If I have the limited with the alarm, but want to add the GBS, does that need to be activated by the dealer as well, or is it plug and play? (and if this has been addressed already, my SINCERE apologies.......)
Thanks,
Bill
if you have the limited and have the alarm, (roll window down,lock it, wait 1 minute and open it with the inside handle test) then it SHOULD be a plug and play, if not then you will have to get it turned on.(although every limited i have looked at/heard about is a plug and play)
The ball is rolling! The dental assistant will have to be a German nurse and will of course be called Frau Hen-ga. She'll delight in pulling chompers and in no time I will have a collection of hen's teeth. No good techs, you understand, those are actully rare here in the hills.
As for the arming the alarm, your previous GBS PDF included the complete RS3200 Plus manual. There, on page 5, it clearly states that to actively arm the alarm (i.e., passive off), all one has to do is lock the vehicle: turn the key, push the lock switch or use the remote.
Perhaps I'm wrong, but the way I read it, if the Security System is ON (via Techstream or the scanner as per version 2 of the PDF - Thank you, by the way!), any locking of the vehicle will arm the alarm. Is that true? If yes, I hope there is a door opening-closing procedure to turn the alarm (not the passive arming, but the alarm itself) off and on.
Originally Posted by Sparks Toyota-TRD
WELL, you can lock it with just the switch, but if you have passive arming turned on by the chicken dentist's assistants, as you say, then it will arm, if passive is not turned on then it will just be there with the immobilizer.
ok, what will your nurse look like when you open your poultry dental clinic?
Thanks - my alarm, GBS and hood switch now works!!!
I had my dealer activate mine gratis because of all the other stuff they screwed up. I had to go to the original "accessory guy", though - the service department blew me off (jerks)!
BTW, they used a laptop-sized Snap-On programmer so a TechStream isn't the only option (i.e. any well-equipped Toyota shop).
Mark
Mark,
Did that, it works!! I am ordering my GBS from you guys right away!
Thanks,
Bill
Word of advise, the install PDF says start on 5 sensitivity but for the Tundra start on 8 and I had to set mine to 10 for the glass tap method to work.
Man, I'm confused and I used to be a mechanic! I, too, bought the GBS kit from Sparks and even the hood switch. I couldn't get it to work after install on my SR5 DC Sport (and I didn't keep the box, either).
Anyone care to guess how the hood switch plays in this confusion? Does it need to be activated, too?
I hate to have to go to the dealer to get this stuff activated - they screwed up so many things on dealer add-ons I'll likely never go back...
I give up! I know this is going to make me look stupid but what in the world is a hood switch and what does it do?
