Re: DIY: Change the Rear Differential Fluid in 07 Tundra w/pics
Drained/filled mine today with Mobil1 75w90 with 11k on the truck. Not a bad job at all. The fluid was very dark, and the stuff I wiped up off of my collection container was black on the paper towels. The drain plug had the blob of goo on there, dark grey and full of metal. Like grease. The drained fluid was FULL of metal shavings, some were just specks, others bigger like 1-2mm in size.
Filled mine up with almost 4 quarts, then took it for a figure-8 parking lot spin. Got back, and removed the fill plug and had some fluid seeping out. I put on a new washer and put the fill plug back in while it was still seeping. Torqued the bolt and I was done.
The washers were about a buck each at my dealer. Picked up some engine oil drain plug washers while I was there :-)
sspatel - I have a county waste collection facility nearby - I take my old oil there. You could probably take it to a local auto parts store too, many of them offer to take used oil for recycling.
2007 Tundra DC TRD 4x4
Pyrite Mica
Bucket Seats
Cold Kit
Deck Rails
Tow Mirrors
Door sill protectors
Originally Posted by can't stop spinning
Has anyone changed the oil in the front dif? Is it the same as the rear?
Yes, i have and it's a beotch to do vs. the rear. It helps to have 2 people while attempting. I've actually replaced all 3 diffs in my truck with Amsoil Severe Gear 75w90 synthetic.
The process is the same as the rear, but the front takes 2.3 qts if i remember correctly. Transfer case takes 1.2 qts, but there was no need for me to replace the transfer case as the fluid looked brand new. But i did it anyway.
My truck had 15k on the clock, and the front fluid was in pretty bad shape. Be sure and getter done.
I am a new member and looking at doing this at some point, so am looking for pointers. I presume that the truck is raised on the left side to allow all of the fluid to drain out. Correct? If that is correct, would lowering the vehicle prior to refilling with oil get a more accurate oil level? Just wondering, maybe it doesn't matter or make that big of difference. Any opinions? Thanks to all involved here, very helpful.
Tman I don't think it makes much difference. If you DO raise the left to get more oil out, then yeah lower before filling. I didn't bother lifting the left side personally and I still fit the capacity in there so I am thinking most if not all oil came out.
Pyrite Mica
Bucket Seats
Cold Kit
Deck Rails
Tow Mirrors
I did mine today at 28,000 miles. The original fluid was a bit dark and my drain plug had the same gooey stuff on it as reported on the forum...no metal shavings observed.
I think a 24mm socket fits the plugs better that a 15/16" socket. I rounded off the corners of the fill plug with the 15/16 socket when I removed it.
Are the reported torque setting for the plugs correct? 36 ft#s Fill plug and 29 ft#'s for the drain plug....doesn't seem like enough Where did those figures come from?
I refilled with Royal Purple 75W-90...first time user of this product.
__________________ '07 Tundra SR5, 2WD DC, 5.7L, Salsa Red Pearl with Running Boards, Delta Toolbox.
Don't ever under any circumstance put a brick under a jack to raise your vehicle. Don't show greenhorns this dangerous shortcut or you may be resposible for getting someone hurt.
Great write up!
just a FYI about Royal Purple. The motor oil is super good we always run it in the race truck. However there gear oil is sub par. We ran it in the race truck, it made it 2 laps before blowing up the gear set. After inspection the oil gunked up under heat. I would recommend Mobile 1, or if you want the absolute best and dont mind forking out the money get Swepco. SWEPCO High Quality Industrial Lubricants
The 4th & 5th photo shows drain hole and then the drain bolt. Much better than GM & Ford where you need to remove the diff cover which is a messy PITA.
