Originally Posted by Demo8BX68
how do you guys like your fmj's? a friend installs PE stuff and has had nothing but problems in about a years time after they were purchased, mainly delamination of the panels, hopefully they corrected it, i am interested in one and he hasn't really installed any after he had problems
I've only had the FMJR less than a month, so way too early to tell if there is a long term problem. The FMJR doesn't have any vinyl; it's all aluminum, so I don't think that was the version your friend had a problem with though.
I'm very impressed with the FMJR. I have a Roll-N-Lock on my 2001 Dakota Quad and like the FMJR a lot more. The R-N-L has a real problem with debris getting into the canister and blocking the drain holes. The canister then fills with water and leaks into the bed. THE FMJR's cannister opening is much tighter then the R-N-L's and the drain tubes are larger. Only time will tell if this solves the problem though.
The installation is very simple, although I did have a problem with my bed liner (Perma Guard installed by the dealership).The liner wouldn't let the canister position close enough to the front of the bed; this caused the rails to stick about 1/4" too far at the tailgate end. I had to cut out part of the bed liner to allow the cannister to fit against the front of the bed.
The FMJR uses the factory rails to mount, so the installation is very fast. (There's a clamp option for trucks without rails.) The only problem with the installation is that the Toyota OEM rail clamps wont fit under the FMJR. The knob for tightening them is too large. When I get a chance, I've got to see if I can make the knobs smaller with a Dremel tool.
