LinkBack (3) Thread Tools Display Modes
  #31 (permalink)
Old 02-02-2008, 04:54 PM
zpaul's Avatar
Dealer : Timonium Toyota
2007 Toyota Tundra CM Ltd
Last Online: Today 08:15 AM
Images: 45
zpaul is a superior contributor. zpaul is a superior contributor. zpaul is a superior contributor. zpaul is a superior contributor. zpaul is a superior contributor. zpaul is a superior contributor. zpaul is a superior contributor. zpaul is a superior contributor. zpaul is a superior contributor.
zpaul's Photo Albums
Default Re: DIY: How-To-Enable DRL – 2007 Tundra
Very nice post!
Do you know by any chance, how DRL should work on Limited if it came with it in AUTO position? Thanks
2007 Toyota Tundra CrewMax Limited 5.7L 2WD, Timberland
  #32 (permalink)
Old 02-02-2008, 04:58 PM
Dealer : Toyota of Plano
2007 Toyota Tundra,
- Other - 2007 Mercedes C230
Last Online: Yesterday 11:48 PM
Images: 61
07DCwhiteSR5 has done just about everything. 07DCwhiteSR5 has done just about everything. 07DCwhiteSR5 has done just about everything. 07DCwhiteSR5 has done just about everything. 07DCwhiteSR5 has done just about everything. 07DCwhiteSR5 has done just about everything. 07DCwhiteSR5 has done just about everything. 07DCwhiteSR5 has done just about everything. 07DCwhiteSR5 has done just about everything. 07DCwhiteSR5 has done just about everything. 07DCwhiteSR5 has done just about everything.
07DCwhiteSR5's Photo Albums
Originally Posted by SGull View Post
Good post, but make sure DRL's using the amber turn signals are legal in your state. In California, they aren't.
uh. yeah whatever. all corvettes made since 97 i guess are illegal in california then, along wth firebirds/trans ams, camaros, many minivans....yeah....im guessing we can ignore this post.
  #33 (permalink)
Old 02-02-2008, 05:01 PM
2007 Toyota Tundra,
Images: 61
ok..jsut so i know, this mod wont allow the temporary disabling of the DRLs with the parking brake on like OEM correct?
  #34 (permalink)
Old 02-02-2008, 09:13 PM
wildbill129's Avatar
Last Online: Yesterday 08:08 PM
Images: 6
wildbill129 will become famous soon enough.
wildbill129's Photo Albums
Yah, I think he was confused. From the CHP's web site:
Driving with just parking lights on (24800 VC). Vehicles that have factory-installed automatic daytime running lights must meet federal requirements and are legal.
2007 Crewmax 4x4 Limited - Silver
2.5" OME Front Lift w/Toytec 1" Diff Drop
1" Toytec Block rear w/Bilstein 5100 shocks
20" Ultra Mammoth Wheels
305/55/R20 Toyo Open Country A/T
Line-X Bed Liner
Undercover Tonneau
Console Vault
Two car seats and a box full of princess toys!
CBTMA Member
  #35 (permalink)
Old 02-06-2008, 09:12 PM
Dealer : Toyota of Augusta
Last Online: 09-28-2009 04:31 PM
jaagee is on a distinguished road.
jaagee's Photo Albums
Toyota does not make it easy to enable the Daytime Running Lights on the Tundra. Nor do they seam to have any interest in helping anyone add them themselves. But that’s ok, like everything else it can be reverse engineered.
If you have an interest in enabling DRL on your Tundra you might want to click on the PDF file attached to this post and save it to your computer.
If you can follow some directions and are capable of soldering a few wires you can get the DRL working.
This design will enable your DRL to operate as follows:
q With Ignition Key “On” the Turn Signal Bulbs (27-watts) light up as the DRL.
q With Headlights “On”, the DRL will be turned “Off”.
q When using the Turn Signal, the DRL for the side you wish to signal will turn off function as the DRL and turn on function as the Turn Signal until the turn indicator is canceled. Once Canceled DRL function will return.
q If you would like to be able to turn the DRL system off at any time you can install an “Optional Switch” (of your choice).
This simple design has been installed for the last three (3) months on seven (7) 2007 Toyota Tundra’s. All have operated flawlessly.
If you would like to enable DRL using the 27-watt turn signals, as Toyota does, on your Tundra this low cost design will work for you.
I hope some will find this useful.
Please see DIY-DRL.pdf attached.
Frank (Daless2)
Thanks for the great, very detailed, write-up. Do you know if this mod has been attempted on a 2008 yet? I have a 2008 DC and I am going to make this mod as soon as the parts arrive. Ordered them today and all sholud arrive in 3-5 business days. I will keep you posted.
  #36 (permalink)
Old 02-19-2008, 04:00 PM
Marsh54's Avatar
Dealer : Toyota Towne of Simi Valley
2008 Toyota Tundra SR5 Desert Sand
Last Online: 03-07-2008 11:06 PM
Marsh54 is on a distinguished road.
Marsh54's Photo Albums
After all of my searching I find your solution to be the one I'm going to try. I do have a question though. Why not use one relay and tie pin 30 to ground. In the normally closed condition that should apply a ground to pin 5 of the relay. When the headlights are enabled that should open the ground disabling the DRL function and have the signal lights operate normally. I just want to make sure I'm thinking correctly.
Thanks for figuring this out.
Marsh54 where are you!
  #37 (permalink)
Old 02-19-2008, 08:36 PM
wileetundra's Avatar
Super Genius
Dealer : Beaman Toyota Co.
Last Online: 11-03-2009 11:15 AM
wileetundra is on a distinguished road.
wileetundra's Photo Albums
Great post Frank. Very detailed and easy to follow instructions.
I might try this however I will probably make it more complicated by installing a computerized switch. I do want to add the DRL function but I also want to add computerized control of the automatic light sensor, so that I can program the ON / OFF times based on the time of day and time of year. This will allow me to specify the headlights to come on at 4:00 pm CST during the dark winter months and 8:00 pm CST during the bright summer months. The factory setting on the auto sensor is never correct and I find it irritating that it incorrectly switches on and off as I drive through tunnels, shadows, cloudy or rainy days, etc. So I plan to use an old PDA that I have on the shelf to replace the auto sensor and control the lights based on my local time zone. The bonus is that it will be completely programmable with all sorts of options. Now I just need to find where the harness connector is for the auto sensor...
WileETundra
view all of my 2007 Tundra mods and photos
  #38 (permalink)
Old 02-22-2008, 02:28 PM
Last Online: 11-11-2009 03:17 PM
abutterworth is on a distinguished road.
abutterworth's Photo Albums
The instructions are great.
I have all the pieces and just want to clarify a point on the use of the Double Relay Plug\Socket.
My Double relay plug\socket came with long wires coming out of each post except on the left 87 post the wire jumps over to the 87 of the other relay. And the left 86 post it also jumps over to the 86 on the right relay.
I am assuming that I am going to cut these jumps and wire exactly as indicated in the diagram.
Is this right?
Also, when using a SPDT rocker switch on wire Relay A wire 86 I think I go into the center post on the switch and out one of the others. Do I leave the remaining post empty?
Thanks.
  #39 (permalink)
Old 02-23-2008, 02:35 AM
re.ac.tor's Avatar
Dealer : Toyota Of Fort Worth
- Other -
Last Online: Yesterday 04:23 AM
Images: 1
re.ac.tor is on a distinguished road.
re.ac.tor's Photo Albums
Thanks.
abutterworth,
I do not know the answer to your first question but can help with the second:
The posts on your switch should be labelled (or the packaging should indicate) that one post is power (positive), earth/ground (negative) and load. The wire in question should connect at the power and load posts and the earth/ground post should be connected to a grounding point on the truck.
Hope this helps, re.ac.tor
CURRENT Tundra:'10 CM SR5 4x2 Constructed & Purchased in September 2009, 5.7L, Sandy Beach Metallic
OLD Tundra:
'07 DC SR5 4x4 Constructed & Purchased in May 2007, 4.7L, Texas Edition,
Enkei Wheels, Nautical Blue Metallic, Sirius InV, Line-X, Recon CCLs.
Drug Information in Lay Language
  #40 (permalink)
Old 02-23-2008, 09:58 AM
gkeas's Avatar
Dealer : Pedersen Toyota
2007 Toyota Tundra Black LTD 4x4
Last Online: 11-12-2009 10:14 PM
gkeas is on a distinguished road.
gkeas's Photo Albums My eBay
Any chance you'd put together a schematic for using the factory fogs as DRL's? That would be far more appealing to me than the turn lamp option. I could probably figure this out myself, but I'm battling a bout of laziness. I hope to be through it soon, but who knows?
Do you really care what truck I have or what mods I've done? Probably not, but here they are any way:
Loaded 07 LTD 4x4 DC 5.7. ARE Cap, Yakima Rack, Toytec 3" Lift, ProComp 8166 Wheels, Nitto Terra Grappler 305/55/20's, Bullhide Spray-In Liner, Volant CAI, Black Headlight Mod, Zoomers Cat back exhaust.
Still to Come: Headers? Speaker/Sub upgrades? What else? Supercharger........? I'm sure I'll think of something.
  #41 (permalink)
Old 02-24-2008, 09:33 PM
daless2's Avatar
Dealer : Toyota On Nicholasville
Last Online: 08-07-2009 07:26 AM
daless2 will become famous soon enough.
daless2's Photo Albums
Hi Marsh,
Sorry for the delay in replying. I was out of town.
You can get by with one relay as pin 30 is in effect already connected to ground.
That said, I can tell you how to do it with no relays too, but both present a problem that is not “Factory Like”. One relay or no relay will turn the DRLs “On” when the ignition key is on. This is good.
But….
Neither of these means (one relay or no relay) will turn the DRL “Off” when the headlights are on. If you don’t mind having the DRLs “ON” when your headlights are on then you can give it try.
To do it with NO Relays, simply cut the gray wire going to pin #5 on J29 and connect it directly to ground. Tape off the other side of this cut wire.
Now when Ignition key is “On”, DRL will be on. They just won't shut off when the headlights are on. (You still need to install the DRL Relay)
Hope this helps you out my friend.
Have a great night,
Frank
  #42 (permalink)
Old 02-24-2008, 09:36 PM
daless2's Avatar
Sounds like a great project you've got going there. I would be interested in learning how you do this.
I should have some time tomorrow. I will try to find the harness connector for the auto sensor you are needing. As I do not have this feature on my Tundra, my source will have to be the factory electrical manual. Perhaps it will help.
Frank
  #43 (permalink)
Old 02-24-2008, 09:38 PM
daless2's Avatar
Is this right?
You got it! Just cut those wires on your double socket and wire things up as shown in the diagram and it will work fine for you.
Have a great evening,
Frank
  #44 (permalink)
Old 02-25-2008, 07:52 PM
Dealer : Dorschel Toyota
Last Online: 10-02-2009 10:42 PM
sandrews002 is on a distinguished road.
sandrews002's Photo Albums
Is there any way to stop the sunroof airdefector on the 07 crewmax limited from changing from the low speed position to the high speed position and just make it stay in the high speed configuration??
  #45 (permalink)
Old 02-26-2008, 10:34 AM
Everything went fine with the install. I now have DRL, so I can now register my Truck in Canada. Thanks!
One thing. If I put the parking brake on and then turn on the truck the DRLs are still on. Did I wire something wrong or does this feature not work. Not concerned unless I have a loose wire somewhere or the job isnt grounded properly.
LinkBack to this Thread: http://www.tundrasolutions.com/forums/tundra/117414-diy-how-enable-drl-2007-tundra/
Posted By For Type Date
DIY (Do-It-Yourself) & User Knowledgebase - Tundra Geeks :: The Toyota Tundra Enthusiast Forum This thread Refback 07-15-2009 11:32 PM
DIY (Do-It-Yourself) & User Knowledgebase - IBTO Toyota Tundra Forum This thread Refback 07-02-2009 02:49 AM
DIY (Do-It-Yourself) & User Knowledgebase - IBTO Official Forums This thread Refback 05-26-2009 12:53 AM
