LinkBack (12) Thread Tools Display Modes
  #421 (permalink)
Old 10-25-2008, 02:26 AM
los211's Avatar
Dealer : Piercey Toyota Scion
2007 Toyota Tundra,
2005 Toyota Sienna The wifes "bus"
Last Online: Yesterday 05:46 AM
Images: 6
los211 is on a distinguished road.
los211's Photo Albums
Default Re: Possible Tundra Bed Bounce CURE FOUND
My good friend has an '07 f250 crewcab 4x4 long bed and the ride in that truck is way worse than mine ever was. He carries alot of weight for work but when its not loaded down it rides really stiff. But that is just a very stiff ride. He does get the "shaker cab" once in a while like my tundra but its only limited to certain areas and mine will do it on every pot hole, man hole cover, uneven surface changes, and speed bumps etc. I have calmed it down a lot but still shows its ugly face once in a while. Normally a truck being of any make, model, 2wd or 4wd has some type of bed wiggle but the Tundra has a fisical shake that shakes everything in the cab. I think that is the main complaint in this thread.
'07 SR5 DC 5.7 silver sky metalic
5% tint rear windows, 2 Flowmaster 40 series w/ dual tips out the back, Carriage Works polished grill overlay w/emblem, 3-piece bumper inserts (not CW), Airaid, Ground Force rear shocks, DJM 3" arms, belltech flip kit, 22" BOSS 329 w/ 305/45/22 General grabber UHP, G2 bakflip.
  #422 (permalink)
Old 10-25-2008, 12:08 PM
ballin's Avatar
Dealer : Alexander Toyota of Franklin
2007 Toyota Tundra,
2004 Toyota 4Runner
Last Online: 11-09-2009 10:06 PM
Images: 18
ballin is on a distinguished road.
ballin's Photo Albums
Originally Posted by Keto View Post
My F250 bounces/jars a lot, more so than my Tundra. The F250 is very stiff in the back stock, so when unloaded its a little more rough on some of the same surfaces (though I have BFG C-T/A's on that truck). Both trucks have the same general behavior, the severity varies. I can tell you right now, theres no way an undladen F250 rides smoother with stock, or close to stock suspension, than a Tundra.
i am talking about the springy a$$ end on the tundra. the tundra rides great on flat paved roads, but once you hit a sharp bump or pot hole the bed bounces like a 18 wheeler. i have followed 3/4 tons and have watched the bed of those trucks and in no way are the hopping around like the tundras. let your tailgate down on your tundra and put both hands on the tailgate and push down hard real fast and let go and do the same to your ford and the tundra is way more springy.
07 tundra 5.7, 4x4,trd, dc, sr5 blk-readylift,1'' toytec block,305/65/18 bfg's,chrome door handles,tint,hatchie bottoms custom seat covers, true duals flowmaster 10 series race mufflers w/h-pipe
  #423 (permalink)
Old 10-25-2008, 03:38 PM
Dealer : Stephen Wade Toyota
Last Online: 11-18-2009 05:35 PM
Sean Dempsey is on a distinguished road.
Sean Dempsey's Photo Albums
I have a few hundred miles on my 08 DC, 2wd, shortbed, and I don't know what bed bounce is or if it I have it.
I've take it on a few 50+ mile freeway trips, and I haven't noticed anything or ever though "could that be the bed?"
So maybe it's worse in some than others, but so far I've not noticed anything I'd consider annoying our unusual.
  #424 (permalink)
Old 10-27-2008, 10:09 AM
Dysan911's Avatar
Dealer : Arlington Toyota Scion
Last Online: Today 01:01 AM
Dysan911 is on a distinguished road.
Dysan911's Photo Albums
I have to believe that for the most part these trucks are made the same.. It's not likely one was built so different that it would experience Bed Bounce and others won't. I believe every Tundra has Bed Bounce, it's just the owners may not realize it because of:
A. They have really smooth roads and rarely travel anywhere that has poor road conditions.
B. Use the truck for hauling and or towing equipment all the time, thus the added weight is eliminating any of the effects of bed bounce.
C. The driver is so oblivious to what BB is because he's driven heavy duty trucks his entire life, and that likely had worse BB than the Tundra i.e. Ford F250, etc..
So, you gotta fall under one of these categories above if you think you don't have it.
  #425 (permalink)
Old 10-27-2008, 10:39 AM
Toy Collector's Avatar
Last Online: 11-20-2009 04:35 PM
Toy Collector is on a distinguished road.
Toy Collector's Photo Albums
Originally Posted by ballin View Post
i have rode in f-250's, duramax's etc. they are far more of a work truck than the tundra. they have more payload, more towing power and they do not bounce like the tundra. the tundra is a workhorse for a half ton, but if you think theres nothing wrong with the bounciness, then toyota has you right where they want you. when not fully maxed out with weight, people just want a non brain jarring ride over certain road surfaces..
My brother has a 2004 Crew Cab Dually and a 1994 Crew Cab Diesel and they both ride way worse than the Tundra ever could on it's worst day.
You're very right... they do not bounce like the Tundra... they bounce TEN TIMES worse than the Tundra.
Like I said before... if you want a better ride... buy a Civic or a mini van... not a truck.
  #426 (permalink)
Old 10-27-2008, 11:03 AM
insaneR6's Avatar
Dealer : Bel-Air Lexus Toyota
Last Online: 11-05-2009 09:49 AM
Images: 18
insaneR6 is on a distinguished road.
insaneR6's Photo Albums
Well, here's something that people could try. Obviously we can see the Tundra is setup stiff, as it was apparently beefed up to handle the capacity better.
Now, most of the comparisons right now are between the Tundra and other 1/2 tons, and it rides much harsher. More bed bounce, which is really the stiffer suspension causing a visual bounce of the bed and a bouncy cab ride. There's a post here not to long ago where someone did some measuring and noticed a lot of things are 3/4 ton sized on the Tundra (axle, etc). Not to mention the fact the tundra frame is the same design as the other brands HD trucks (F250, F350, RAM 2500, etc) if i remember correctly?
People have driven the other 1/2 tons on test drives and noticed the expansion joint issue isn't as much of a problem on the F150s and etc. People driving 3/4s say the tundra is of course way better (to be expected) but all smooth out when loaded.
So, go back and do a test drive with those same trucks, but load the ever loving cr@p out of them. Show up for your F150 test drive with a 10'000lb trailer or a full bed toolbox full of gear and see how the ride compares over those same expansion joints or when braking, etc. See if there's a ride difference then. I would like to see the results of that ride comparison.
2008 4.7L Double Cab Radiant Red + TRD Package, Wrangler SilentArmors, N-FAB Steps
  #427 (permalink)
Old 10-27-2008, 01:58 PM
TUNDRA-ID's Avatar
Dealer : Peterson Toyota
Last Online: 05-21-2009 01:08 AM
Images: 3
TUNDRA-ID is on a distinguished road.
TUNDRA-ID's Photo Albums
Took my family to Disneyland and Seaworld for a week in California this summer and rented a Dodge Charger for the week while down there. IMO, it's definitely the Cal. freeway that's causing the bounce. At certain sections of the freeway, it feels like the front wheels of the Charger is hopping off the pavement. I can understand why the Tundra would produce such a harsh ride for owners in this region.
2007 5.7 Crewmax 4x4 Limited, Slate Metallic
20" Ultra Goliath, 305/55R20 Toyo Open Country AT
2.4" Readylift front w/ 1" Toytec rear blocks
  #428 (permalink)
Old 10-27-2008, 03:48 PM
bigpapa's Avatar
Dealer : Rudy Luther's Toyota
2007 Toyota Tundra,
2003 Toyota Corolla,
- Other - 1998 Honda Civic EX
Last Online: 08-15-2009 09:23 PM
bigpapa is on a distinguished road.
Send a message via Yahoo to bigpapa bigpapa's Photo Albums My eBay
Up here in Minnesota don't ya know we have the bounce too. 694 has been redone in the North St. Paul area right at 35e n/s and When my truck is empty with nothing in the box it bounces really bad. My poor dogs trying to sleep in the back I bet are a bit upset with the uncomfortable ride they are experiencing. I know that my cab bounces with it because I feel it up on my seat as well. I have the TRD package on my truck. Every Friday I go to my distributors and pick up product for my retail store and even with the bed fully loaded top to bottom (top being up to the soft tonneau cover on the back closed) with about 20 cases of liquor in it and with all that liquid and glass (weight) it still bounces all over the place.
One of my customers just came in and he drives a F350 that is maybe 8 months old or so. He says fully loaded drives like a caddy but once he takes out the load in the back its like our trucks and bounces all over the place.
Personally I think that the roads have something to do with it but I also feel that Toyota could have possibly worked something a little better than this with the truck. Its a great truck and I am not getting rid of mine anytime soon because of a bounce. I have hauled almost 3000# of concrete with my truck and it didn't even hit the stops yet. I love this machine....for those who think its only Cali....drive 694/35e or 494 south in Plymouth in Minnesota and you will see its probably a combo of roads and truck build. Either way we do own the safest truck of its class on the road and that is why I bought my mainly. My family can be safe
'07 Crewmax TRD SR5 Slate Metallic JBL 12 spk, Power Moonroof, Cold Start, Tow, HomeLink rear view
MODS
AstroStart auto start, TrailFX Nerf bars, Tundra AW floor mats, Access Limited Edition soft tonneau cover, vent shades, magnaflow exhaust, Color match headlights, Volant CAI, fully debadged, bolt on Billet Grill, LED interior lights, door sill protectors,Truxxx Leveling Kit, 20% tint front windows 5% tint back three windows, TRD rear sway bar, sport shifter, sport brake/gas pedals, color match door handles
After I get off my @$$ mods
Power locking tailgate, auto open tailgate,
Line-x Bed Liner, rear window button moved on the dash, RAV interior with heated seats
  #429 (permalink)
Old 10-27-2008, 04:39 PM
I know that shocks have an effect on the issue... it would be interesting to do a poll and see how many of us have the stock black Toyota shocks and how many have TRD (blue and yellow Bilstien) shocks. I had an '06 Double Cab with the TRD package and my Mom has an '05 without the TRD package. I detailed both trucks religiously and drove them both all the time. My truck with the blue and yellow Bilstiens had a much better ride than my Mom's truck. The difference was so great that sometimes I thought I jumped into my 4runner instead of my Mom's truck. My new '08 does not have Bilstiens as future plans call for a complete ICON setup so I bear with the ride I have, KNOWING IT CAN improve with better shocks.
I would still like to drive a CrewMax with the following:
-Complete ICON suspension setup
-Complete King suspension setup
-Complete standard Bilstien (TRD) shock setup
...And see the differences. I don't think that would be possible any time soon though.
  #430 (permalink)
Old 10-27-2008, 08:07 PM
ballin's Avatar
2007 Toyota Tundra,
2004 Toyota 4Runner
Images: 18
if your brothers trucks were 10 times more springy than the tundra it would be completely undriveable. l like my truck and it meets my needs but if you dont see a problem with the springy bed then good for you cause i do. i dont drive cars either fyi. the shocks you think will fix the problem, wont.
  #431 (permalink)
Old 10-27-2008, 09:04 PM
Dealer : Putnam Toyota
Last Online: 10-07-2009 09:28 PM
joshp is on a distinguished road.
joshp's Photo Albums
Interesting, I've heard the complete opposite. Those with the TRD offroad package state it is far worse than the standard suspension at least on the 2007+
  #432 (permalink)
Old 10-27-2008, 11:19 PM
- Other -
Last Online: 09-13-2009 09:01 PM
Keto is on a distinguished road.
Keto's Photo Albums
Do-It-Yourself Re: Possible Tundra Bed Bounce CURE FOUND
"Springy"? Both are sprung on the stiff side for sure. The F250 is stiffer for obvious reasons. Both have the same bounce and reverb effect on sharp obstacles, more pronounced on the 250.
I dont see how a bed can "hop around" since its bolted to the frame. If you mean the twisting/bending motion or the reverb effect, the reaction really isnt all that different between the 2 trucks. Just more severe (harshness) on the 250. You hit a really sharp bump in the F250, it'll knock your teeth out, and you'll see that bed move.
Keto
12" lift on a 2wd = EPIC FAIL
  #433 (permalink)
Old 10-27-2008, 11:32 PM
Dealer : Findlay Toyota Scion
Last Online: Today 12:19 AM
vegasheat is on a distinguished road.
vegasheat's Photo Albums
Shocks & springs have nothing to do with the bounce. I've replaced my shocks with the Rancho Adj. and tried every setting. Not one setting worked to stop or slow down the bounce. I've mentioned this before that it's in the frame where the double "C" meets the single "C". There is a week spot there that if you look at your back seat while all the bouncing is going on...you will see your seat bouncing where the 2 "C's" meet. Try not to have an accident while looking back. You can take a passenger with you and have them look while you drive.Others have changed their springs and shocks..all it did was make their truck stiffer.
When my warranty runs out, I may have a fab shop weld or bolt a piece in that area where they meet to make it stronger.
  #434 (permalink)
Old 10-27-2008, 11:33 PM
Forgot to mention that I also tried the foam under the spare tire. Didn't work.
  #435 (permalink)
Old 10-28-2008, 12:20 AM
Dealer : Centennial Toyota Scion
2007 Toyota Tundra CM, SR5, 4X4, 5.7,
1995 Toyota T100 2.7L,
- Other - '01 Ford F-250 Crew Cab, V10
Last Online: 11-20-2009 06:43 PM
Time4change is on a distinguished road.
Time4change's Photo Albums
You also forgot to mention that you didn't try softer springs.
I've mentioned it before.......it's not the frame.
The only thing fabbing something up to your frame would affect warranty wise would be your frame.
'07 Cmax, SR5, 4X4, 5.7......'01 Ford F-250 Crew Cab, V10.....'95 T-100, 2.7L......and about 10 other vehicles that I don't want to bore you with.
LinkBack to this Thread: http://www.tundrasolutions.com/forums/tundra/119409-possible-tundra-bed-bounce-cure-found/
Posted By For Type Date
Consumer Reports 2008 Hybrid Cars, Consumer Report Reviews Buick Rendezvous, Consumer Reports Best Car Tires - Classiccommercials This thread Refback 03-08-2009 03:40 AM
Toyota Tundra Bed Bounce Issue: Our Position | Tundra Headquarters . com This thread Refback 02-06-2009 11:00 PM
PickupTrucks.com Forums: Yet another sign of Toyota's "Superior quality"... This thread Refback 06-06-2008 10:31 PM
RV.Net Open Roads Forum: Tow Vehicles: Tundra problems/Consumer reports - Are they real? This thread Refback 05-07-2008 12:35 PM
F-150 vs Tundra - Page 2 - ClassicBroncos.com Forums This thread Refback 04-28-2008 07:56 PM
RV.Net Open Roads Forum: Tow Vehicles: Tundra problems/Consumer reports - Are they real? This thread Refback 04-21-2008 10:26 PM
Good Sam Club Open Roads Forum: Tundra problems/Consumer reports - Are they real? This thread Refback 04-21-2008 09:45 PM
Trailer Life Magazine Open Roads Forum: Tundra problems/Consumer reports - Are they real? This thread Refback 04-21-2008 08:24 PM
RV.Net Open Roads Forum: Tow Vehicles: Tundra problems/Consumer reports - Are they real? This thread Refback 04-21-2008 06:05 PM
Woodalls Open Roads Forum: Tow Vehicles: Tundra problems/Consumer reports - Are they real? This thread Refback 04-21-2008 02:50 PM
Trailer Life Magazine Open Roads Forum: Tundra problems/Consumer reports - Are they real? This thread Refback 04-21-2008 12:13 PM
RV.Net Open Roads Forum: Tow Vehicles: Tundra problems/Consumer reports - Are they real? This thread Refback 04-21-2008 12:09 PM
