  #16 (permalink)
Old 10-17-2007, 03:11 PM
Dealer : Gene Reed Toyota
Last Online: 08-17-2009 05:36 PM
turbo8765 is on a distinguished road.
turbo8765's Photo Albums
Default Re: MODS+DYNO Results
Originally Posted by Gave_up_my_Bowtie View Post
Actually K&N's dyno runs seem to show the same type of curve and no I'm not putting my foot into it more for the sound, but like I said before Take it for what its worth. I just thought some people would like to see some real data.
Absolutely, I very much appreciate the data. Particularly since you have a usefull comparison given that you've dyno'ed before and after mods on the same dyno.
I'm just blown away by the performance of the intake in the midrange. I hadn't considered any power mods, but this is too good to pass on.
It is exceedingly unlikely that the exhuast you installed significantly altered EGTs. There really is no logical explanation at this point for why the cat back reduced fuel economy.
  #17 (permalink)
Old 10-17-2007, 03:17 PM
Dealer : Demontrond Toyota Scion
Last Online: 11-22-2008 06:22 PM
swagtime911 is on a distinguished road.
swagtime911's Photo Albums
Nice work Bowtie.
I think that it was cool to do back to back runs, but it doesn't change my outlook on changing out the air intake and replacing it with K&N, Airraid, etc. I am sure on any dyno you will show an increase no doubt, but I bet if you were to re-dyno in say 1 month, your gains will be all but gone. Without a programmer the truck is just gonna readjust for the added air flow and all you will have left is the intake noise. Which is not worth $300-$400 in my opinion.
  #18 (permalink)
Old 10-17-2007, 03:27 PM
thumbster's Avatar
Moderator
Dealer : Capitol Toyota
2005 Toyota Corolla,
2007 Toyota Tundra 5.7 RC SB SR5 Sport
Last Online: 11-15-2009 01:12 AM
thumbster is a splendid one to behold. thumbster is a splendid one to behold.
thumbster's Photo Albums
Looking at the stock curve, it appears as if you didn't put your foot into it enough to get a WOT reading, at least that's what the A/F ratio curve says - the stock (green) A/F ratio stays at 14.7 (closed loop) longer. This may magnify the apparent gains you were seeing from the other curves in comparison.
  #19 (permalink)
Old 10-17-2007, 03:28 PM
Dealer : Montrose Toyota
Last Online: 09-17-2009 09:56 PM
Gave_up_my_Bowtie is on a distinguished road.
Gave_up_my_Bowtie's Photo Albums
Originally Posted by swagtime911 View Post
Nice work Bowtie.
These mods were done over the course of a week. The intake mods as well as the exhaust mods were done at wide open throttle. Therefore nothing should change because the computer is in what I think is called open loop which doesn't use the O2 sensors only the mass air sensor. At that point we are just running according to what the computer is mapped to run at. So many CFM= so much fuel. Thats why we need programmers or adjustable mass air sensors to change this setting or fool the computer. That was a concern of mine as well with testing over a short time. Thanks for the idea.
07 Black Crewmax 5.7 4X4 FE, BU, CK, DZ, AA, HM, MG, CF, SIRIUS, K&N CAI, SMITTYBILT SIDE STEPS, SMITTYBILT BULL BAR, TRUXXX 3" FRONT 1" REAR LEVELING KIT, BFG 305*65*18's, JBA DUALS, CHROME HANDLES...BLAH..BLAH..BLAH....
  #20 (permalink)
Old 10-17-2007, 03:29 PM
Thats completly on the dyno operator. Only they are allowed to run the dyno
  #21 (permalink)
Old 10-17-2007, 03:41 PM
low c1500's Avatar
Dealer : Red Deer Toyota
Last Online: Yesterday 11:33 AM
Images: 1
low c1500 is on a distinguished road.
low c1500's Photo Albums
The newer vehicles actually do some fuel triming at WOT, so its not completely open-loop. The first I've read of this was the early 2000's Ford lightening.
Hard to say waht Toyota does with there computers??
2008 Tundra CrewMax Limited 4x4 5.7, White w/ oak leather, Moonroof, NAV, Factory 20's, XM.
2006 Nissan Murano SE Black, Loaded, Black leather, 20" Dubs
2005 Corvette C6 (#581) Coupe 6 spd Black, Loaded, Black Leather, Navigation, XM, Onstar, HUD, F55 Magnetic ride, Z51 Brakes/calipers/sway-bars, Route 66 Exhaust, Intake, Custom Tune, 160 stat. Only 2 runs at the track...12.4s @116mph
  #22 (permalink)
Old 10-17-2007, 04:05 PM
123Gone's Avatar
Dealer : Toyota Of Fort Worth
2005 Toyota Tundra
Last Online: Yesterday 10:34 PM
123Gone will become famous soon enough.
123Gone's Photo Albums
Looks like max HP is 311.79 and assuming a 20% auto transmission loss, that is 389.74 HP at the crank. But, we don't know about any SAE correction.
The graph is fairly wavey, not really a good sign. Looks like the engine starves for gas/air fairly early.
  #23 (permalink)
Old 10-17-2007, 04:06 PM
Rocketsled's Avatar
Dealer : Fremont Toyota Scion
Last Online: 09-13-2008 04:49 PM
Rocketsled is on a distinguished road.
Rocketsled's Photo Albums
I'm not being negative or anything, I think your gains are Great!
But I did noticed on the K&N site that the picture shows that its a "boxless design" that uses the hood to seal the top from hot engine heat, but if the hood is open on the dyno runs....then it is sucking cool air from All 360 degrees. Now with the hood closed (such as when driving) you are mostly getting air from the fender hole(I believe). With the stock filter box assembly it makes little diffference in cfm if the hood is up or down.
I wonder if that would explain the extraordinary power difference.
It would be interesting if someone does a closed hood run with the same cai
Anyway NICE gains
2007 Tundra SR5 Crewmax 4x2
5.7L Slate Metalic, Graphite Fabric
Bucket seats w/floor-shift
Bedliner with deck-rail system
  #24 (permalink)
Old 10-17-2007, 04:19 PM
I think on this PCM the "open loop" really is used more for start-up than wide open throttle on this engine. On my last dodge the PCM had a very tight INT and BLM value window. Once you moved to one end or the other of the scale it would default a 14% value and detune. Next time you cranked it up it would read and detune again until it got into a measurable window. If you made a change it couldn't compensate for it would trip into "limp" mode until you took it to the dealer to have the PCM reflashed. It sucked. This PCM is not going to be as simple to crack and adjust like those of chevy. I wish we had something like an LS1 type flash, but I think were going to be screwed for sometime.
  #25 (permalink)
Old 10-17-2007, 04:43 PM
07 firecrew's Avatar
Dealer : Cowboy Toyota and Scion
2007 Toyota Tundra superwhite crewmax
Last Online: 04-25-2009 07:46 PM
07 firecrew is on a distinguished road.
07 firecrew's Photo Albums
that's because the engine is running too rich with the addons, yes it's making more power at the expense of less mpg. blame the air sensor and ecu.
2007 SR5 crewmax Texas Edition 4x2
light gray leather interior
xm radio, bed liner
fog lights
swaybar
woodgrain interior
carriageworks grille
corsa exhaust
ARE LSll cover
chrome accent covers
  #26 (permalink)
Old 10-17-2007, 04:57 PM
123Gone's Avatar
2005 Toyota Tundra
It's possible that the computer's algorhythms can't compensate for the increased air flow.
  #27 (permalink)
Old 10-17-2007, 06:11 PM
FiveOh's Avatar
Dealer : Earl Stewart Toyota Scion Of North Palm Beach
2007 Toyota Tundra DC 5.7 TRD
Last Online: Today 05:01 PM
FiveOh may have some regrets.
FiveOh's Photo Albums
No it's not.
http://www.leanangle.us
  #28 (permalink)
Old 10-17-2007, 06:12 PM
FiveOh's Avatar
I think the graph shows pretty clearly that the ECU makes a switch into open loop. It would appear that the run timing skewed the early portion of the graph.
  #29 (permalink)
Old 10-17-2007, 06:44 PM
Dealer : Toyota Of Lake Norman
2005 Toyota Tundra
Last Online: 03-12-2008 05:54 AM
Fireman38 is on a distinguished road.
Fireman38's Photo Albums
What dyno shop did you go to? Big shot up, in the Falls?
I used to live in the "Lakes".Moved six months ago to NC.Somedays (most)I miss it there.Guiseppe's pizza yum
  #30 (permalink)
Old 10-17-2007, 07:24 PM
Hey former neighbor, just had Guiseppe's the other night. I took it to Akron Horsepower. Eric is a really good dude and seems to be the master when it comes to mustangs. They do some wild mods there(1800+ hp)
