LinkBack (4) Thread Tools Display Modes
  #91 (permalink)
Old 01-03-2009, 07:43 AM
WT's Avatar
WT WT is offline
Dealer : McGeorge Toyota
Last Online: Yesterday 10:30 PM
Images: 1
WT is a splendid one to behold. WT is a splendid one to behold. WT is a splendid one to behold.
WT's Photo Albums
Default Re: DIY: Automatic Tailgate and Unlock/Lock Projects with Pics..
Originally Posted by Twinster View Post
I'll open it up and mess with it again this weekend. my problem is when i pull the handle to open the tailgate, the rod doesn't get pulled b/c the actulator is not sitting all the way up. So its not fully unlock. Hard to explain but hopefully i'll get it this weekend.
Okay I understand the issue now, Its a matter of getting the throw just right but it should work. I test to be sure everything works just right before closing up the panel. I am sure you figure out the right placeing of the actuator on the bracket.
2007 CM Limited Blue Streak
Click below for Auto Tailgate Project:
http://www.tundrasolutions.com/forums/tundra/116550-automatic-tailgate-unlock-lock-projects-pics/
DVD Headrest:
http://www.tundrasolutions.com/forums/tundra/120927-dvd-headrest-installed-about-350-00-a/
DIY Painting door handles (color match):
http://www.tundrasolutions.com/forums/tundra/121391-diy-paint-your-door-handles-match/
Bakflip and Bedrug:
http://www.tundrasolutions.com/forums/truck-bed-tonneau-covers/113644-g2-bakflip-installed-crewmax-w-pics/
Color match grill/Clear Bra/Other Stuff:
http://www.tundrasolutions.com/forums/tundra/112118-mod-weekend-with-pics/
Billet grill installed:
http://www.tundrasolutions.com/forums/tundra/124082-billet-grill-arrived-and-installed-pics/
Black Headlight Mod:
http://www.tundrasolutions.com/forums/tundra/126864-completed-my-diy-black-headlight-mod/
TPMS Bypass:
http://www.tundrasolutions.com/forums/tundra/142895-tpms-diy-bypass-completed-tested-pics/
Truxxx Lift:
http://www.tundrasolutions.com/forums/tundra/136860-truxxx-lift-install-w-pics-thoughts/
How to fit 35" Tires with body mount mod:
http://www.tundrasolutions.com/forums/tundra/138052-lifted-with-35-and-pictures-share/
  #92 (permalink)
Old 01-06-2009, 11:02 PM
Gunner Tundra's Avatar
Dealer : Kearny Mesa Toyota Scion
2007 Toyota Tundra LTD 5.7L 2WD Black,
2000 Toyota 4Runner LTD 3.4L 2WD M. Slvr
Last Online: 11-21-2009 12:08 AM
Images: 133
Gunner Tundra is on a distinguished road.
Gunner Tundra's Photo Albums
Just finished up this MOD. I'd say it's one of the "MUST DO" simply for convenience and most bang for the buck enjoyable MODs to do. I only did the lock/unlock actuator, but now I don't have to turn off my truck just to use the key to get something from the bed. Thanks to WT for the Outstanding PDF/post. BTW, I used the Harada brand Actuator from The Right Connection Pt No. DLA-01.
2007 Tundra CrewMax LTD 8272 Black/Sand Biege - Navigation, Rear Seat Entertainment, 20" Alloys, Sunroof, Mudguards, Sonar, DTR, V2 Alarm w/GBS.
MODS: Line-X, RETRAX, Tech Formula Paint Sealant, Debadged, Clear DRL's, AMP Powerstep Running Boards, 2.4" ReadyLift, Nitto Terra Grapplers 305/55/20's on OEM LTD 20" Alloys, Ravelco Anti-Theft Device, aFe CAI Stage 2 ProDry S, Corsa Performance Touring Exhaust. NEXT MODS: TRD Sway Bar, Auto Tailgate.
2000 4Runner LTD Millenium Silver 2WD - TRD Intake Air Filter, Clear-Corner Parking lenses, partial Debadge. Removed: Poweraid Throttle Body Spacer
1965 Ford Mustang 289 cid Laser Red - 5 spd, McLeod Clutch, Hydraulic Slave Clutch Cylinder, 3:89 Trac-Loc, 9" Lincoln Versialles Differential, 4 Wheel Disc Brakes, SVO Aluminum Master Cylinder, Simmons F90 custom wheels with Front/Rear width off-set, TFS Twisted Wedge heads, Holley 650 Double Pumper, Crower Custom CAM, Hooker Headers, Flowmaster w/H-pipe 2.5", SPAL fan, Weiand Stealth Intake - Mid 13's at 104 MPH street tires!
SOLD: 1993 Toyota Truck Xtra Cab SR5 2WD - E&C Spring UCA 3" lift, ProComp 3" Body lift, ProComp ES3000 Shocks, Rear Add-A-Leafs, 14mm Sway-Away Torsion Bars, Custom Skidplate and Driving light bar w/PIAA 40 Driving lights, Hella H4 Headlights, Optima Battery, Jacobs Omni-Pak w/8.5mm wires, K&N FIPK, FlowMaster 2 Chamber 2.5" CAT-Back Exhaust, 10 deg. Advanced Timing, Western 15x8 wheels, BFG TA KO's 31x10.5x15, 4.11:1 Gears w/Tru-Trac TracLok.
IYAOYAS!
  #93 (permalink)
Old 01-07-2009, 08:36 PM
WT's Avatar
WT WT is offline
Images: 1
WT's Photo Albums
Well Thanks and I agree got to love the tailgate lock even if you don't do anything else.
Congratulations and glad everything worked out for you and looks like you found another source for an actuator while doing the mod.
DVD Headrest:
Bakflip and Bedrug:
TPMS Bypass:
Truxxx Lift:
  #94 (permalink)
Old 01-08-2009, 11:31 PM
Dealer : Bohn Brothers Toyota
1995 Toyota Supra
Last Online: 11-09-2009 12:15 AM
Twinster is on a distinguished road.
Twinster's Photo Albums
I got it working! Thanks for the direction and pictures. I had to whip out the dremel tool to shave the actulator head for a smooth operation. Tap the wires straight to the passenger side Dark Blue and Big Gray wires. Now I have to hook up the trunk wires to my alarm so my tailgate can drop when I hit the trunk button.
  #95 (permalink)
Old 01-09-2009, 07:55 AM
WT's Avatar
WT WT is offline
Images: 1
WT's Photo Albums
Good to hear you got it all working , be sure to add a relay in line with your aftermarket alarm trigger for the trunk button. Don't want to burn out the output on your alarm trigger since most of those outputs are low current draw usually.
DVD Headrest:
Bakflip and Bedrug:
TPMS Bypass:
Truxxx Lift:
  #96 (permalink)
Old 01-10-2009, 10:36 PM
Dealer : Bryan Easler Toyota
Last Online: 10-15-2009 10:10 PM
Images: 3
Psychosis is on a distinguished road.
Psychosis's Photo Albums
Finally got around to doing the auto lock/unlock today. Don't really think I need the auto open part done (ran wire like the OP did, 4 18ga. wires in one bigger wire) but have 2 extra wires waiting if I ever decide to. I had a little trouble with full unlock and had to shave off some of the end of the actuator to make it work smooth. Never thought about maybe raising the actuator on the bracket up higher, might have worked better. Either way it works smoot as butter now.
Wire I used was just like this but not monster brand and mine is 18ga. http://www.radioshack.com/product/in...ductId=2344403
I also added a interlocking connector between the tailgate and the bed. Got it at radio shack and it came with both male and female sides, it locks right together perfect and comes apart easily if I need to remove the tailgate. I filled them with dielectric grease to keep it waterproof too. Here are the connectors. http://www.radioshack.com/product/in...ductId=2103292
The one thing that I would like to do is make it a tad quieter when it throws but I guess thats a good indicator that it is working.
Thanks for the mod info.
2007 Tundra Crewmax SR5 4x4, Silver Sky Metallic, 5.7L, Enkei 18" alloys, BFG Rugged Trail AT 275/65/18, 40/20/40 front bench, cold kit, deck rails, heated/power mirrors, Line-X bed spray, Access Literider Rollup cover, Yaesu ft-7100, Mobile1 5w-20, AVS ventvisors, Auto lock/unlock tailgate, Tundra step boards.
  #97 (permalink)
Old 01-10-2009, 11:41 PM
Marky_Mark's Avatar
Rut Ro!
Last Online: Yesterday 12:29 PM
Images: 13
Marky_Mark has done just about everything. Marky_Mark has done just about everything. Marky_Mark has done just about everything. Marky_Mark has done just about everything. Marky_Mark has done just about everything. Marky_Mark has done just about everything. Marky_Mark has done just about everything. Marky_Mark has done just about everything. Marky_Mark has done just about everything. Marky_Mark has done just about everything. Marky_Mark has done just about everything.
Marky_Mark's Photo Albums
Just seen this! All I can say is wow!!! You guys are tops in doing mods like this! Puttin' this on my near future mods list for sure!
  #98 (permalink)
Old 02-01-2009, 07:16 AM
Dealer : Deal & Davie Toyota
Last Online: 09-26-2009 12:14 PM
buddha125 is on a distinguished road.
buddha125's Photo Albums
So, I got all the stuff together, programmed the module, ran the wires, cracked open the passenger side door sill....
and NONE of the wires resemble the ones in the pictures!
I tried metering them with no great results. So if you don't mind, I would like to pick everyones brain a bit.
If you have done this mod and found the wire colours to be different:
1) Anyone have any pictures/wiring diagrams from when they did this mod?
2) I have an '07 Double Cab. Any reason you can think of that mine would be radically different than the Crew Max in this post?
Thanks for your help with all of this!
Cheers,
Sean
  #99 (permalink)
Old 02-01-2009, 08:28 AM
Dealer : Sun Toyota Scion
2007 Toyota Tundra DC Red Pearl 5.7,
- Other - 05 Saturn Vue V6
Last Online: 11-20-2009 06:44 PM
Tundra Tin Man will become famous soon enough.
Tundra Tin Man's Photo Albums
All I have to say is NEAT...............
You tellem HELL'S A COMIN, Im bringing it with me.....
Tundra Tin Man
  #100 (permalink)
Old 06-02-2009, 07:57 PM
Dealer : Carlson Toyota
Last Online: 09-13-2009 01:01 PM
duanels is on a distinguished road.
duanels's Photo Albums
Like the sound of this mod.
I have a topper on my truck.
How would you guys handle that so the automatic tailgate would open?
  #101 (permalink)
Old 06-02-2009, 11:08 PM
Ray Kane
Try this link Dee Zee EZ Down Tailgate Assist
This might help you
  #102 (permalink)
Old 06-02-2009, 11:32 PM
Marky_Mark's Avatar
Rut Ro!
Images: 13
^^Our trucks have that already. This is a different mod, unless you are referring to someone that does not have it already.
"They Were Just Jealous That My Tundra Pulled More Kitty's Than A Bowl Of Milk"
  #103 (permalink)
Old 09-13-2009, 04:34 PM
Last Online: 11-18-2009 11:44 AM
madehtsobi is on a distinguished road.
madehtsobi's Photo Albums
Are the wiring differernt on the 08 models?????
TIA
  #104 (permalink)
Old 09-13-2009, 08:33 PM
catalyst105's Avatar
Last Online: Today 10:08 AM
catalyst105 will become famous soon enough. catalyst105 will become famous soon enough.
catalyst105's Photo Albums
TIA
No, I followed this DIY when I did my 08. Just test the wires before you cut or connect just because there are a lot of wires and similar colors, especially the blue wires.
_______Cardomain_______
  #105 (permalink)
Old 09-14-2009, 11:36 AM
its the front passenger side correct?
which one is the "unlock" wire?
and positive one?
thanks!
LinkBack to this Thread: http://www.tundrasolutions.com/forums/tundra/116550-diy-automatic-tailgate-unlock-lock-projects/
Posted By For Type Date
DIY (Do-It-Yourself) & User Knowledgebase - Tundra Geeks :: The Toyota Tundra Enthusiast Forum This thread Refback 07-18-2009 01:02 AM
DIY (Do-It-Yourself) & User Knowledgebase - IBTO Toyota Tundra Forum This thread Refback 06-30-2009 12:19 PM
DIY (Do-It-Yourself) & User Knowledgebase - IBTO Official Forums This thread Refback 06-07-2009 07:02 PM
Nissan Titan Forum - View Single Post - Keyless Tailgate? This thread Refback 11-07-2008 12:12 AM
