LinkBack (12) Thread Tools Display Modes
  #151 (permalink)
Old 02-26-2008, 01:54 PM
Dealer : Toyota of Morristown
Last Online: 06-23-2009 08:12 AM
rackman is on a distinguished road.
rackman's Photo Albums
Default Re: Possible Tundra Bed Bounce CURE FOUND
I am a first time Toyota owner and have owned an '07 Crew Max SR5 with the TRD package since March 2007. I live in New Jersey and have the bed 'shake'. I met with a factory rep. last week and took him for a drive. He explained to me that the rear portion of the frame is designed to flex to improve ride quality. Toyota's position is that there is no need for a correction as this is not a problem. However, this does not mean there would not be a recall in the future. I am a lifelong GM owner and do not understand why Toyota would design a frame that flexes, when my '01 and '03 Chevy HD's had stable beds/ frames and smooth rides for large trucks.
I tried installing a pair of Rancho RS9000XL adjustable shocks on the rear and although there seemed to be a slight improvement with a softer setting, it did not correct the problem. I now have some reservations about my switch to Toyota. As I told the rep. when it comes time to buy a new truck one of my considerations will be do I want a truck with a stable bed or a flexy one? Tundra sales will probably be affected somewhat if Toyota does not acknowledge and address this issue.
Based on what I have read and heard so far I think welding the cross members and perhaps adding tubular cross supports may be the only cure.
  #152 (permalink)
Old 02-26-2008, 04:10 PM
DanielAcosta's Avatar
Dealer : Earnhardt Toyota
2007 Toyota Tundra,
2009 Toyota Venza,
- Other - 05 Honda Odyssey
Last Online: Yesterday 10:15 AM
Images: 13
DanielAcosta is on a distinguished road.
DanielAcosta's Photo Albums
I have changed rear shocks as well as the rake on my truck. Today I am trying different tires as well as a different, heavier spare that I hope will emulate the foam spacer someone else reported as curing the bounce. Will be trying the SoCal freeways in a couple weeks and will report back.
07 DC SR5 TRD 4x4 5.7 TRD exhaust, 46K miles, 17 mpg city after battery disconnect reset. Truxedo Lo-Pro with deck rails. Front Susp: Stock coilovers, 4" lift (http://www.tundrasolutions.com/forum...6-4-inch-lift/), swapped extra spacers for Bilstein 5100s on lowest setting, wheel well height still 41.5." Rear Susp: ProComp ES3000 #326510 (2.25" taller than stock), 1.25" blocks plus PRG mini-pack (http://www.tundrasolutions.com/forum...and-new-truck/) gives 2.25" total lift, parking brake cable bracket spacers, wheel well height 43." Front diff and rear ds drop; trailer hitch electrical harness tucked up above bumper. After 20K miles swapped 305/65/18 BFG AT for 285/75/18 Toyo AT, still on stock 18x8x60 offset TRD wheels, about 1/8" clearance to sway bar. Like the extra height but miss the width. Next time either 305/70/, 295/70, or 35x12.50/18. Added 5th 285/75/18 Toyo AT as spare. Bed Bounce: Stiffer E-tires are worse than stock P-metric; biggest improvement from PRG mini-pack, slight improvement from shocks. Still a stiff ride but tolerable now. Best things about this truck: 5.7 and transmission, interior size and comfort, very quiet at high speed. Worst things about this truck: bed bounce, no VSC in 4wd, mileage sucks above 70.
  #153 (permalink)
Old 02-26-2008, 05:55 PM
Dealer : Toyota Cap-a-l'aigle
- Other -
Last Online: 04-17-2008 09:04 PM
Griffy may have some regrets.
Griffy's Photo Albums
Thumbs up Re: Possible Tundra Bed Bounce CURE FOUND
Originally Posted by moto22 View Post
I think some guys are referring to different things here. From where I sit there are 2 issues - and this is how I have termed them:
1. "Bed Bounce" - meaning the bed shakes back and forth and the suspension begin a harmonic oscillation that occurs on evenly spaced concrete road expansion joints. This results in a herky-jerky ride that is, from reports, extremely annoying. I have not felt this yet but have not been on a road that would cause it. Obviously all beds have some independent movement between the cab and bed - but the inability of the chassis to handle spaced bumps without doing the pogo pogo is a problem.
2. "Chassis Harmonic" - This is the one I feel - which is a vibration that reverberates through the chassis AFTER a single bump has been absorbed by the suspension. This, to me, feels like a shock that has lost its rebound control - though I know that is probably not the cause.
Interestingly enough, every truck I've owned or driven regularly has done both of those is varying degrees (worse in the 3/4 tons). My last personally owned truck was an '03 F150 SuperCrew, which did the same kind of things. I was able to tone it down a bit by installing some RMX Monotubes from Les Schwab. I did not expect it to go away completely, but the ride did improve.
I think a lot of the issue is that many Tundra owners just dont have a lot of experience with large trucks, particularly 3/4 ton type trucks (which the Tundra resembles a little more than the typical 1/2 ton). As a result, the reaction from the Tundra seems out-of-whack to them.
It IS a large truck, with a typical large truck frame (unlike the current F150 or Silverado). Its not going to act like a car or even an SUV in most situations. To expect it to, isnt all that reasonable. Load your truck up with cargo/trailer, and it acts exactly the way it should.
  #154 (permalink)
Old 02-26-2008, 09:57 PM
Last Online: 08-04-2009 05:36 PM
frankg is on a distinguished road.
frankg's Photo Albums
I live in southern CA in the Palm Springs area. The worst part of I-10 is in the Banning / Beaumont area. I drive it on a regular basis. Lanes 1&2 (left side) are the bad lanes. Lanes 3&4 (right side) where the semi's roll are fine.
I have owned many dozen's of trucks over the years. Currently I own 04 ec/sb duramax, 05 rc/lb duramax, 91 chevy 2500 rc/lb and 08 Tundra 5.7 rc/sb.
In this section of I-10 all these trucks will suffer from this bounce. I won't call it BED bounce because the whole truck will experience it. Some trucks are worse than others, all depending on wheelbass, weight and design. My Tundra is easily the worst in this regard. When driving on this stretch of interstate by myself, the passenger seat will be shaking so bad you'd think it would break off it's mounts. Believe me, it's really bad.
On the other hand, on most roads this truck rides like a Mercedes. Firm but smooth. I added a TRD rear sway bar and it seemed to help but it's still pretty bad. It's obvious that there is a problem here.
Having said that, I love this truck and am willing to be stuck behind the semi's when driving this road. When there is a fix I will be one of the first to jump on it. If anyone finds it, please keep us informed.
  #155 (permalink)
Old 02-26-2008, 10:01 PM
Dealer : Riley Toyota
Last Online: 11-12-2009 10:11 PM
jarheadfor4 is on a distinguished road.
jarheadfor4's Photo Albums
I drive a section of I-44 in Missouri and it is driving me nuts. My truck drives like a champ and very comfortable except for the concrete sections of highways.
I love my Tundra, but it is embarrassing when it shakes that bad and honestly, it makes my stomach sick.
I've ridden in every vehicle known to man and the shakes on the concrete sections are out of control.
2007 Toyota Tundra 5.7
ENOUGH SAID!!!
  #156 (permalink)
Old 02-26-2008, 10:21 PM
Dealer : Carson Toyota Scion
Last Online: 07-04-2009 01:45 AM
Skyler may have some regrets.
Skyler's Photo Albums
I live in Southern Cali and have had to deal with the nightmare vibrations too. I would try putting about some weight ( 200-300lbs.) in the bed near the tailgate for about 3-4 months while you're breaking it in and see if it mellows out. I had some polymer shackles installed and it helped somewhat but a bit pricey @ $479.00, but a noticeable difference. IMO try the weight in the back first for a few 1k miles and I think you'll notice a difference.
  #157 (permalink)
Old 02-27-2008, 07:44 AM
Art64's Avatar
2007 Toyota Tundra RCSB5.7SR5WHTSports
Last Online: Today 12:01 AM
Art64 will become famous soon enough.
Art64's Photo Albums
There is really no fix for this unless you modify your rear suspension. If you loaded your truck with 500 lbs on the bed, it will ride smoother on these roads. I've already replaced the stock shocks, installed sway bar, installed Class V hitch (SAP), replaced the overload springs with a 3-leaf mini pak. They do help a lot in cushioning the vibes. This week I ordered Alcan leaf springs to replace the factory springs. The springs will ride soft. I'm also going to install Firestone air bags for heavy loads. Hopefully this mod will finally end the bounce, vibes issues for empty truck. Costs a lot of money, but its worth it since I'm keeping the truck for a long time. Customized suspension.
  #158 (permalink)
Old 03-04-2008, 02:58 AM
Dealer : Mayfield Toyota
- Other -,
2008 Toyota Tundra 08 DCSB 4x4
Last Online: 11-14-2009 11:41 PM
can't stop spinning is on a distinguished road.
can't stop spinning's Photo Albums
I just picked up my 08 dc 4x4 yesterday morning, and the bed shakes like crazy. The roads where I live suck, and have lots of rough joints/cracks in them. You can see the bed shake everytime you hit a joint. About 1/2 the bumps cause the box to shake the cab of the truck. It's very easy to see the bed still shaking or vibrating even after the bump.
I've never driven another 1/2 ton on these sections of roads before, but I have driven 3/4 and 1 tons, and they all feel a lot more solid, and don't shake like my Tundra. My Dad's 96 Dodge w/ almost 300k on it feels more solid on these joints then my brand new truck. It's rather disappointing after spending 40k on a truck to have this happen.
  #159 (permalink)
Old 03-04-2008, 11:33 AM
steelpony5555's Avatar
Dealer : Fiore Toyota
Last Online: 12-24-2008 01:53 AM
steelpony5555 is on a distinguished road.
steelpony5555's Photo Albums
also, all trucks that are in two pieces (i.e. not avalanches, el caminos etc) have parts of the body that move independently from one another. its a fact of life. if you guys think this so called "bed bounce" is an issue, try driving in an 80s or even older pickup. the beds werent even lined up when parked most of the time. things have improved tremendiously over the years but some people just cannot accept a truck is a truck and the bed wiggles. who cares
Ditto---over the past 10-15 years or so the big 3 started catering to the women and now the suspenions on their 1/2 tons is no different the a full size sedan. Drive a 1/2 ton chevy with a load in its bed and feel how mushy it feels---just like an old station wagon--but they had to please the little women--and if women had to drive an 80's or later pickup they would not have the sales of 1/2 tons they have now--they now build them as the family vehicle---a truck is built to give it's best ride with at least 1/2 of their max weight on-I said a "truck" now--if you want the car like ride them buy a big 3--Tundra is a truck and over bumps the bed is gonna bounce and if there's lots of bumps it's gonna be a basketball---You guys in Ca. dont know what bumps are till you get to Pa. or N.Y. --we got bumps you could lose your mother in law in---this truck does have a stiff suspension just go to a chevy ford lot and jump on the rear bumper and then jump on a Tundras and then tell me it's not stiff--Japan built it as a truck and a dang fine truck it is..
2007 4.7 Reg Cab 2WD SR5 long bed white Tundra.
Towing 6000 lbs of Travel Trailer with no issues!!
  #160 (permalink)
Old 03-04-2008, 12:09 PM
Dealer : Cedric Theel Toyota
2008 Toyota Tundra 4x4, Black
Last Online: Yesterday 09:06 PM
dafoot is on a distinguished road.
dafoot's Photo Albums
I am glad this issue continues to be on this site. Toyota reads this site. They need to be reminded this problem has not gone away. I live in ND. My 07 bounced like craze over a certain part of I94. My 08 is the same way. It's my belief their is a design flaw that Toyota needs to correct.
  #161 (permalink)
Old 03-04-2008, 05:23 PM
Dealer : Kearny Mesa Toyota Scion
2008 Toyota Tundra,
2007 Lexus ES350
Last Online: 11-07-2009 10:03 AM
Images: 10
GMoney749 is on a distinguished road.
GMoney749's Photo Albums
Amen.
2008 Toyota Tundra SR5 DC 5.7L
2007 Lexus ES350
2003 Infiniti FX35
1971 Datsun 240Z
2005 BMW K1200S
2003 Ducati 749S
This...is....TUNDRA!!
  #162 (permalink)
Old 03-04-2008, 06:15 PM
- Other -
Indeed.
  #163 (permalink)
Old 03-04-2008, 06:18 PM
TUNDRA-ID's Avatar
Dealer : Peterson Toyota
Last Online: 05-21-2009 01:08 AM
Images: 3
TUNDRA-ID is on a distinguished road.
TUNDRA-ID's Photo Albums
It has been mentioned before, the road condition will have an effect on the ride of the vehicle. Some vehicle will handle it a little better than the other on certain road conditions. The Tundra handles very well overall. I've been driving the same freeway to work 5 days a week for the last 10+ years. I driveway about 6 miles of freeway and 2 miles of it has older concrete that will cause any vehicle to feel the "bounce". As I remember the Tundra does not bounce any worse than my last 2 pickups (2002 GMC crewcab, 2005 Nissan Titan), but maybe just a tad stiffer.
My brother-in-law borrow my pickup a couple weeks ago and he gave me his 2007 Ford Expedition to drive to work. It bounces also on the 2 mile stretch of the old concrete freeway. No as bad, but noticeable. The Tundra is best pickup I've owned so far and I've owned several pickup trucks since 1992.
2007 5.7 Crewmax 4x4 Limited, Slate Metallic
20" Ultra Goliath, 305/55R20 Toyo Open Country AT
2.4" Readylift front w/ 1" Toytec rear blocks
  #164 (permalink)
Old 03-05-2008, 02:23 AM
SPEEDY5.7
Dealer : Mike Calvert Toyota Scion
Last Online: 06-12-2009 12:46 AM
Images: 20
TOMMYDAWGG76 is on a distinguished road.
TOMMYDAWGG76's Photo Albums
2008 REG CAB 5.7 SPORT PACKAGE......
MCGAUGHY'S 4/4 DROP KIT, AIR RAID CAI, MAGNAFLOW CAT BACK EHXAUST, 22" INCUBUS WHEELS, BILLET GRILLE, CHROME DOOR HANDLES,CUSTOM LEATHER INTERIOR, CARBON FIBER TRIM & STEERING WHEEL, SPORT PEDALS, PAINTED MIRRORS, FRONT & BACK BUMPERS, CALIPERS, ENGINE COVER, "HURST" SHIFTER, PIONEER Z3 NAVIGATION, 6000 HID'S LOWS & FOGS, TUNDRA RACING REAR VALANCE, BILLET UPPER GRILL ON HOOD, LEDS IN OVERHEAD LIGHTS AND LISCENCE PLATE LIGHTS, DOOR SILL PROTECTORS, CARBON FIBER STEERING WHEEL... MORE TO COME, TRUST ME...
  #165 (permalink)
Old 03-05-2008, 04:45 AM
GraetWhyte's Avatar
Dealer : Toyota Of Fort Worth
2007 Toyota Tundra DCab Ltd 4x4 Silver
Last Online: 09-25-2009 11:22 AM
GraetWhyte is on a distinguished road.
GraetWhyte's Photo Albums
Maybe this is really a banging on the bed from the spare. Maybe it just needs to be tightened. After I installed the spare lock I noticed that I may have not gotten it as snug as it is from the factory so every now & then I get a thump on the bed from the spare area.
LinkBack to this Thread: http://www.tundrasolutions.com/forums/tundra/119409-possible-tundra-bed-bounce-cure-found/
Posted By For Type Date
Consumer Reports 2008 Hybrid Cars, Consumer Report Reviews Buick Rendezvous, Consumer Reports Best Car Tires - Classiccommercials This thread Refback 03-08-2009 03:40 AM
Toyota Tundra Bed Bounce Issue: Our Position | Tundra Headquarters . com This thread Refback 02-06-2009 11:00 PM
PickupTrucks.com Forums: Yet another sign of Toyota's "Superior quality"... This thread Refback 06-06-2008 10:31 PM
RV.Net Open Roads Forum: Tow Vehicles: Tundra problems/Consumer reports - Are they real? This thread Refback 05-07-2008 12:35 PM
F-150 vs Tundra - Page 2 - ClassicBroncos.com Forums This thread Refback 04-28-2008 07:56 PM
RV.Net Open Roads Forum: Tow Vehicles: Tundra problems/Consumer reports - Are they real? This thread Refback 04-21-2008 10:26 PM
Good Sam Club Open Roads Forum: Tundra problems/Consumer reports - Are they real? This thread Refback 04-21-2008 09:45 PM
Trailer Life Magazine Open Roads Forum: Tundra problems/Consumer reports - Are they real? This thread Refback 04-21-2008 08:24 PM
RV.Net Open Roads Forum: Tow Vehicles: Tundra problems/Consumer reports - Are they real? This thread Refback 04-21-2008 06:05 PM
Woodalls Open Roads Forum: Tow Vehicles: Tundra problems/Consumer reports - Are they real? This thread Refback 04-21-2008 02:50 PM
Trailer Life Magazine Open Roads Forum: Tundra problems/Consumer reports - Are they real? This thread Refback 04-21-2008 12:13 PM
RV.Net Open Roads Forum: Tow Vehicles: Tundra problems/Consumer reports - Are they real? This thread Refback 04-21-2008 12:09 PM
