Old 10-02-2007, 11:20 AM
Dealer : Leith Toyota
2007 Toyota Tacoma
Last Online: 07-31-2009 05:05 AM
Tundra Man 2007 is on a distinguished road.
Tundra Man 2007's Photo Albums
Default Recycle vs. fresh air
OK, this is not an earth shattering thing, but am I the only one that is driven crazy by the way the truck resets itself to recycling air versus just staying where is was set when the truck was turned off? I only want recycle during the summer and as it has finally started to cool off I find myself having to select fresh air everytime I start the truck. We have guys on this board that can reprogram the Nav System, over ride the seat belt buzzer and explain stuff that I can't even begin to figure out (like the traction control/VSC/4-trac). Surely someone can figure out how to make my air stay on fresh!!!!!!!!!!!!!!!!!!!!!!!!
Kirk
Old 10-02-2007, 11:26 AM
mxsjw's Avatar
Jedi Ninja in Training
Dealer : Toyota of Puyallup
- Other - 2003 VW Passat,
Images: 10
mxsjw's Photo Albums
Default Re: Recycle vs. fresh air
I was frustrating me too, I had the service tech at my dealership jack in with his techstream laptop and change it.
That is the only way I know of that it could be done, I also sweet talked him into disabling the Pass seat belt chime.
Beer please!
Old 10-02-2007, 11:30 AM
mxsjw's Avatar
Images: 10
Here you go, post #1 has a PDF of the items that can be changed by you and by the dealership.
Feature Customization??
that should help
Beer please!
Old 10-02-2007, 01:08 PM
Dealer : La Fontaine Toyota
Last Online: 11-05-2009 07:00 AM
stinvh is on a distinguished road.
stinvh's Photo Albums
Thanks for the info - I was going nuts with the truck on recycle air all the time. Why would they make that the default in the first place?
Thanks again!
Old 10-02-2007, 01:23 PM
mxsjw's Avatar
Images: 10
Thanks again!
Efficiancy is my guess, heater and a/c work faster on recirc.
I always keep mine on "fresh", I don't want to smell my stinky azz any longer than I have to.
Beer please!
Old 10-02-2007, 01:28 PM
seadragon's Avatar
Dealer : Milton Toyota
2006 Toyota RAV4 Limited,
2007 Toyota Tundra 5.7L DC 4x4 SR5 TRD
Last Online: Today 06:12 AM
seadragon will become famous soon enough. seadragon will become famous soon enough.
seadragon's Photo Albums
Yeah, this "feature" is on my RAV4 too. I think it is only on trucks with the automatic climate control (which my RAV has). My Tundra has manual controls so the recirc does not come on by itself.
Here's another thought. I have been told and read that its a good idea to hit the recirc button when you're leaving your vehicle for a while (like at work or overnight). This closes the fresh air damper and will keep out mice and other rodents. I had this problem with my Highlander and they made a real mess.
Anyway, does anyone know when the damper actually closes? Is it at shutdown or at startup? If at shutdown, that could potentially be a good thing.
2007 Tundra 4x4 5.7L SR5 TRD BLK
Old 10-02-2007, 02:22 PM
2007 Toyota Tacoma
See I knew someone had figured this out. One more question. Is it only possible to do these mods through the "intelligent tester" or the "Techstream", in other words via the dealer or can it be done through the mod system in the Nav system?
Kirk
Old 10-02-2007, 02:28 PM
mxsjw's Avatar
Images: 10
I do not believe you can access the truck features through the Nav system at all, sorry.
The "multi infomation display" if you have a Limited has some, as seen in the document, everything else is dealer only so far, unless you buy the laptop or tester yourself...$$$$$$$$
Beer please!
Stock Air Flow Numbers and Mod Hi Volt Forced Induction Systems 84 03-24-2009 09:12 PM
After-Market Air Filters mmulcahy1 1Gen-Tundra 26 03-08-2008 04:59 AM
Cold Air without AC System On Using Defrost Setting? Ralpert Tundra 10 08-30-2007 11:05 PM
Tundra Air Filter Test nhparrot Engine & Drivetrain 56 04-04-2004 09:14 AM
Tundra Air Filter Test nhparrot Knowledgebase Archive 0 06-06-2002 07:52 PM
