Maintenance Schedule
+ Reply to Thread
Results 1 to 12 of 12
Thread: Maintenance Schedule
  1. #1
    Join Date
    Jun 2006
    Location
    Wichita, KS
    Posts
    114
    Liked
    0 times
    Thanks
    0
    Rep Power
    9
    Default Maintenance Schedule
    Ok, this is probably a dumb question
    Where can i find a maintenance schedule?
    I did look through the papers that came with the truck and i couldnt find anything. I take that back...there was a small blue book that had some stuff in it. But it really wasnt what i was looking for. I think the first maintenance wasnt scheduled until 5,000 miles and that didnt seem right. My dealer mentioned about getting the oil changed after about 1,000 miles. So i was assuming there was some other stuff that needed to be done. Any help is greatly appreciated
    2014 Tundra Limited Crewmax, 5.7L, 4wd, Attitude Black Metallic, JBL Audio System
  2. Remove Advertisements
    Toyota Tundra Forum
    Advertisements
  3. #2
    Join Date
    Jul 2007
    Location
    albuquerque, nm
    Posts
    49
    Liked
    0 times
    Thanks
    0
    Rep Power
    8
    Default Re: Maintenance Schedule
    I found this on the Toyota website under the small tab "owners". Hope it helps.
    Toyota Parts and Service
  4. #3
    Veteran Member shadyskins's Avatar
    Join Date
    Jun 2007
    Location
    Philly
    Posts
    1,701
    Liked
    3 times
    Thanks
    0
    Images
    14
    Rep Power
    29
    First oil change is 5,000 miles..... first anything is 5,000 miles
    2007 CrewMax SR5 4x4 5.7 Nautical Blue
    My Pictures
    TRD Rear Sway Bar, Pioneer FH-P8000BT w/ Sirius, Carriage Works Black Replacement Grille + Top Insert, Color Matched Sequoia Door Handles, Bench Seat, Dual Headrest DVD, back up camera w/monitor, Nüvi, Line-x, TruXedo Lo Pro QT, Tekonsha P3, debadged, enjoyed since 7/20/2007
    Towing - 35 Foot 2011 KZ Spree 321BHS
  5. #4
    jkd
    jkd is offline
    Join Date
    Jun 2007
    Location
    Cody, WY
    Posts
    641
    Liked
    0 times
    Thanks
    0
    Rep Power
    8
    Mine said about 2500 for first oil change and it would be free. Seems like anywhere from 1000 to 2500 would be OK and a good idea for a brand new engine. They also said they more or less go over it, check for any loose undercarriage bolts, etc.
  6. #5
    Join Date
    Jun 2007
    Location
    Philly
    Posts
    1,701
    Liked
    3 times
    Thanks
    0
    Images
    14
    Rep Power
    29
    besides.... your maintenance light should illuminate when it is time
    My Pictures
  7. #6
    Join Date
    Jun 2006
    Location
    Wichita, KS
    Posts
    114
    Liked
    0 times
    Thanks
    0
    Rep Power
    9
    Thread Starter
    Maybe its me...but it seems like 5,000 miles is a long time to wait for the first oil change on a brand new engine.
    So did most of you wait til 5,000 miles to get your first oil change?
  8. #7
    Join Date
    Jun 2007
    Location
    Philly
    Posts
    1,701
    Liked
    3 times
    Thanks
    0
    Images
    14
    Rep Power
    29
    I'm currently @ 1,300 miles. I'm leaving for southern Georgia on Thursday, about 860 miles one way. I will there for a week..... probably doing alot of driving while there..... then returning 860 miles. Which will put me between 4-5K when I return to PA. My service manager suggested that I wait to get the oil change until I return from my trip. I'm by no means an expert.... but from what I've heard, there are benefits to keeping the factory oil in for the initial 5K.
    My Pictures
  9. #8
    Rookie glassfinish's Avatar
    Join Date
    May 2006
    Location
    Davie
    Posts
    14
    Liked
    0 times
    Thanks
    0
    Rep Power
    0
    I don't believe there's a benefit to leaving the factory oil till 5000 miles other than a monetary savings. I changed my oil with the first 1000 miles to synthetic and will change it thereafter every 5000 miles. The only reason I changed it early (ie 1000 miles) was simply because I always change my oils post break inn period!
  10. #9
    Junior Member jgonzales's Avatar
    Join Date
    Jan 2007
    Location
    MS
    Age
    31
    Posts
    160
    Liked
    0 times
    Thanks
    0
    Images
    1
    Rep Power
    13
    This is a topic where everyone is going to have a different opinion... that "small blue book that had some stuff in it" is your "official" scheduled maintenance guide. Yes, it starts at 5k miles. I'm pretty sure all the new Toyota vehicles start at 5k now. Changing before 5k definitely will not hurt it, but if Toyota says 5,000 miles why not follow their advice? If something happens to your engine they're not going to say that it's not covered under warranty because you only changed it every 5k instead of 3k or 1.5k or whatever...
    Joe
    2009 Tundra D-Cab TRD Sport - Red
    MBRP Exhaust, TRD Sway Bar, TRD CAI, Bilstein 5100's, 275/60-20 Zeon LTZ's
    BakFlip G2, 6-Step N-Fab's, UnderCover SwingCase, Hella LED's
    2008 Tundra SR5 CM - Black *SOLD
    2006 4Runner V8 4WD - White *SOLD
  11. #10
    Join Date
    May 2007
    Location
    Warner Robins, Ga
    Posts
    6
    Liked
    0 times
    Thanks
    0
    Rep Power
    0
    Here is a copy of one I found and use for my Tundra. Use it iof you like....
    Attached Files Attached Files
  12. #11
    Join Date
    May 2007
    Location
    Gardendale, AL
    Posts
    83
    Liked
    0 times
    Thanks
    0
    Rep Power
    8
    Here is the copy of Scheduled Maintenance Guide from Toyota:
    2007 Toyota Tundra 5.7L RCSB (White)
    Mods: TundraCAI - Cold Air Intake
    Goliath Rims
  13. #12
    Join Date
    Jun 2006
    Location
    Wichita, KS
    Posts
    114
    Liked
    0 times
    Thanks
    0
    Rep Power
    9
    Thread Starter
    Quote Originally Posted by jgonzales View Post
    Good point.
    I did talk to my sister (she have a 2006 Corolla, bought new) and the first oil change on that was at 5,000 miles. So i think i'll just wait until it gets closer to 5,000 and do it then.
    Thanks for all the input.
Quick Reply Quick Reply
Register Now
Log-in
Human Verification
  1. Maintenance Schedule
    By Pavilion in forum Avalon
    Last Post: 01-28-2007, 07:33 PM
  2. Schedule Maintenance : Tightening chassis bolts?
    By TowingCivic in forum Towing
    Last Post: 11-04-2006, 01:03 AM
  3. Maintenance Schedule 1999 Lexus LX470
    By KDTundra in forum Lexus
    Last Post: 10-23-2006, 09:04 AM
  4. 2000 Tundra Maintenance Schedule
    By Rapid Dog in forum Off-Topic
    Last Post: 09-24-2004, 09:55 PM
  5. 2002 maintenance schedule
    By rtm925 in forum Engine, Intake, Exhaust, Induction
    Last Post: 10-27-2003, 08:47 PM
Posting Permissions
  • You may post new threads
  • You may post replies
  • You may not edit your posts
