Unichip.com
Old 08-25-2007, 07:49 PM
asianflava's Avatar
Dealer : Classic Toyota Scion of Round Rock
2001 Toyota Highlander,
2007 Toyota Tundra CrewMax
Last Online: Yesterday 07:20 PM
asianflava is on a distinguished road.
asianflava's Photo Albums
Default Door panel removal & speaker install
Here is a pictorial to show you how to remove the door panels.
This is the back door for the CrewMax but the front doors are the same.
Remove the 2 screws behind the door latch cover and the grab handle.
Push the plastic pin in with a small screwdriver. The pin is towards the front on the front doors.
After these 3 fasteners have been removed, start at the bottom and pull the panel away from the door. When it is free pull up to get over the window ledge.
Disconnect the door lock and door open cables (they snap out)
Disconnect the power window harness
Disconnect the puddle lamp harness
You can remove the door
Old 08-25-2007, 08:03 PM
asianflava's Avatar
Default Re: Door panel removal
Here is how I did the reas speakers:
I removed the factory speaker and cut out the cone
After I cut the cone, I cut the frame and removed the cone
I screwed the speaker right to the old speaker's frame
To make for a clean install, I soldered the speaker connection to the old frame
Because I soldered them, I was able to use the factory plug.
Old 08-25-2007, 08:16 PM
asianflava's Avatar
This is the front speaker install
Here are some comparison pics between the factory speakers and the Polk db690's. NO wonder the factory ones sound so bad.
I used this speaker adapter for an ebay seller. I prefer it because it is plastic instead of MDF which is what some others use.
Since I got my speakers from Crutchfield, they included these speaker harnesses
I used the spacer which came with the new speakers, on the rear for more clearance
Ready to install, harness and spacer have been installed.
Final installation
seadragon's Avatar
Dealer : Milton Toyota
2006 Toyota RAV4 Limited,
2007 Toyota Tundra 5.7L DC 4x4 SR5 TRD
Last Online: Today 07:07 AM
seadragon is on a distinguished road.
seadragon's Photo Albums
Outstanding post! I'm going to upgrade my non-JBL speakers soon. Thanks for the well documented process with great pics, they really help!
2007 Tundra 4x4 5.7L SR5 TRD BLK
Old 08-25-2007, 09:23 PM
Dealer : Cobb County Toyota Scion
2007 Toyota Tundra Red with Sport Pack
Last Online: 04-12-2009 04:28 PM
lss177 is on a distinguished road.
lss177's Photo Albums
Question Re: Door panel removal
So how does system sound w/o a subwoofer? Is door speaker upgrade enough of an improvement? Or is subwoofer next move? Did you keep standard (non-JBL) head unit?
Lance
Old 08-25-2007, 09:27 PM
niyo's Avatar
Dealer : Servco Auto Center
Last Online: 06-24-2009 02:09 AM
niyo is on a distinguished road.
niyo's Photo Albums
What size speakers are in the rear door?
Old 08-25-2007, 09:34 PM
lotus4s's Avatar
Dealer : Courtesy Toyota Scion of Orlando
Last Online: 06-30-2009 01:34 PM
lotus4s is on a distinguished road.
lotus4s's Photo Albums
very nice job and thanks for the pictorial.
Old 08-25-2007, 10:06 PM
ChiroHorn's Avatar
Dealer : Charles Maund Toyota
2007 Toyota Tundra Silver DC 5.7
Last Online: 08-28-2008 06:57 AM
ChiroHorn is on a distinguished road.
ChiroHorn's Photo Albums
Nice writeup. By a local to boot! What model # are the speakers? Can I listen to your setup sometime?
Old 08-25-2007, 10:50 PM
asianflava's Avatar
Yessir! an amp and sub will be the next step. I haven't decided on the head though. I'd like to get a double DIN nav system but that depends on if I can save enough moolah, there are so many things I want to get. I'm gonna use the factory head unit for now. I have a pair of JL 10W1s from my old car and a pair of 8W1s from my old truck. I'll see which ones will work best for the space available. I also haven't decided on the amp, I prefer discrete channels for the speakers so it will probably be a milti channel amp like a 5 or 6 channel.
It sounds OK, nothing to brag about. It is much better than the stock system though. The internal amp on the factory head doesn't have much power, it peters out pretty quickly.
6.5s
Polk db690 in front and Polk db650 in the back. Crutchfield was closing them out so both pairs were under $150. Don't know if they have anymore, I just got their new catalog and it shows the db691 and db651 which are the newer model.
Thanks for the compliments!
Old 08-25-2007, 11:04 PM
Dealer : World Toyota Chamblee
2009 Toyota Tacoma SR5, TRD, CREW CAB,
2007 Toyota Tundra RCLB -- TRADED
Last Online: 06-29-2009 07:47 PM
SOSHeloPilot will become famous soon enough.
SOSHeloPilot's Photo Albums
This answers a question that I have been thinking about for a while .. "how to remove a door panel".
I need to replace speakers, add a few additional ones, add insulation & eliminate a few rattles. ..
I have a RC-LB with the big doors .. and this is a great for me also. ..
Excellent post .. you should be writing manuals for the military .. ..
Thanks again ..
SOS
PS ... Now ... How do I keep from losing this thread ???? ... LOL ...
Old 08-25-2007, 11:10 PM
Dealer : South Coast Toyota Scion
2007 Toyota Tundra 5.7 double cab,
2006 Toyota Tacoma Xrunner
Last Online: 06-07-2009 10:15 AM
sp33dy714 is on a distinguished road.
Send a message via AIM to sp33dy714 sp33dy714's Photo Albums
is the front speakers 6x9?
Old 08-25-2007, 11:11 PM
Dealer : Putnam Toyota
Last Online: Yesterday 05:43 PM
joshp is on a distinguished road.
joshp's Photo Albums
I'm thinking for the average person the 6X9's powered by an external amp is probably sufficient bass reproduction.
Didn't someone on here get a wiring diagram that allowed them to split into a signal for an external amp to power the mids and highs? If so please post details on the wires (color, location etc.)
Old 08-29-2007, 07:18 PM
Dealer : Fort Myers Toyota Scion
Last Online: 02-20-2009 05:51 AM
jaymarine75 is on a distinguished road.
jaymarine75's Photo Albums
Exclamation Re: Door panel removal
i just put in the db691s and the tweets in the center are pushing on the door panel. i did not use the spacer provide with the speakers.
if you get 6x9s make sure the tweet is flush w/ the speaker
Old 08-29-2007, 07:21 PM
ME BIGGER's Avatar
Dealer : Piercey Toyota Scion
Last Online: 10-13-2007 04:26 PM
ME BIGGER is on a distinguished road.
ME BIGGER's Photo Albums
or get 6X9 components
THE GARAGE
Old 08-29-2007, 07:28 PM
AlaskaCub's Avatar
Dealer : Auto Service Company
2005 Toyota 4Runner SR5 4x4,
2007 Toyota Tundra TRD 5.7L DC SR5 4x4
Last Online: Today 04:15 PM
AlaskaCub is on a distinguished road.
AlaskaCub's Photo Albums
Where did you get the 6x9 speaker adapter? I havent seen one that wasn't MDF.
07 Tundra DC TRD 4WD 5.7L Desert Mica
Oh and I dont use spell check!
Valve shim removal tool Al Hanks Corolla Matrix 10 01-29-2008 01:21 AM
Tacoma Door Panel Removal Questions supraxx Tacoma 3 06-18-2005 03:32 PM
Rear door panel removal? Brian's Toy Interior & Exterior 10 10-27-2004 12:16 PM
