some regrets.
litfuse's Photo Albums
If anything, the 4.30s will be smaller and not as strong. And I don't know where guys are running at 2000rpms at 70mph with 4.10s. I run almost 80mph at 2000rpms in my rcsb sport package tundra.
  #18 (permalink)
Old 08-07-2007, 05:29 PM
2005 Scion xB,
2005 Toyota Corolla,
- Other - 84 Reg cab Long bed,
2007 Toyota Tacoma
Last Online: 10-25-2007 10:05 PM
hotbox05 is on a distinguished road.
hotbox05's Photo Albums
or just use the sequential
www.myspace.com/hotbox05
www.myspace.com/mertechperformance
Lookin' for 22r hop up parts
merTECHPerformance
Suzuki . FOX racing . Toyota . SCION .
www.CafexD.com
  #19 (permalink)
Old 08-07-2007, 06:14 PM
POS71RS's Avatar
Dealer : Thousand Oaks Toyota
Last Online: 07-30-2009 08:29 AM
POS71RS is on a distinguished road.
POS71RS's Photo Albums
Hell, If they offered 3.90s, I would have gone with those.. bring my freeway cruise rpm down a touch...
  #20 (permalink)
Old 08-07-2007, 06:37 PM
jkd jkd is offline
Dealer : Prestige Toyota
Last Online: 10-08-2009 06:12 PM
jkd is on a distinguished road.
jkd's Photo Albums
It doesn't really matter, if you go to the specs you have double OD. 5th and 6th are both coming out of the trans at above 1:1 ratio. (Same as having a higher rear differential)
Not true at all. Regardless of any ratio in any rear end the physical size of the ring and pinion gears, brgs, etc are always the same.
  #21 (permalink)
Old 08-07-2007, 08:39 PM
mhadden's Avatar
Dealer : Toyota Of Merrillville
2007 Toyota Tundra 5.7 CrewMax
Last Online: 04-08-2008 02:03 PM
mhadden will become famous soon enough.
mhadden's Photo Albums
Except in the case of the Tundra where the 4.3 rear end is a 10.5" diameter gear and the 4.1 is a 9.5".
2008 Honda CR-V EX AWD
2008 Honda Civic LX
  #22 (permalink)
Old 08-07-2007, 10:13 PM
TRDSucker's Avatar
Dealer : Gene Messer Toyota
Last Online: 06-30-2009 10:05 PM
TRDSucker is on a distinguished road.
TRDSucker's Photo Albums
Originally Posted by litfuse View Post
I still think it is strange for toyota to make two individual ring and pinion ratios. I would imagine it would have been cheaper for toyota just to make all their axles with 4.30s. There has to be a reason why Toyota did the 4.10s, besides just gas mileage, because I don't believe there is any substantial difference between the 4.10s and the 4.30s. I would think if they were worried about gas mileage they would have thrown in some 3.73s.
IF you think that is a waste, then consider that GM has at least 4 ratios available in the 1500 ld. Ford at one time, had about six for the f-150, ranging from a 2.-- to 4.30 or something like that. I would have though that they would have spaced out the option a little more though. I like that the 4.30's make my 4.7 feel like it is on anabolics though.
07 Tundra DC TRD 4.7, THE Blue Streak
Top Gun Customz levelling kit
MagnaFlow true duals, XM ExpressRC
Tinted Winders, mostly shaved emblems
Kobalt toolbox, Silverstar bulbs
Removed charcoal filter,
pillar vinyl and gayass pinstripes
Coming attractions: Tires and stereo upgrades
Whats the best diff? silverTRD Engine & Drivetrain 27 04-17-2005 11:38 PM
*-The Racing Thread-* Eddie Off-Topic 200 01-15-2005 11:00 PM
