Closed Thread
LinkBack (5) Thread Tools Display Modes
  #61 (permalink)
Old 09-12-2007, 05:40 PM
POS71RS's Avatar
Dealer : Thousand Oaks Toyota
Last Online: 07-30-2009 08:29 AM
POS71RS is on a distinguished road.
POS71RS's Photo Albums
Default Re: DIY: How-To disable the seatbelt chime.
Well.. it appears that there's a time limit after which you are unable to edit a post or thread...
Cause I had the intention of adding a major warning to the original thread.
Best I can tell, there's a certain number of times that you can start up the truck with the seatbelt sensor bypassed. After this number of startups, you will be forced to remove the sensor and cycle the slider a few times to reset this.
My guess is somewhere around after 50-100 startups, the airbag will remain off regardless of weight on the passenger side seat. The only way to repair this is to either take the sensor back apart (which, by now, is super easy to do in seconds) and cycle the sensor with the ignition on, or replace the spring.
As I mentioned in the original post... my springs shot out to Pluto...(planet, gas?...whatever) and I've replaced with.... yes.. ball point springs. Took a few attempts at the right size pen though.
I'm currently battling the ignorant dealership to get the chime turned off. My driver's side is remaining un-sprung.
Sucks majorly... but Tundra = 1. Me=0
~ If you're still keeping it unsprung, you should be able to reset this by having the key-ignition on, pop the sensor off and slide the white plastic slider a few times and reassemble. Test it by sitting in the seat with ignition on for 20 seconds or so to ensure that the airbag light turns to ON.
Additionally, I found that the end of my cellphone charger fits PERFECTLY into the hole to disengage the sensor. No tools needed... which is GREAT... when your passenger sits and finds the airbag is OFF.
2007 DC 5.7 SR5 with black bench interior.
Smittybuilt nerfs, Polk audio speakers, and dirty.
  #62 (permalink)
Old 09-12-2007, 05:49 PM
POS71RS's Avatar
Default New post to Seatbelt Chime thread.. ALERT.
See this post I wrote a short bit ago:
No, I'm not happy. And yes, slightly embarrassed as well.. it sucks. But I'll take the egg-on-face over the alternatives. No need for I-told-you-so's.
Everything holds true.. but the 'benefit' is getting to be more of a PIA. (Pain In the... you know)
  #63 (permalink)
Old 09-12-2007, 06:08 PM
Dealer : Valdosta Toyota
Last Online: 04-06-2008 01:09 PM
jacs1017 is on a distinguished road.
jacs1017's Photo Albums
new to site. had tundras for 13 years. 7 yrs. T100 and 6 yrs. with 01' 4.7 tundra. never had 1 problem with toyota, i guess i've been lucky or maybe this truck is that great. also wife has sequioa, love this suv also, no problems with it. after reading info on seatbelt chime and how annoying it was to everyone, i got to thinking to myself, hell it's annoying to me also. so i decided to solve the problem. i came to work today and took measurements of the seatbelt and went to my computer and programmed it in, went to my haas (milling machine) cut one just like the one in my tundra.
took the part to my truck and put it in and drove down the road to see if there was going to be that annoying chime, all gone in about 1 hour of work. i know seatbelts are for reason, but i ride motorcycles and i believe this should not a law for adults. huh i don't no anymore. just want to know is it against the law to see if anyone else wants them. they just simply knap out it u need to use your seatbelts. any comment are welcome. plus, thanks for all the great info. on this form.
jeff
07 cm loaded
  #64 (permalink)
Old 09-12-2007, 06:16 PM
Dealer : Hilltop Toyota
2007 Toyota Tundra,
2007 Toyota Camry Wife's Ride Loaded!
Last Online: 09-27-2009 02:04 PM
HP384mott is on a distinguished road.
HP384mott's Photo Albums
Default Re: New post to Seatbelt Chime thread.. ALERT.
Check my previous post with some pics. If you disable the chime itself, your good to go. No passenger airbag on/off problems, no key chime, and everything functions perfectly. My pics may have made the mod look a little difficult. But, I can assure you it was not a big deal. A couple of snap off panels, a few wiring connectors to unplug, unplugging the dash cover, pulling out the dash gauge assembly and your there. Reverse assemble and that D*mn chime is gone forever!
07 CM Ltd., Red Salsa, TRD, Tan Leather, factory liner, JBL w/12 spkrs., Moon Rf., Alarm Sys., Tow Pckg., Back-up Cam., Retrac Mirrors, More goodies to come!
  #65 (permalink)
Old 09-12-2007, 06:18 PM
2007 Toyota Tundra,
Forgot to mention. I also lost my first springs when I tried that route and used some out of a fountain pen. They were the same length and diameter. Sorry, I don't know what brand of pen I used since I pitched them in the trash.
  #66 (permalink)
Old 09-12-2007, 07:35 PM
mccolors's Avatar
Dealer : Thompson Toyota
Last Online: 11-11-2009 07:07 AM
Images: 3
mccolors is on a distinguished road.
mccolors's Photo Albums
Default Re: The EASY DIY way to kill the seat belt chime.
Originally Posted by mccolors View Post
Please read the post before disconnecting, this mod also disconnects the airbags! * Disconnecting seat belt chime also disconnects airbags!! *
Please leave the springs alone for your (your family's) safety! I hate to say it but................I TOLD YOU SO!!!!! It is just not worth it to me to know that my driver or pass. airbag will not go off when needed. This is one of the best features the tundra has; front and curtain side airbags. I have read other mods for this, some disconnect chips in dash, some have stuffed cards into the clips, for what it's worth this chime bothered the hell out of me, after finding out this could jeperdise me or my family's safety I have learned to live with it, and wear my seat belt more. The chime does go off in time if you take the belt off, and at least I know my airbags will work if needed!
5.7 DC 4x4,TRD off road, bucket seats, 6 disc, sat, TRD shifter, 2.5"front/1.5"rear lift, fender flares, chrome tube steps, tint, front rain guards, bed liner w/deck rail system, color matched grill surround, partialy debadged, black TRD decals, BFG 305/65/18's on TRD rims, Black headlight mod. (sorry, haven't changed pic's yet)
  #67 (permalink)
Old 09-13-2007, 10:15 PM
Dealer : Teton Toyota
Last Online: 11-22-2008 08:12 PM
bigolsen is on a distinguished road.
bigolsen's Photo Albums
I only removed my drivers side spring. Does this mean my airbag will not work now? I havn't had any lights come on saying no airbag. Does this only apply to the pass side??
'07 CM SR5 TRD, 5.7, Warpspeed dual catback,305 BFG's,AFE filter,leveled,free mods,etc.
'07 GMC ACADIA AWD (kid mover)
'97 ECLIPSE GST w/lots of mods.
  #68 (permalink)
Old 09-14-2007, 04:10 PM
lotus4s's Avatar
Dealer : Courtesy Toyota Scion of Orlando
Last Online: 07-26-2009 10:41 PM
lotus4s is on a distinguished road.
lotus4s's Photo Albums
The driver's side bag will activate whether the seat belt is fastened or not so it shouldn't make any difference.
What's screwing up the passenger side is the fact that the seatbelt sensor works in conjunction with the weight sensor which can turn the airbag off if there's no one in the seat or not enough weight such as a child.
07 Black DC Ltd. 5.7, 4x4
  #69 (permalink)
Old 10-01-2007, 06:05 PM
Dealer : Billion Motors
Last Online: 10-22-2007 04:32 PM
lizardleft53 is on a distinguished road.
lizardleft53's Photo Albums
Originally Posted by xerces View Post
I've put mine back in too. Just not worth knowing if the Air Bag Off light will come on at the wrong moment. For now, I'll just live with the dinging.
What is the trick to putting the spring back inside. I tried for about 5 minutes with needlenose pliers to no avail. Any suggestions???
  #70 (permalink)
Old 10-01-2007, 08:10 PM
xerces's Avatar
Dealer : Autoway Toyota
Last Online: 04-25-2008 08:10 PM
xerces is on a distinguished road.
xerces's Photo Albums
Yeah, you have to lightly pry the sliding clip off. Once off, insert one end of the spring into the clip and the other onto the "fixed" stop and then slow slide the clip back into place.
2007 Salsa Red Tundra DC 5.7L SR5 w/TRD package
2005 Suzuki GSX-R1000
2006 Kawasaki KX450F
  #71 (permalink)
Old 10-01-2007, 10:17 PM
Dealer : Champion Toyota Scion Gulf Freeway
Last Online: 07-15-2009 05:48 PM
TundraTimHouston is on a distinguished road.
TundraTimHouston's Photo Albums
I posted a fix for chime/buzzer... Has anyone else done it?
Here is the link to my post...
http://www.tundrasolutions.com/forum...-disabled-now/
Good luck to you...
  #72 (permalink)
Old 10-01-2007, 10:35 PM
Thanks, I was afraid that the plastic piece might break, but it was fairly flexible. Now I don't have to worry about the airbag.
I will be making a trip to the dealer to get that damn passenger seat chime disabled. The flashing light is enough to remind me to make certain that my kids are buckled in if they are with me. I certainly don't need the chime going off time and time again when I have a business associate in the front seat who prefers not to wear a seat belt.
There must be some sort of sequence to disable the chime without going to the dealer. If anyone knows what this might be, please post it.
  #73 (permalink)
Old 10-10-2007, 10:51 PM
Dealer : Phil Wright Toyota
Last Online: 11-14-2009 06:52 PM
basswakr is on a distinguished road.
basswakr's Photo Albums
i took the easy route.
traced the male seat belt part on a piece of plastic the thickness of the buckle , cut it out so it doesn't stick out of the female part. when u press the release be ready because it shoots the piece out. thank goodness no more chimes.
  #74 (permalink)
Old 10-18-2007, 12:49 PM
Dealer : Ira Toyota of Manchester
2007 Toyota Tundra,
Last Online: Today 08:07 AM
2uprup is on a distinguished road.
2uprup's Photo Albums
I just ride with the passenger side seatbelt always buckled even if there is no one sitting in the seat. If some one wants to use the seat belt they can just unbuckle it before they get in the truck and then buckle themselves in. This way if I put anything heavy on the seat, the seatbeat is already buckled.
  #75 (permalink)
Old 10-22-2007, 05:56 PM
Dealer : Performance Toyota Of Lincoln
Last Online: 08-01-2008 02:27 PM
HuntinHabit is on a distinguished road.
HuntinHabit's Photo Albums
I had removed the springs to get rid of the chimes, but after a couple weeks I noticed the airbag was off when my kids or wife were in the passenger seat. I came back and read through the rest of this thread and I see that this is a problem.
I just don't feel comfortable with it. I put the springs back in and everything is back to normal. As much as I hate the chimes at certain times, it certainly beats having airbag problems. I realize I could probably just put the passenger side back in and leave the drivers side out, but it's just one of those things that would always bother me, so they are in for good.
Closed Thread
LinkBack to this Thread: http://www.tundrasolutions.com/forums/tundra/107489-diy-how-to-disable-seatbelt-chime/
Posted By For Type Date
disable Elantra seat belt chime - Zuula Search This thread Refback 09-18-2009 09:14 AM
DIY (Do-It-Yourself) & User Knowledgebase - Tundra Geeks :: The Toyota Tundra Enthusiast Forum This thread Refback 07-15-2009 11:41 PM
DIY (Do-It-Yourself) & User Knowledgebase - IBTO Official Forums This thread Refback 05-16-2009 07:07 PM
Disabiling seat belt buzzer - Page 3 - Toyota Forums :: Toyota Nation This thread Refback 02-02-2009 06:42 PM
Tundra the next expedition vehicle? - Page 3 - Expedition Portal Forums This thread Refback 01-04-2008 02:44 AM
Seatbelt Chime thumph Audio & Stereo 1 07-26-2007 09:09 PM
Passenger seatbelt chime removal (software) TRDTROY Tundra 8 07-25-2007 06:31 PM
Seatbelt warning beep disable.... Tundraengineer RAV4 7 03-26-2007 12:34 PM
