Old 10-24-2007, 02:13 AM
Dealer : Camelback Toyota Scion
2007 Toyota Tundra 4x4 Crewmax Limited
Last Online: 09-23-2009 12:11 PM
Images: 10
hbonney is on a distinguished road.
hbonney's Photo Albums
Default New Upper Control Arms
Total Chaos has a new upper control arm that is supposed to correct loss of caster when adding 3 inch lifts...has anyone experienced any loss of straight line stability or handling issues after adding the lift and getting alignment done? I understand that camber is adjustable but caster falls where it does when you lift it....
Total Chaos 2007+ Toyota Tundra Suspension System
2007 Crewmax Limited 4x4 Nautical Blue, OME 2.5 inch front lift, OME Dakar 2.5 inch rear leaves, BFG 305x55x20 Mud Terrain KM2's on stock 20 inch rims
Old 10-24-2007, 05:47 PM
DevinSixtySeven's Avatar
Leader of Group Evil
Dealer : Voss Toyota
Last Online: Yesterday 02:10 PM
Images: 22
Default Re: New Upper Control Arms
Toyota (and everyone else w/double wishbone setups FAIK) designs their front suspension so the lower control arm pivots parallel to the ground, and the upper control arm has a slightly positive angle of attack.
This ensures stability during compression...a frost heave or hard landing is the last place you want an unstable truck.
I don't think anybody has posted alignment numbers yet, much less min/max caster, for lifted 07s.
You're correct, when you lift you lose caster, so you get what you get to some degree. There's a range tho...on a 1st-gen it's a few degrees, you should still be able to get a good alignment with a mild lift.
Less caster means the truck will be less stable in crosswinds, ruts, and chatter, will wander more, and will follow any tilt in the road much more compared to the same truck with higher caster.
Chaos increases the caster angle by moving the upper ball joint position slightly aft from stock. This does nothing but help ...and the arm should provide about as much travel as a 1st-gen with a long travel kit since the 07 arms are longer .
-Sean
GFX by FreedomEagle50
Manual Hubs
Old 10-24-2007, 06:01 PM
Dealer : New Rochelle Toyota
Last Online: 01-20-2009 11:11 PM
reldapimp has little shameless behavior in the past.
reldapimp's Photo Albums
Socal Truck Gallery
This truck has it installed. he is also a member here.
Old 10-24-2007, 09:24 PM
Dealer : Longo Toyota
Last Online: Today 01:34 AM
Images: 3
dani7 is on a distinguished road.
dani7's Photo Albums
Originally Posted by reldapimp View Post
Socal Truck Gallery
yea saw this truck at the off road expo pretty clean.
Old 10-24-2007, 09:28 PM
AlaskaCub's Avatar
Dealer : Auto Service Company
2005 Toyota 4Runner SR5 4x4,
2007 Toyota Tundra TRD 5.7L DC SR5 4x4
Last Online: 11-06-2009 11:12 PM
AlaskaCub is on a distinguished road.
AlaskaCub's Photo Albums
Man that red Tundra needs a little lift in the rear bad! Hate the look of the tail draggers!
07 Tundra DC TRD 4WD 5.7L Desert Mica
Oh and I dont use spell check!
Old 10-24-2007, 09:31 PM
Images: 3
here in cali PRE RUNNERS have exploded think thats kind of look he was going after. which is pretty sick by me
Old 10-24-2007, 09:33 PM
I thought CA had the lift law where the taillights have to be a certain height. And the Front is not limited. ??? I could be wrong
Old 10-24-2007, 09:38 PM
AlaskaCub's Avatar
Toyota Pre-Runners??? Whats a Pre-Runner?
Old 10-24-2007, 09:41 PM
Images: 3
yea there is some laws but most the time the truck has to have 12" 15" lift to get pulled over for not having mud flaps. but most cops that come in to my friends shop will sign off on the fix it ticket right there so its pretty cool. But you will see more lifted trucks here than anywhere most cops can careless, they just nail you for speeding like a mother f-er
Old 10-24-2007, 10:02 PM
Images: 3
a pre runner can have 25" 30" of wheel travel for Pre running in the desert or what not. mostly in cali its all young adults who put 10+k in there suspensions. basically the affordable version of baja 1000 trophy truck that are 300K$$
YouTube - Dirt Alliance
Old 10-24-2007, 10:09 PM
more pictures and info on that last crewmax
Old 10-24-2007, 10:19 PM
GGWOODY's Avatar
Kibble Wrangler
Dealer : Alexander Toyota of Franklin
Last Online: 11-18-2009 11:20 PM
GGWOODY is the One. GGWOODY is the One. GGWOODY is the One. GGWOODY is the One. GGWOODY is the One. GGWOODY is the One. GGWOODY is the One. GGWOODY is the One. GGWOODY is the One. GGWOODY is the One. GGWOODY is the One.
GGWOODY's Photo Albums
My Total Chaos UCAs go on tomorrow with my SAW long travel coilovers, and an AAL. Obviously, this is more than a spacer lift, but I'll get alignment (camber/caster) numbers from the shop. Will talk to the mechanic about it.
BTW...these friggin' coilovers are MASSIVE
Want to know what's ironic? My Polish grandparents who were captured during the Warsaw Uprising.
Grandmother was enslaved in a German concentration camp and forced to make artillery shells for the 3rd Reich. Grandfather was in German and Soviet POW camps...ending up in Siberia. After WWII, they moved to the USA to be free, but Obama has turned it into the USSA...Grandaddy is rolling in his grave.
CBTMA Member
Old 10-24-2007, 10:21 PM
GGWOODY's Avatar
Kibble Wrangler
Oh yeah...California law is 48" maximum height from the earth to the bottom of the headlight...no law on the rear from what I've heard.
CBTMA Member
Old 10-24-2007, 10:22 PM
Images: 3
yea well i cant really remmeber what was on that truck but im pretty sure it had total chaos UCA, 2.0 coil overs that add 3" of lift, 35" tires they had two trucks allmost the same but one had a tire rack. was so post to be a pit truck for the desert or something like that.
Old 10-24-2007, 10:30 PM
35's look kinda big to me.. I like 20's on 33's.. It fits nicer..
Anywho what exactly are the coilover's for and what do they do..*sorry im a newbie*
