This is a discussion thread titled "how do I?", within the Tundra forum, part of the Truck Forums category.
Old 12-02-2007, 05:40 PM
dduny's Avatar
Dealer : Basil Toyota
dduny's Photo Albums
Last Online: Yesterday 10:40 AM
dduny is on a distinguished road.
Default how do I?
how do i remove the part of the console that houses the shifter and tow haul button/cubby. i pushed something in the cubby and it popped out insed the dash. any help would be appreciated
Old 12-02-2007, 09:40 PM
dduny's Avatar
Default Re: how do I?
anyone?
Old 12-02-2007, 09:48 PM
DavidT.'s Avatar
Dealer : Elk Grove Toyota Scion
2007 Toyota Tundra CrewMax 4x4,
2005 Toyota Tacoma Double Cab PreRunner,
2001 Toyota Tacoma Double Cab
DavidT.'s Photo Albums
Last Online: Today 12:28 AM
DavidT. may have some regrets.
If you have the bucket seats, remove the center console (the part with the three cup holders). Then you will see a plastic screw holding down the rear portion of that silver piece you're trying to take off. Remove the screw, the forward portion where the tow/haul button is, is just clipped on. So just pull back and the whole thing will pop out. Having the shifter in "N" will allow you to pull further back on the trim piece and navigate it out.
2007 Tundra CrewMax SR5 4x4 TRD 5.7
Old 12-02-2007, 10:21 PM
Dealer : Valdosta Toyota
2007 Toyota Tundra,
- Other - 2006 Mustang GT
mtusrsmith's Photo Albums
Last Online: Yesterday 09:24 AM
mtusrsmith is on a distinguished road.
You can also get to the 'cubby' by removing the upper dash cover (the silver thingy surrounding the speedo, etc). It is held in place by clips that will give way with a little tug. There are two harnesses to unplug (one on each side of the steering column) and you have to unclip four clips that hold the vinyl that fills the gaps around the steering column. This allows access from above the 'cubby' plate, which is actually clipped into the larger piece that surrounds the shifter. The cubby itself is clipped into the little plate with the tow/haul button in it, which is in turn clipped into the larger piece surrounding the shifter.
More than one way to skin a cat. I had my dash apart yesterday and moved my rear window switch to the blank right next to the tow/haul button. I was able to do it as described above without removing the console.
Good luck, let us know how it turns out.
SRS
07 Tundra SR5
CrewMax 4x4 5.7L
Old 12-03-2007, 03:07 PM
dduny's Avatar
thanks guys
