  #31 (permalink)
Old 08-27-2007, 02:15 AM
Dealer : Findlay Toyota Scion
Last Online: 11-22-2009 12:19 AM
vegasheat is on a distinguished road.
vegasheat's Photo Albums
Smile Re: Adding Acetone?
Originally Posted by ishino View Post
I've came across some readings about adding acetone to gasoline to increase MPG. Anyone else come across this or have any thoughts good or bad about trying this. Thinking about trying it out on one of our Government rigs first to see.
Double Your Gas Mileage! 2X Video
Directory:Acetone as a Fuel Additive - PESWiki
I tried that last year with my old Toyota truck with 240,000 miles on it back then. I didn't noticed a change at all. Maybe because of the miles it has already. Maybe it will do well with the newer trucks. if you try it..post your results if you don't mind.
  #32 (permalink)
Old 08-27-2007, 02:34 AM
TNK TNK is offline
Banned
Dealer : Team Toyota
Last Online: 09-03-2007 10:36 AM
TNK is on a distinguished road.
TNK's Photo Albums
Default Re: Adding Acetone?
Nothing wrong with thinking outside the box,making sure you understand outside the box is a different animal.
Without a UCL added your most likely to have an issue.
Smoking the primary cats wouldnt be out of the question,but the least of my worries if you asked me
Just find acouple gallons of 110* and add them to your ¼ full tank of fuel.
You'll know within 2 miles if the accetone would have been a good idea or not.
Originally Posted by ninrocket View Post
Needs to be Pure Acetone...99%
This can be had at Walgreens and sometimes Home Depot in gallon cans.
I will be more than happy to do the testing on my '07 DC...after I get my first oil change at 3K and have a reference.
I'll post my results in the TS forum. I don't expect great results because I believe the engines do a pretty good job of burning the fuel efficiently. Might see a little more power...and that would be good on the low side.
Gotta' test it to find out though.
Sometimes you gotta think outside the box...right TNK?
  #33 (permalink)
Old 08-27-2007, 09:28 AM
Tundradrenalin's Avatar
Assistant Administrator
Last Online: Yesterday 11:12 PM
Images: 205
Tundradrenalin is part of the TundraSolutions family. Tundradrenalin is part of the TundraSolutions family. Tundradrenalin is part of the TundraSolutions family. Tundradrenalin is part of the TundraSolutions family. Tundradrenalin is part of the TundraSolutions family. Tundradrenalin is part of the TundraSolutions family. Tundradrenalin is part of the TundraSolutions family. Tundradrenalin is part of the TundraSolutions family. Tundradrenalin is part of the TundraSolutions family. Tundradrenalin is part of the TundraSolutions family. Tundradrenalin is part of the TundraSolutions family.
You're going to do a fuel system experiment on your new Tundra from something you read off Google? ok...
Try it on your lawn mower first. If you finish your mowing faster than your neighbor Jim, the Mythbusters would applaude you.
Here's some science for your reading. Flashpoints of various flammable liquids:
-45C, ether
-43C, gasoline (petrol)
-18C, acetone
22C, ethyl alcohol
38-72C, kerosene
62C, diesel
If you don't understand what a flashpoint is, wiki it or go to sigma-aldrich.com and read the MSDS on every CAS# you can find on the bottle. They'll give you a free MSDS copy for anything they offer. Safety first!
Under the Hood: AMSOIL Synthetic Lubes all around, AMSOIL Ea Air Filter, Doug Thorley Headers, Magnaflow Exhaust, Semi-RAMair airbox mod
Suspension & Tires: 285/75-16 BFG T/A'ko, Fabtech Coils, 1.5" Wheeler's blocks, Toytec Diff Drop, 1.25" Spidertrax [front], 1.5" Goeske Wheel Adapters [rear]
Handling: TC Poly Steering Rack Bushings, Downey HD End Links, Wheeler's Anti-Sway Kit, Hellwig 7700 Swaybar, Timbren Rear SES
Electrical: URD MAF Sensor Calibrator, Superlift Truspeed Speed Sensor Re-Calibrator, ScangaugeII, Full LED Conversion
Stereo: Alpine CDA-9886, Alpine & Phoenix Gold amps, Q-Logic box w/RF subs, eDead
Cosmetic: Line-X Bedliner, Custom N-Fab Steps, Rear Diff Breather Extension, F103N Fumoto Oil Drain Valve, Debadged (partially), Bell Truck Trunk, Access Vanish Tonneau
  #34 (permalink)
Old 08-27-2007, 12:01 PM
ninrocket's Avatar
Banned
Dealer : Woodhaven Lexus Toyota
Last Online: 09-03-2007 11:13 AM
ninrocket is on a distinguished road.
Send a message via ICQ to ninrocket ninrocket's Photo Albums
-45C, ether
-18C, acetone
22C, ethyl alcohol
38-72C, kerosene
62C, diesel
Thanks for the warning. I work in the chemical industry and am well aware of flashpoint. I design equipment to recycle Class I Div 1 chemicals everyday...it doesn't get any tougher than that as far as electrical/explosion safety goes.
I added 7 oz's to a tankful of Texaco 87 Octane today. I will be logging the data over the next month and will report my findings to the TS gang. I decided that since I still have over 1,000 miles before my first oil change I can still establish a baseline reference from my other fuel logs and should get some good information.
I would never suggest someone try something without doing research first. I have done plenty and I personally feel the risks are insignificant. The gains are yet to be seen since I will be the first documented tester on the 5.7 Tundra.
Wish me luck!
  #35 (permalink)
Old 08-27-2007, 03:33 PM
TNK TNK is offline
Banned
TNK's Photo Albums
Naaah we'll just pitch you a cookie now and be done with it
  #36 (permalink)
Old 08-27-2007, 04:42 PM
ninrocket's Avatar
Banned
Me like Cookie!!
Hey TNK...haven't any luck with 50 shot or more on the 5.7? I know you were working on dumps...wondering what else ya'll have done lately...
  #37 (permalink)
Old 08-27-2007, 05:40 PM
TNK TNK is offline
Banned
TNK's Photo Albums
Got one TB ported and finally got the truck to accept the change(sounds like a moose horn)
Abit of help from DEEP South Texas pointed to the solution They rumored a Full ECM platform(simular to the GM LS-1 Edit) is in the works sadly the bird ran out of chirp shortly after that
Thought about welding the spider gears up ?
Got another warning from the local law dogs on the dumps
We'll eventually get one built and disclose the fruits of our trials and tribulations from the "BARN" or 1000 Posts which ever comes first
Me like Cookie!!
  #38 (permalink)
Old 08-27-2007, 05:58 PM
Tackz's Avatar
Dealer : Frontier Toyota
Last Online: Today 03:44 AM
Tackz is on a distinguished road.
Tackz's Photo Albums
Keep in mind that Acetone is a SOLVENT and any & all rubber/plastic hoses/parts that it travels through and/or touches will be subject to damage or being dissloved. In a race application where the engine is being torn down on regular basis it may be worth it, but I would NEVER put it in a daily driven vehicle.
Black '07 Tundra Double Cab 5.7 L 4x2 SR5 TRD , Line-X, N-FAB Steps
-SOLD-
Black '07 Tacoma Access Cab 4.0L 4x4 SR5 TRD
  #39 (permalink)
Old 08-27-2007, 07:18 PM
ninrocket's Avatar
Banned
If the Iphone can be hacked then I believe the Tundra can as well. Must be coded in Japanese That's why it's taking a little longer.
  #40 (permalink)
Old 08-27-2007, 07:26 PM
ninrocket's Avatar
Banned
I fill the tank half way...dump the acetone in...and continue to fill it to the top.
I'm adding 7oz's to the tank so that's about 475:1 ratio. You have to get below 150:1 to see minimal negative effects such as minor swelling of certain rubbers(of which probably aren't in this fuel system anyway)...over the long term. 475:1 rate should have no effect...other than better combustion.
I will add one other note. I added the acetone, finished fueling and went inside to talk to a friend for a few minutes....truck was running. I came back out and the truck was dead..................so I thought. I open the door up and notice that the engine is running....VERY QUIETLY.
That can be bad or good depending on how you look at it. Since the purpose of my test is to increase MPG and Power...I won't worry about the quietness for now.
See ya'!
  #41 (permalink)
Old 08-27-2007, 07:33 PM
Jay_dash's Avatar
Dealer : Toyota Scion of San Bernardino
Last Online: 08-10-2008 06:15 PM
Jay_dash is on a distinguished road.
Jay_dash's Photo Albums
Originally Posted by slackjaw07 View Post
Acetone has been used for many years by women and Boy George to remove their nail polish. It does not melt skin under normal use but I sure wouldn't pour any of it in my gas tank.
Lol... I agree, don't do it.
  #42 (permalink)
Old 08-27-2007, 07:58 PM
TNK TNK is offline
Banned
TNK's Photo Albums
Just for my piece of mind would you please put some type of UCL in there with it ? Marvel,Lucas . . . . . .
  #43 (permalink)
Old 08-28-2007, 08:57 AM
ninrocket's Avatar
Banned
Initial report. Truck is definitly quieter. The low end torque(under 3K) is through the roof! It might even be considered annoying by people that don't like getting the old neck snapped. If I barely touch the accelerator the "dog hunts" as TNK would put it.
MPG was lower for about 20 miles with cruise running 70. I think the computer was making adjustments. Today I averaged 21.8 running 70 with S6 and VSC off in cruise.
I am going to run 3 tank fulls at 3oz per 10 gallons, 3 @ 2oz, 3@1oz and record the MPG and overall feel of the truck. Between the acetone quantity changes I will run straight gas with no acetone.
All tests will use Texaco 87 from the same gas station.
Once I figure out the best % I will experiment with different gasoline brands...Chevron, BP, Amoco, etc....
Later!
  #44 (permalink)
Old 08-28-2007, 09:44 AM
Dealer : Brent Brown Toyota
Last Online: 03-29-2009 06:50 PM
b.e.wilson is on a distinguished road.
b.e.wilson's Photo Albums
So, acetone is a solvent.
So are toluene (up to 35%), MTBE (an ether, 7.5%, up to 18%), the benzenes (monocyclic aromatics, up to 13%), a host of alkanes (almost all isomers from C5 to C12), and ethanol (up to 10%), all components of gasoline.
Every component of gasoline but one (the polycyclic aromatics, up to maybe 2%) are fantastic solvents for almost all non-polymerized compounds lacking a dipole moment. Water is one of the few compounds they don't dissolve (but if MTBE or ethanol are present, gasoline will solvate a small amount of water).
So why doesn't every fuel line and seal dissolve and crumble under use? They are designed to withstand solvents! Solvents are, in fact, the only thing that goes into your gas tank.
Knowing the properties of the rubbers and plastics used, and the properties of the gasoline compounds involved, I'd frankly be astounded if the manufacturers managed to find a polymer that withstood all the compounds present in gasoline but was susceptible to acetone attack.
P.S. I'm using the term solvent, as I presume the poster I quoted used it, to be those liquids that will dissolve compounds similar to the vehicle components typically exposed to gasoline: rubbers, plastics, metals, and possibly ceramics. The proper definition of solvent and solute depend more on the bulk of material found in each particular solution; gasoline is properly a solution with all components dissolved into the others; given the number of components in the solution, it would be difficult pointing out a single compound functioning as the solvent.
P.P.S. I am not a polymer chemist, nor am I a petroleum chemist. Though I say I'd be astounded to find a polymer that would react with acetone and not gasoline, I don't know that such a polymer doesn't exists. I am a Ph.D. inorganic chemist; I study the broadest range of compounds, their properties, and the bonds that hold atom to atom, and molecule to molecule, thus imparting the bulk properties to the material.
P.P.P.S. I honestly doubt that adding acetone will do anything to the milage you get per tank. I don't think combustion reaction mechanisms support acetone in any catalytic role, and acetone has a lower energy per ounce than gasoline as a whole.
Bruce 2007 Tundra DC/5.7L/off-road/NAV
  #45 (permalink)
Old 08-28-2007, 09:28 PM
ninrocket's Avatar
Banned
You are right in your assumption.
Acetone benefits the gasoline by lowering surface tension...hopefully creating more efficient vaporization and combustion. That's the theory anyway...we shall see.
Thanks for your insight!
Adding an amp and QLogic to factory radio crown&coke Audio & Stereo 14 09-22-2006 02:07 AM
Adding a AEM intake to a Flowmaster dual.. chmorro Aftermarket Products 3 09-27-2005 04:52 PM
How To: Adding 120V AC Power to a truck bed imjin Audio & Stereo 0 03-25-2005 05:16 PM
Adding 2nd fog light switch keninsb Electrical & Computer Systems 1 10-23-2004 07:37 PM
Adding Photos To Your Profile Possum Texas 3 08-31-2002 04:52 PM
