Old 11-08-2007, 10:14 PM
Dealer : Tejas Toyota
Last Online: Today 09:00 AM
EVOL ARDNUT is on a distinguished road.
EVOL ARDNUT's Photo Albums
Default Transmission Fluid Change
How often to realistically change fluid instead of 125,000miles recommended by toyota?
How many quarts, what weight, and whats a good synthetic?
ANY ONE DO A HOW TO YET?
Old 11-08-2007, 10:22 PM
guntech's Avatar
Benny Hill
Dealer : Prestiqe Toyota
2003 Toyota Camry,
Images: 71
guntech has done just about everything. guntech has done just about everything. guntech has done just about everything. guntech has done just about everything. guntech has done just about everything. guntech has done just about everything. guntech has done just about everything. guntech has done just about everything. guntech has done just about everything. guntech has done just about everything. guntech has done just about everything.
guntech's Photo Albums
Default Re: Transmission Fluid Change
I have a 120,000 warranty. At around 100,000 I'm going to have them do it. That gives me another 20,000 miles under warranty in case something goes wrong.
Old 11-08-2007, 10:23 PM
93cruiser's Avatar
Dealer : Glen Motors
2007 Toyota Tundra crewmax- it's mint
Last Online: Today 12:32 AM
Images: 1
93cruiser is on a distinguished road.
93cruiser's Photo Albums
Not an easy procedure without the Toyota service manual. My plan is to dump it at 25K, measure what comes out, and replaced the exact amount through the fill plug. If 5 quarts drains, I will put 5 back in. Drive for a few hundred miles, do again, and call it good until 75K when I will repeat it again. I dont care if I get it all out.........and I am trusting that it was filled to the correct amount from the factory. I like to replenish rather than replace everything in autos, but that is just me.
TOYOTA ONLY HOUSEHOLD
2007 Tundra CrewMax 4x4
2008 4runner SR5 4x4
1990 Land Cruiser FJ62
1972 Land Cruiser FJ40
2002 YZ250F
Old 11-08-2007, 10:57 PM
And without dipstick, no way of knowing?
Old 11-08-2007, 11:50 PM
Afterimage's Avatar
Dealer : Toyota of Puyallup
2007 Toyota Tundra DC TRD LTD 4x4
Last Online: 11-19-2009 03:04 AM
Afterimage is on a distinguished road.
Afterimage's Photo Albums
The Tundra uses separate fill and overflow ports. You add fluid through the fill port till it runs out the overflow port. Now it's full. Simple.
Look at the attachment I posted in this thread.
Originally Posted by Tundra Repair Manual
2. TRANSMISSION PAN FILL
(a) Remove the refill plug and overflow plug.
(b) Fill the transmission through the refill hole until fluid
begins to trickle out of the overflow tube.
(c) Reinstall the overflow plug.
Getting the fluid out looks like dropping the pan, however. Not fun but no big deal.
Old 11-09-2007, 04:15 PM
NO PICS YET, FOR MOST OF US NOT THERE YET.
i..m.o. DON'T WAIT UNTIL 120,000 MILES TO REPLACE TRANNY FLUID.
IT HAS BEEN SHOWN THAT IF YOU DO, YOU WILL SOON BE REPLACING TRANSMISSION AS WELL.
LOOK AT AUDI, MERCEDEZ THREDS FOR THESE SO CALLED NO MAINTENANCE TRANNYS.
EX. C230 MERCEDEZ IS SEALED. WHAT IT HAS BEEN SHOWN IS THAT IF YOU DON'T DO IT AT 20 -40 THOUSAND AND WAIT UNTIL 100, 000, YOU WILL BE REPLACING TRANNY THERE AFTER AS WELL. SO AFTER 100, 000 MILES, NO ONE TOUCHES TRANNY UNTIL IT DIES.
Old 11-09-2007, 04:17 PM
I Plan To Replace Tranny Fluid At 30-40 On 5.7 Tundra.
Any More Imfo Anyone?
Old 11-09-2007, 07:58 PM
kd5byb's Avatar
Dealer : Bill Penney Toyota
2007 Toyota Tundra CrewMax 5.7L SR5 TRD
Last Online: 11-10-2009 02:43 PM
kd5byb is on a distinguished road.
kd5byb's Photo Albums
I'm still formulating my plan of attack on tranny fluid changes:
Periodic Partial-Change -or-
The first school of thought which has already been presented is to drain the pan, measure the amount drained, and refill the same amount. If you do this periodically (maybe every 10k?), you'll get the wear metals out and get fresh fluid in. This method is very simple. Checking the fluid level in the tranny seems pretty simple.
Full Flush?
A full flush is very appealing. It gets everything out now. If you've got a truck with a towing package, you may be able to use the tranny cooler lines. I've seen several methods:
1) Disconnect the tranny fluid lines at the cooler and put the return hose (the hose returning fluid to the tranny) in a bucket of new fluid and putting the supply hose (the hose supplying fluid to the cooler from the tranny) into another bucket. Start the engine, put the tranny in N and let the tranny pump the old fluid out and suck new fluid in. This method assumes that the tranny both pumps fluid out to the cooler as well as scavenges (or sucks) fluid back into the tranny. I don't know if this is how the AB60E/F works.
2) I think you could do the same thing as above but use two buckets that seal. One bucket is filled with fresh fluid, the other collects dirty fluid, but connect the two sealed buckets together so that the pressure going into the waste bucket pressurizes the supply bucket. This might work. The danger I see is that if they leak, you'll be forcing more fluid out of the tranny than back into the tranny.
3) I've also seen methods where you add fluid via a funnel into the return line as the tranny pumps out the old fluid. Trick is to put the fluid in at the same rate it's coming out! Probably tricky.
Fluid to Use?
Toyota WS seems to be a very special tranny fluid - or at least Toyota thinks it is. The service manual notes it's very low viscosity (thin) and has very little viscosity change between cold and hot. I've heard rumors both here and on BITOG that WS is fully synthetic, which I don't doubt. It's easier to get a fully syn fluid to perform at low viscosity with controlled viscosity vs temperature change.
* Toyota WS would be the natural choice to use. Posts here say it's about $5 to $6 a quart at the deal.
* Red Line Oil has a fluid that they claim meets Toyota WS specification.
* Chevron Multi-Vehicle ATF claims to meet Toyota WS specs. This shocked me, but check for yourself:
http://https://www.cbest.chevron.com/generated/MSDS/PDS27291626.PDF
Two things are striking to me about the Chevron fluid:
First, it seems to meet SO MANY different ATF specifications. Yet, being that Aisin AW supplies trannies to Toyota, Volvo, etc..., perhaps this isn't so shocking.
Second, it doesn't seem to be a fully synthetic fluid. Or, it's not more than a Group III Synthetic:
It is formulated with premium, severely
hydroprocessed base stocks and carefully crafted
additives that provide oxidation and thermal stability,
friction control, load-carrying ability, corrosion and
wear protection. It helps protect against the formation
of sludge, varnish, other harmful deposits, and foam.
Amsoil doesn't yet make a fluid that they say meets WS specs.
So, I'm not yet married to any fluid or change methodology...
later,
b
Old 11-09-2007, 09:39 PM
shooter2jim's Avatar
Slowpoke
1996 Toyota 4Runner,
2007 Toyota Tundra DCLB 4x4 5.7L
Last Online: Yesterday 11:59 PM
shooter2jim will become famous soon enough.
shooter2jim's Photo Albums My eBay
Why not get it done at the dealership so there won't be any warranty issues? To me, that's worth more than any non-dealership money savings you might get.
Old 11-10-2007, 08:09 AM
daless2's Avatar
Dealer : Toyota On Nicholasville
Last Online: 08-07-2009 07:26 AM
daless2 will become famous soon enough.
daless2's Photo Albums
I haven’t had the time to look in the factory service manual yet to determine if this can be done on the Toyota Trans or not, but….
I have changed out the trany fluid on a MB sealed unit buy using compressed air at about 40 - 50 PSI.
I used a 5 gal air tank, filled with new trany fluid. Then pressurized with air.
Disconnected the trany cooler lines and then connected the air tank to the return line.
Turned tank upside down so that trany fluid would come out of hose before the air did.
I don’t know if I got every drop of old oil out but I feel confident I did manage to get most of it out. Sure beat the dealer almost $500 charge to do the work.
This does over fill the trany, so you have to leave the overflow plug out for a few minutes to drain the excess.
Many Trany oil change places use a similar method to perform this function.
I will look at the Toyota A6 in the manual and see if it might work before actually trying it in the next 50K miles.
Might help,
Frank
Old 11-10-2007, 09:10 AM
Dealer : Mid City Toyota
- Other -
Last Online: 11-14-2009 03:13 PM
Skyhammerz is on a distinguished road.
Skyhammerz's Photo Albums
Here is the TSB for changing the ATF.
2007 Tundra DC, 5.7, Limited, 4X4
TRD, NAV,TOW
Afe Stage 2
Xlerator Exhaust
Desert Sand Mica
Old 11-10-2007, 10:29 AM
Dealer : Toyota Center
Last Online: 05-06-2009 05:39 AM
kevinivey is on a distinguished road.
kevinivey's Photo Albums
I plan on having my done @ 120k. I'll let ya know how it works out.
2007 Toyota Tundra Double Cab Black TRD
Old 11-10-2007, 10:39 AM
Check Other Vehicle Types With The Same Idea At 100, 000 Miles, Tranny Failures Thereafter.
I Think Toyota Is Doing What Germans Are, But German Cars That Said Do It At 100, 000 Or 120, 000 Found Out Trannys Were Going Out After Fluid Change At Those Miles. So They Went Back To Every 30, 000 To 40, 000 Miles.
Tundra Tranny Is Not Cheap And You Will Be Out Of Waranty At That Time. I Know This From My 99 C 230 With Its So Called No Maintenance Tranny. Above Applies. At 100, 000 Miles M.b. And Outside Mechanic Say To Leave It Alone Now Until It Dies Cause If I Do Tranny Fluid Change, High Chance Of Tranny Going Out.
Any One Understand What I Am Talking About?
Old 11-10-2007, 10:43 AM
If i let toyo do it at 30-40 thousand and there are shavings, then I will still be under warranty if tranny is trashed.
Old 11-10-2007, 12:10 PM
PVTUSMC81's Avatar
Dealer : Massey Motors Co.
2007 Toyota Tundra,
1995 Toyota Tacoma
Last Online: 06-14-2009 06:11 PM
PVTUSMC81 is on a distinguished road.
PVTUSMC81's Photo Albums
I read through that TSB on the ATF replacement. I can see some DIY folks gooning that one up.
PVTUSMC81
2007 Pyrite Mica CM Ltd TRD 4x4
