Old 11-11-2007, 07:50 AM
Dealer : Rudy Luther's Toyota
Last Online: 03-28-2008 07:16 PM
rahis is on a distinguished road.
rahis's Photo Albums
Unhappy Tailgate Handle Is Broken Again!!!
I had a problem with my tailgate handle.It ckicked but would not open the gate.Took it to the dealer they said its an easy fix ,flaw in design.I belived.They ordered 'NEW AND IMPROVED" parts and installed them under warranty.Well this weekend same thing happened again.Going to the dealer to get it fixed for free again.
I guess they just waiting for my warranty to expire!HATE IT>
2007 Desert Sand MicaDC LONG BOX 5,7 V8 4X4
Old 11-11-2007, 07:58 AM
Dealer : Faulkner Toyota
2007 Toyota Tundra,
1995 Toyota T100,
- Other - 88 4Runner SR-5
Last Online: 11-20-2009 10:50 PM
gobblerman is on a distinguished road.
gobblerman's Photo Albums
Default Re: Tailgate Handle Is Broken Again!!!
Didn't you get the memo. We're not supposed to use our tailgates, they are only meant to contain items in the bed. How dare you open your tailgate, that's undue stress and should be avoided. Seriously though, why don't they just scrap these gates already and produce something durable. Ok zeolots lets hear you chime in and tell us to stop whinning and how your sick of these posts.
Old 11-11-2007, 08:51 AM
Dealer : Draper Toyota
Last Online: 01-17-2009 11:15 PM
trinibob is on a distinguished road.
trinibob's Photo Albums
how about snaping a pick of the inside of your gate latch and point out to us the part that keeps breaking i would love to see this suspect part so that i can inspect my gate latch for bad parts!
Old 11-11-2007, 09:03 AM
slimjim2525's Avatar
Dealer : Gale Toyota Scion
2006 Toyota Camry SE Silver,
- Other -
Last Online: 05-22-2009 01:13 PM
slimjim2525 is on a distinguished road.
slimjim2525's Photo Albums
Talking Re: Tailgate Handle Is Broken Again!!!
That's some funny s#@t right there. To bad it's true.
Old 11-11-2007, 09:19 AM
cwit's Avatar
Dealer : New Country Toyota
2007 Toyota Tundra,
2006 Toyota Camry-Solara black moon roof
Last Online: Today 06:20 AM
Images: 3
cwit is on a distinguished road.
cwit's Photo Albums My eBay
I'v had both outer clips break. Did the mod where you drill lower part of rod & put in cotter pin,no problem sense. Took all of twenty minutes.
Charlie & Linda
Old 11-11-2007, 09:25 AM
clips WHAT clips ??????
Old 11-11-2007, 09:44 AM
dsmonline's Avatar
Dealer : Toyota Walnut Creek
2007 Toyota Tundra,
2008 Toyota Highlander Limited
Last Online: 11-17-2009 05:54 PM
dsmonline is on a distinguished road.
dsmonline's Photo Albums
If you open up the inspection plate on the tail gate and look at the mechanism used to open the latches, you will see a number of cheap plastic clips holding down rods. There are any number of ways to modify the tie-downs so that they will not come off or break just when you need to get into you bed the worst. I have a BakFlip cover on my truck and it is kept locked. If I could not unlock and open my tail gate, I would have to rip open the cover somehow, so it was important to insure I 'fixed' my rods and clips before I had a problem.
I have attached a copy of the TSB on this issue, I do not believe the dealer fix is sufficient to insure it will not have additional problems down the road.
File Type: pdf '07 Tundra Tailgate Latch Will Not Open.pdf (231.0 KB, 284 views)
'07 Limited DC 2x2, 5.7, Debadged, ReadyLift Leveling Kit, G2 BakFlip Tonneau Cover, Black Carriage Works Grille Kit, Black Westin Platinum Series Nerf Bars, Black TRD Anti-Sway Bar
Old 11-11-2007, 12:02 PM
truckman261's Avatar
Dealer : Mid City Toyota
2007 Toyota Tundra 4x4 5.7 SR5
Last Online: 02-23-2009 04:04 PM
truckman261 is on a distinguished road.
truckman261's Photo Albums
This happened to me also. No big deal really. Usually you break only one side the first time and then you probably broke the other side this time. I'd only be worried if the same side broke twice.
Tundra Truck Pro
MODS: Line-X, Sirius, Dual Flowmasters
Old 11-17-2007, 08:28 AM
Thanks for the info everyone.I really like my truck and I work construction for a living.Not just working by the hour but actually using my 8' bed to it`s full extent.I just so frustraiting when you nee to unload compressors and mite boxes OVER THE TAILGATE WHEN YOU ARE 150 MILES AWAY FORM HOME AND NO DEALER IN SIGHT FOR A WEEK AND NO TIME TO GO BACK.I dont mind getting it fixed it is just so frustraiting
They fixed it again and I was told they did not use Toyota parts and dealel did couple of mods himself to te opening mechanism.
Old 11-17-2007, 09:54 AM
Gary419's Avatar
Dealer : Toyota and Scion of Louisville
2007 Toyota Tundra Std Cab&Bed,White
Last Online: 05-13-2009 09:04 AM
Gary419 is on a distinguished road.
Gary419's Photo Albums
Thanks for supplying the TSB, I was hoping to have access on this forum for the TSB, have they reinstated them or did you have another source?
Gary419
Gary419
2007 StdCab ShtBed,5.7 v8.
TRD Pak,Undercover,BedRug,
Old 11-17-2007, 10:11 AM
dsmonline's Avatar
2007 Toyota Tundra,
Gary419
I bought a one day login at TIS for $10 and downloaded what I could and what I thought would be useful. The TIS site is not setup to grab large chunks of documents, it is painful to do them one at a time and rename the files so you know what you have.
Old 11-17-2007, 12:20 PM
Banned
Dealer : Carson Toyota Scion
Last Online: 06-15-2008 02:41 PM
ponyuk is on a distinguished road.
ponyuk's Photo Albums
If it happens again, you can still drop the tailgate by removed the 8 torx screws that hold the cover plate on to the tailgate and manually open it by pulling the two levers. I replaced my tailgate handle with one with the backup camera, the plastic clips do not look at all substantial. After reading the stories here I should look at modifying them.
Old 11-18-2007, 07:17 PM
Last Online: 11-12-2009 11:20 AM
temeculaseq is on a distinguished road.
temeculaseq's Photo Albums
Mine just broke this morning...right as I was leaving to go pick up my daughter's quad. Very frustrating time for it to break. I was able to open it by removing the access plate. One of the purple clips on the end of the rod broke. I'm surprised that Toyota used such a small cheap piece of plastic!
Garage:
2007 Tundra Crewmax SR5, 5.7L, 4x4, Slate Metallic, Katzkin Leather, Line-X, Pioneer Avic D3 (with iPod, Bluetooth, XM and Backup Camera)
2004 Sequoia Limited, 4x4, Pioneer Avic Z2 (with iPod, Bluetooth and XM)
http://www.flickr.com/photos/9472383@N08/
Old 03-12-2008, 03:12 PM
07White-SR5's Avatar
Dealer : Robbins Toyota
Last Online: 09-28-2009 08:43 PM
07White-SR5 is on a distinguished road.
07White-SR5's Photo Albums
Wow, funny you mentioned that. Because it's exactly what happened to me right now. This is the first thread I found after searching for broken tailgate latch.
Now I have to figure out how to get the cover open without damaging it so I can open my damn tailgate from the inside.
"Handle it? Sir...for 2 billion dollars, I'd handle my grandfather's balls."
-Cartman
5.7L DC - TRD CAI+Dual Exhaust, CW Grill, Chrome Handles, tint, 3" Truxxx Lift, HID's, G2 BakFlip, Rhino Lining, 20" Goliaths+33" Toyo's.
Old 03-12-2008, 03:36 PM
azdesert57's Avatar
Dealer : Avondale Toyota Scion
Last Online: 09-11-2008 06:21 PM
azdesert57 is on a distinguished road.
azdesert57's Photo Albums
question: will toyota replace the unit if mine is still working fine???
DESERT POWER 57
