This is a discussion thread titled "Hitch drop formula…", within the Tundra forum, part of the Truck Forums category.
Old 12-01-2007, 01:03 PM
Dealer : Dublin Toyota Scion
Revived's Photo Albums
Last Online: 11-04-2008 02:18 PM
Revived is on a distinguished road.
Default Hitch drop formula…
This may seem like a silly question for those who tow regularly but, the truth is - I don’t…. Having the tow package for me is more of a “if I ever need to” justification - because it came on the truck anyway…
With that said I would like to get a receiver hitch and ball that can cover most situations…. If that’s possible…. The measurement to the top of the receiver is 19”… I’m guessing a 4” drop…. But before I invest I thought I’d ask some of those in the know here….
Thanks in advance….
Old 12-01-2007, 01:07 PM
Preferred Dealer
Dealer : Toyota Of Stafford
Cliffy1's Photo Albums
Last Online: 11-17-2008 10:12 AM
Cliffy1 is on a distinguished road.
Default Re: Hitch drop formula…
It all depends on the trailer. Its not even just the amount of drop you have to worry about. Its also the size of the ball. If you want something that is likely to handle just about any boat, get a 2" drop and a 2" ball.
If you're just looking for something to have in an emergency, get one of those 0" drop mounts with three different balls already mounted on it. More than likely, it will be a little higher than is optimal for regular towing, but at least you'll be ready for anything.
Now a sales manager at Stafford Toyota in Stafford VA. Call 540-720-4700 and ask for Steve Clifford... they will not know who "Cliffy" is.
Old 12-01-2007, 01:19 PM
Dealer : Stevinson Toyota East Inc
Leardriver's Photo Albums
Last Online: Today 08:18 PM
Leardriver is on a distinguished road.
My 3 trailers all like the flat part of the receiver insert at around 15-16 inches from the ground. On my 4WD DC, that was a 3.5 inch drop insert.
Old 12-01-2007, 01:20 PM
SAM-RAI's Avatar
Dealer : Earnhardt Toyota
2004 Toyota Camry-Solara
SAM-RAI's Photo Albums
Last Online: Today 10:34 AM
SAM-RAI is on a distinguished road.
The rule of thumb is 18"-20" from the ground with hitch height. Although, it's best to measure it and find the exact height for best result. I tow my bass boat a lot and I think 4" or 4 1/2" drop is what I got, but don't remember exactly. Remember, it's best to keep the trailer level with the hitch height and balance your tongue weight if you want best performance.
Hope this help a little!
Sam
" If At First You Don't Succeed, Try And Try Again. "
Old 12-01-2007, 02:08 PM
martino4's Avatar
Dealer : Country Hills Toyota
2007 Toyota Tundra CM LTD 4x4,
- Other - 2007 Toyota Rav4 V6
martino4's Photo Albums
Last Online: Today 09:11 AM
martino4 is on a distinguished road.
Send a message via Skype™ to martino4
yeah it all depends on trailer. i'm using two different trailers Shasta travel trailer - needs 2" drop and 2" ball and for work trailblazer 14' long - same 2" drop but 2 5/16 ball.
i'm using factory ball monts rated 11k pounds, for the second trailer i bouth second mount
black crewmax ltd red rock int
http://i193.photobucket.com/albums/z...4/IMG_0113.jpg
Old 12-01-2007, 02:19 PM
HOGWILD's Avatar
Dealer : American Toyota
2006 Toyota Tundra,
1993 Toyota Truck,
2007 Scion tC
HOGWILD's Photo Albums
Last Online: Today 05:00 PM
HOGWILD will become famous soon enough.
Tips, Specs and Definitions keep your reciepts and buy what you figure will work and go from there! most place have no problem with returns as long as it has not been abused!
Old 12-01-2007, 02:56 PM
Dealer : Wesley Chapel Toyota
weverb's Photo Albums
Last Online: Today 02:54 PM
weverb is on a distinguished road.
Thanks in advance….
I was in the same position as you. I just went to Autozone and they had a Reese 2" drop with a 2" ball set-up with a locking pin. The set-up (kit) only cost $37. Now I have something just incase I need to tow.
Old 12-01-2007, 04:16 PM
Billy Bob's Avatar
Dealer : Northtown Toyota
Billy Bob's Photo Albums
Last Online: 10-24-2008 08:17 AM
Billy Bob may have some regrets.
I have towed a boat for over 30 years and I like the tongue up just a bit as it makes launching a boat easier. I have a 3.5 inch drop on my tongue that I purchased at Walmart when I first got the truck. And actually the Tundra's hitch receiver is lower than on my Ford Escape I traded in.
As said the trailer should tow level or actually lower in the front to prevent swaying in high speed traveling (usually this happens over 60 mile per hour). Also 10 -15% of your total weight should be on the ball to prevent swaying. If your tongue weight is low and it sits up high your probably going to get some sway. However, I have never experience this with my BOAT trailer but I do have the proper ball weight.
Old 12-01-2007, 05:00 PM
Dealer : Downtown Toyota Scion of Spokane
2007 Toyota Tundra DC Limited
blueflash's Photo Albums
Last Online: 11-19-2008 11:06 PM
blueflash is on a distinguished road.
I currently have a couple of lighter trailers to tow. One is a jet ski and the other is a utility trailer for an ATV. I found a 6" drop put the trailers at the correct level. A 2" drop, which is what I used on my old Chevy, is way too high. I borrowed a nice 6" aluminum stinger from a buddy, thinking it would be too low, but found out it was perfect. Nice bonus, my buddy said keep it!
07 Tundra DC Limited, 5.7, Radiant Red, TRD, Nav, Sonar,
Aries Tube Steps, Truxedo Duece, Clearbra, EGR Shield, WeatherTech Liners
Old 12-01-2007, 07:42 PM
Dealer : Prestiqe Toyota
2007 Toyota Tundra,
2003 Toyota Camry
guntech's Photo Albums
Last Online: Today 10:28 AM
guntech will become famous soon enough.
As stated - it depends on the trailer. If you don't own one and just want to be prepared, I would go with Cliffy1's advice.
Old 12-03-2007, 12:35 PM
Dealer : Priority Toyota Richmond
2007 Toyota Tundra,
2006 Toyota Corolla,
- Other - 2006 Mini S Turbo,
2008 Toyota FJ Cruiser
My eBay The Doctor's Photo Albums
Last Online: 06-08-2008 03:05 AM
The Doctor is on a distinguished road.
MAny manufactures make adjustable receivers, covers a very large percentage of needs for about $70.
Old 12-03-2007, 12:44 PM
TUNDRA786's Photo Albums
Last Online: Today 04:17 PM
TUNDRA786 is on a distinguished road.
I have the factory ball mount with a 2 inch reese ball (rated for 6K)
TUNDRA786
2007 Tundra Crew Max 4.7 TRD 4x4
285/65/18's with BF Goodrich All Terrain KO's
BedRug, Undercover, Bed Extender, Husky Liners
Old 12-04-2007, 12:12 AM
asianflava's Avatar
Dealer : Classic Toyota Scion of Round Rock
2001 Toyota Highlander,
2007 Toyota Tundra CrewMax
asianflava's Photo Albums
Last Online: Today 04:10 PM
asianflava is on a distinguished road.
I used one of these formulas and the trailer still wasn't level. I ended up just buying the ones that got me in the ballpark, then returning the ones that didn't work. Wal-Mart has them for a pretty decent price. The only thing is that they are class III rated (I think). The factory one is more robust compared to those, and more expensive.
No one ball mount will work for all trailers, Murphy's Law will gurantee that. If you have one that is the right height, then it will have the wrong size ball. An adjustable height model will get you most of the way there but you still have ball size to contend with. Do not use an undersized ball! Using a 7/8 ball on a 2in coupler is a bad idea. An 1/8th of an inch may not seem like much but it is enough to pop the coupler off the ball at the worst possible time.
