Old 12-04-2007, 12:03 AM
fsj's Avatar
fsj fsj is offline
Last Online: 09-23-2009 07:49 PM
fsj is on a distinguished road.
fsj's Photo Albums
Question Is adding the factory Remote Starter easy?
Wondering if adding the factory remote starter is easy for a DIY?
Old 12-04-2007, 12:10 AM
mxsjw's Avatar
Jedi Ninja in Training
Dealer : Toyota of Puyallup
- Other - 2003 VW Passat,
Images: 10
mxsjw's Photo Albums
Default Re: Is adding the factory Remote Starter easy?
Didn't look too bad, check Spark's, they have the directions on their website.
FYI, most of us that have the Factory remote start really don't like it much. Search "factory remote start" for all the reasons.
Beer please!
Old 12-04-2007, 12:28 AM
Dealer : Noral Motors
2007 Toyota Tundra,
2008 Toyota Camry
Last Online: 06-19-2009 12:23 AM
stubblejumper is on a distinguished road.
stubblejumper's Photo Albums
The factory remote start is listed as having an extremely short range,a maximum range of 100 feet.The range will be even less through walls or windows.I would not even consider a remote start with such a short range.
Old 12-04-2007, 12:37 AM
Dealer : Sun Country Toyota
Last Online: 04-07-2009 11:45 AM
KXcam is on a distinguished road.
KXcam's Photo Albums
Don't get the factory one. I have it and should have waited and got an aftermarket one. The factory unit only works at about 30'. It's OK at home where you can start it out the window, but anywhere else (parking lot at a distance) it is useless. Seriously 30' max.
5.7L 4WD CrewMax, Silver Sky, TRD, Remote Starter, Sill Plates X4, Color Matched LineX.
Old 12-04-2007, 08:55 PM
fsj's Avatar
fsj fsj is offline
fsj's Photo Albums
Yes, I understand that the factory one is not very good. But I was thinking that there would be less issues then with an aftermarket one in going into the truck and crimping and soldering wires. Wondering if it voids warranty when someone other then Toyota does the install. I am just paronoid of some bad installer messing up something.
Old 12-04-2007, 09:36 PM
Dealer : Bernardi Toyota
2003 Toyota Corolla,
2007 Toyota Tundra CM LTD 4x4
Last Online: Today 12:44 PM
Bradscc is on a distinguished road.
Send a message via AIM to Bradscc Bradscc's Photo Albums
The dealer will install an aftermarket RS, and then they are responsible for it...they did mine...I think its an AutoMate...works great and is covered under Toy warrantee...B.
Old 12-04-2007, 09:45 PM
Nailbiter's Avatar
Last Online: 11-19-2009 07:15 PM
Images: 3
Nailbiter is on a distinguished road.
Nailbiter's Photo Albums
What did this run ya?
NEW TUNDRA-
08 DC Grade 5.7 4x4 Black/Black, Rhino, A.R.E MX, w/Thule rack
OLD TUNDRA-TOTALED:
07 DC SR5 5.7 4x4 Black/Black, Line-X, Leer 180 w/ Thule rack
http://www.tundrasolutions.com/forums/off-topic/126782-crash/
Old 12-05-2007, 01:41 PM
Dealer : Bredemann Toyota
Last Online: 12-02-2008 12:57 AM
admirlkirk is on a distinguished road.
admirlkirk's Photo Albums
Default Don't Get The Factory Remote Starter!!!
Don't do it. It has short range and as soon as you unlock the door to load up something, the truck shuts off. I had a remote starter (which I installed) in my 1997 Dodge Ram. It worked threw walls and from inside my house. This one does not. I could also start the truck up and load or unload it while it was running. This one does not. I also could take the key out of the ignition (after pressing a button) so I could unlock my cap and unload, all while the truck was running. Toyota's does not. You are much better and probably cheaper to get an after-market remote starter. Toyota just put a cheap one in and charged a premium for it. I'll probably end up removing Toyota's and put in my own.
Old 12-05-2007, 02:09 PM
ThirdHorseman's Avatar
Apocalyptic Wit
Dealer : Toyota Of Turnersville
Images: 14
ThirdHorseman has blessed us with their presence. ThirdHorseman has blessed us with their presence. ThirdHorseman has blessed us with their presence. ThirdHorseman has blessed us with their presence.
ThirdHorseman's Photo Albums
I want one too! I was considering the Toyota system, but maybe I need to do some more reading.
Old 12-05-2007, 04:48 PM
Last Online: 04-02-2009 01:48 AM
TUNDRA786 is on a distinguished road.
TUNDRA786's Photo Albums
yeah it seems it would be useful on cold days. How much does an aftermarket one run? what brand is a good one to go with?
TUNDRA786
2007 Tundra Crew Max 4.7 TRD 4x4
285/65/18's with BF Goodrich All Terrain KO's
BedRug, Undercover, Bed Extender, Husky Liners
Old 12-05-2007, 05:05 PM
override's Avatar
Dealer : Mayfield Toyota
2007 Toyota Tundra Slate Metallic TRD
Last Online: 10-22-2009 03:06 PM
override is on a distinguished road.
override's Photo Albums
Definately go with an after market one. you will be more options, range and 2-way if you want it. plus you can have the door locks programmed on it too and get rid of the factory door remotes.
The ONLY downside to an aftermarket one is that you lose your Valet key...
Old 12-05-2007, 05:06 PM
Nailbiter's Avatar
Images: 3
Cold days in Houston?
Huh?
NEW TUNDRA-
OLD TUNDRA-TOTALED:
Old 12-05-2007, 05:17 PM
Paul Gilley's Avatar
Dealer : Phil Bachman Toyota
Last Online: Today 04:38 PM
Paul Gilley is on a distinguished road.
Paul Gilley's Photo Albums
Had aftermarket remote starter installed by a great technician. I ordered a Code Alarm remote that has a minimum of 500 feet range. Seems to be a very good quality unit. After truck starts a light flashes to let you know that truck has started. Installation and unit cost was approx. $300.00. Sure beats the toyota deal in my book.
07 Tundra, 4X4, slate metallic, 5.7 engine, TRD duals, reg. cab, standard bed (6.5 length), Steelcraft stainless step bars, Lund bug shield, Carriage Works billet grill insert, Weathertech in-channel vent visors, Scangauge II.
Old 12-05-2007, 05:22 PM
it was like 36 in the day before yesterday.... its not really really cold.
My biggest reason would be is i have a 0.7 mile drive to work and by the time i get to work my truck usually isnt warmed up well.
TUNDRA786
Old 12-05-2007, 05:39 PM
lcdrbrentcarroll's Avatar
Dealer : Priority Toyota
2007 Toyota Tundra Silver DC LTD,
1998 Toyota Camry,
- Other - 2005 Jeep Wrangler
Last Online: 11-04-2008 08:27 AM
lcdrbrentcarroll is on a distinguished road.
lcdrbrentcarroll's Photo Albums
Good thread. I've been debating in my mind for a few weeks.
I read through the OEM install directions from Sparks. I consider myself a DIY-er, but this looks like a tough nut to crack. You gotta take essentially the whole dash apart as well as the steering column...
Prolly end up just paying someone to install and aftermarket.
2007 DC LTD, Silver Metallic. MODS: Line-X Bedliner; Toytec 3" Lift; HUGE Moto Metal 20" Wheels and 35*13.5*20 Procomp Xtreme A/T Tires; Sirius Radio; Nuvo GPS Navigation; Hornblasters; Black Westin Bull Bar with fog lights; Northern Tools Tool Box; TRD CAI; Color-matched Fender Flares; Boorla Catback Dual Exhaust; Infinity Kappa Series Speakers all around.
***Pics in gallery.
