Closed Thread
LinkBack (5) Thread Tools Display Modes
  5 links from elsewhere to this Post. Click to view. #1 (permalink)
Old 08-09-2007, 09:58 PM
POS71RS's Avatar
Dealer : Thousand Oaks Toyota
Last Online: 07-30-2009 08:29 AM
POS71RS is on a distinguished road.
POS71RS's Photo Albums
Default DIY: How-To disable the seatbelt chime.
WARNING...
There is an issue with the passenger side airbag NOT functioning after this mod.
Please read this entire thread before you decide to attempt this modification.
TS staff
NOTICE:
Toyota Dealerships can toggle the chime for the passenger seatbelt ON/OFF
as seen on page 2 here electronic_features.pdf.
We advise you to ask a Toyota Dealer to manually disable this safety feature.
If they refuse to do so, read on
DISCLAIMER:
TundraSolutions.com and the owners of TundraSolutions are not responsible for any modification or misuse of vehicle restraint systems. Modification is solely the owner/modifier's responsibility of liability. Modification is intended as an off-road modification and not for street use. It is your own responsibility to yourself and your loved ones to protect yourself in case of accident.
With that said, I'd like to point out that I contacted two dealerships; Thousand Oaks Toyota, and Oxnard Toyota, and both dealers informed me that this modification was illegal or impossible to turn off the passenger side seat belt chime. I argued with both dealers' service techs that removing the passenger side chime is legal, and Toyota outlines the way to accomplish this.
Simply put... both dealers were total retards. And it was ironic, cause I had my sheriffs uniforms hanging in the truck as the technician argued that it was illegal to turn off the passenger side chime, and I told him the reason was for my duty bag setting off the chime in the passenger seat...
Anyway, enough ranting, on to the modification:
This was FAR EASIER than I anticipated.
I owe Mainliner thanks for his detailed explanation and Alaskacub for the reminder that this is easy. I'm not taking credit for this, just making it easier and condensed to perform yourselves.
Here's a link to the original thread and higher-quality pics:
http://www.toyotatundraforum.com/gen...skyhammer.html
1.) Locate inside of seatbelt buckle (portion facing occupant). There is a small hole, and a tab. Push in the tab with a pick or small screwdriver. This will pop the sensor partially from the buckle.
The pick point is pointing out the tab to be pushed:
Grab onto the black plastic sensor and pull it down out of the buckle housing:
It's a long one, so pull it straight down and out of the buckle:
Flipping the sensor over, you'll see the infamous spring that needs to be ix-nayed. I'm using a pick to pull the spring up over the black stub:
Yes... the spring launched into orbit. If you want to keep it.. cover with your hand, etc. I didn't really care. I'll have this truck a long time.
The next picture is the same thing, minus the projectile-spring. The pick is merely pointing at the missing spring. The white plastic clasp will now stay down due to gravity regardless of if there's a seatbelt buckled or not. Keep your seat belt buckled to save lives!
VERY IMPORTANT UPDATE!!! ADDITION TO PROCEDURE FOLLOWING.
There was an issue with the passenger side airbag not functioning after this mod. (I know, I know.. bit of an oversight for sure.) Thing is, it works on some folks' trucks, not on others. I believe the reason to be that the slider on the clip is not staying down as it properly should have with 'gravity'
Now, I will show you what I did to correct this on my truck.
It's again VERY simple, but I think imperative to proper airbag operation.
I duplicated the no-airbag issue on my Tundra, and conducted various 'tests' to make sure this works, no fail on MY vehicle so far.
Still with the sensor upside down, looking at the circuit board side of it, I merely placed a small piece of tape to inside the sensor, in the 'track' or path that the slider would slide up and down in.
Here's another grainy picture of what I'm referring to:
The principle in the original attempt was for gravity to keep the sensor down. After inspecting my buckle, I believed the issue to be that improper engagement of the sensor back into the buckle to be the problem. Inserting and pulling out to re-insert can leave the slider in the sensor to hang up inside, and nullify the process we did here. To be honest, I'm no expert by ANY means, and this is the best I can come up with.
Why tape?.. Cause it's cheap and easy to reverse! If this doesn't work, then try another method, or put the damn spring back in. But I don't want to make any mods to this system I can't undo later if need or desire be.
Please by all means, ensure the passenger side airbag is ON while there is a passenger (over 45lbs) and buckled up.
Now, reassembly is the reverse procedure.
See the first three pictures for reference. You'll be carefully sliding the clip/sensor assembly back into the buckle.
Be careful pushing it back up into the buckle. I had to make several attempts to get it just right-straight in there. It will require a little bit of a push, but it will 'snap' right in when done properly.
After the chimes are removed, and being that this whole job can take a beginner a few minutes tops, you wont need this anymore:
Old 08-09-2007, 10:04 PM
POS71RS's Avatar
Default Re: The EASY DIY way to kill the seatbelt chime.
P.S. I always wear my seatbelt, and my passengers are required to.
My personal reason for doing this to my seatbelts (passenger and driver) is only for temporary reasons, getting the mail, etc. And the passenger side for my duty bag, etc.
There is no reason to flame or rant about seatbelt wearing.. to each their own. This is merely for instruction.... and so that eleventy-billion people will stop asking about seatbelt chimes...
Hopefully this will be tolerable, and stickied for use.
Old 08-09-2007, 10:11 PM
Dealer : Toyota San Diego
Last Online: 05-19-2009 01:22 AM
ToyCrazy is on a distinguished road.
ToyCrazy's Photo Albums
Thanks for the info! My girlfriend calls the seatbelt chime my theme song. Because every voice mail she gets from me has it playing in the background. Thanks again.
Old 08-10-2007, 12:09 AM
Joe1L1's Avatar
Dealer : Muller Toyota
Last Online: 02-05-2008 02:06 PM
Joe1L1 is on a distinguished road.
Joe1L1's Photo Albums
Thank you very much for this very easy consolidated version. The other ones I had read told me to take the entire seat out and disconnect the battery. This one is soo simple and perfect. I did mine in under 3 minutes. There is no reason to pull out any wrenches or disconnect any batteries! This should be made into a sticky!
2007 Black Tundra CrewMax Limited , TRD exhaust , Graphite Leather, NAV, 20' wheels, Fully Tinted, Craftec Tonneau Cover
Old 08-10-2007, 12:29 AM
The Phoenix's Avatar
Moderator
Last Online: 11-06-2009 02:51 PM
Images: 2
The Phoenix's Photo Albums
Lookin' pretty good.
Old 08-10-2007, 12:41 AM
Dealer : Toyota Carlsbad
2007 Toyota Tundra Limited Crew Max 4x4,
2004 Toyota 4Runner Sport 4.7 V8 AWD,
2003 Toyota Land Cruiser
Last Online: 12-20-2007 12:18 PM
doanlaw is on a distinguished road.
doanlaw's Photo Albums
the most useful piece of info to date from this site, awesome work!!!!!!!!!
2007 Tundra Silver CM 4x4 5.7 Limited, Front: Total Chaos/Donahoe Racing Coilovers, Rear: Deaver Springs/Total Chaos Shackles, Fox Racing Rear Shocks, 35" BFG AT KO's...and a few other misc things.
Old 08-10-2007, 12:42 AM
OTR's Avatar
OTR OTR is offline
Dealer : Ron Tonkin Toyota
Last Online: 10-10-2009 12:42 AM
Images: 6
OTR will become famous soon enough.
OTR's Photo Albums
I take some flaming. Will this work for the drivers seatbelt as well
Old 08-10-2007, 12:52 AM
POS71RS's Avatar
Actually, half my pics are of the driver's side, as I realized halfway through that I cant download pics off my digital camera. Had to re-do it with my camera phone.
I did both for the reasons I mentioned at the end of the original post.
Old 08-10-2007, 04:29 AM
Pbbobkanobi's Avatar
Dealer : Toyota Scion of El Cajon
Last Online: 07-25-2009 03:07 AM
Pbbobkanobi is on a distinguished road.
Pbbobkanobi's Photo Albums
A seatbelt saved my life and i have the scar to prove it. That being typed.....Why would anyone need a buzzer / beeper to tell them to put one on? Darwin theory sounds pretty good in this case. Down with the chime! Up with the smart folks.
Old 08-10-2007, 05:35 AM
R0CKETMAN's Avatar
Last Online: 01-03-2008 03:32 PM
R0CKETMAN is on a distinguished road.
R0CKETMAN's Photo Albums
great post. thanks for making it clear
edit: done, 5 min cause I couldn't get it lined up for re-entry the first few tries.
Old 08-10-2007, 06:27 AM
seadragon's Avatar
Dealer : Milton Toyota
2006 Toyota RAV4 Limited,
2007 Toyota Tundra 5.7L DC 4x4 SR5 TRD
Last Online: Today 06:42 AM
seadragon will become famous soon enough. seadragon will become famous soon enough.
seadragon's Photo Albums
Good post!
I know my question MAY seem like a flame, but it is NOT intended as such...
I've heard that our vehicles have "blackboxes" now and tracks information about speed, brake on/off etc. Does doing this mod make the blackbox think the seatbelts are not fastened? Does the dash light flash even if you're buckled up? (I'm assuming not)
Maybe I don't quite understand how this mod works exactly.
2007 Tundra 4x4 5.7L SR5 TRD BLK
Old 08-10-2007, 10:18 AM
Moderator
Images: 2
Originally Posted by seadragon View Post
Good post!
I would tend to think that since you are removing the sensor that makes that light blink, the computer assumes the seat belt is on, if there is a "black box."
I have my driver side seatbelt light disabled on my 06. I didn't do any of this fancy work though, I just snipped the light wire.
Old 08-10-2007, 10:27 AM
Smilodon's Avatar
Dealer : Mike Erdman Toyota Scion
2007 Toyota Tundra Ltd,2WD,Slate/RdRock
Last Online: 10-23-2009 12:51 PM
Smilodon is on a distinguished road.
Smilodon's Photo Albums
I went to my dealer with the "programmable electronics" sheet provided here with the correct passenger buzzer setting highlighted. They changed it no questions asked.
I can easily have it changed back if I sell the truck, or some such...
That said though, good work!
Old 08-10-2007, 10:51 AM
Dealer : Baierl Toyota
2007 Toyota Tundra Silver Sky5.7 DC TRD
Last Online: 09-07-2009 05:33 PM
tacoma2tundra is on a distinguished road.
tacoma2tundra's Photo Albums
Where would someone find the programmable electronics manual?
Old 08-10-2007, 11:57 AM
Dealer : Right Toyota
2007 Toyota Highlander
Last Online: 03-17-2009 04:02 PM
arizBuckeye is on a distinguished road.
arizBuckeye's Photo Albums
Awesome post!!! I can't wait to get home today and do this...
2007 Tundra 5.7 SR5 CrewMax, 4x4, TRD, Nautical Blue
Closed Thread
LinkBack to this Thread: http://www.tundrasolutions.com/forums/tundra/107489-diy-how-to-disable-seatbelt-chime/
Posted By For Type Date
disable Elantra seat belt chime - Zuula Search This thread Refback 09-18-2009 09:14 AM
DIY (Do-It-Yourself) & User Knowledgebase - Tundra Geeks :: The Toyota Tundra Enthusiast Forum This thread Refback 07-15-2009 11:41 PM
DIY (Do-It-Yourself) & User Knowledgebase - IBTO Official Forums This thread Refback 05-16-2009 07:07 PM
Disabiling seat belt buzzer - Page 3 - Toyota Forums :: Toyota Nation This thread Refback 02-02-2009 06:42 PM
Tundra the next expedition vehicle? - Page 3 - Expedition Portal Forums This thread Refback 01-04-2008 02:44 AM
Seatbelt Chime thumph Audio & Stereo 1 07-26-2007 09:09 PM
Passenger seatbelt chime removal (software) TRDTROY Tundra 8 07-25-2007 06:31 PM
Seatbelt warning beep disable.... Tundraengineer RAV4 7 03-26-2007 12:34 PM
