LinkBack (12) Thread Tools Display Modes
  #46 (permalink)
Old 12-17-2007, 01:28 PM
Trucker1967's Avatar
2008 Toyota Tundra DC 5.7 4X4
Last Online: 11-04-2009 09:57 PM
Trucker1967 is on a distinguished road.
Trucker1967's Photo Albums
Default Re: Possible Tundra Bed Bounce CURE FOUND
Negative? how are my posts negative?
I did not say the spare tire trick would not work in any way
Again think about why the spare tire would work, it quells the harmonics!!!!!!!!!
If anyone is being negative its you
  #47 (permalink)
Old 12-17-2007, 01:36 PM
Dealer : Crown Toyota Scion
Last Online: 10-21-2009 09:23 PM
Wgasa84 is on a distinguished road.
Wgasa84's Photo Albums
Originally Posted by Trucker1967 View Post
lol well I sure was not saying 100,00 trucks in anyway ... it seems you assume that every truck has this issue and thats not the case by any means ... just some have it and it's not only on bad roads as you state.
Like I said they recalled a few driveshafts so that proves they arent using the same exact correct part in every truck ... things will slip through.
Oh and by the way I love Tundra's this is not a smear campaign its just food for thought to get to the bottom of this issue and I think an easily correctable one once the right ingrediants are in place.
Bearings, gears and axleshafts are required to have very tight tolerances, unless toyota went with some chinese bearings, and changed from their gear cutter. I will still bet that it has nothing to do with the vibration people (myself included) are feeling.
Watch a Silverado, F250/250... etc. go down the same highway, their frame flexes at the bed/cab also....
  #48 (permalink)
dkizerian's Avatar
Dealer : Mark Miller Toyota
1997 Toyota T100,
2007 Toyota Tundra DCSB SR5 Slate
Last Online: 11-04-2009 04:17 PM
dkizerian is on a distinguished road.
dkizerian's Photo Albums
Slow down there Chief... look at who's post I was quoting... not yours.
You've been making suggestions of other things that you think could be causing this problem.. Even if I don't agree with your suggestions, at least they're productive, and better than somebody just saying Bed Bounce doesn't exist because I don't have it.
07 4x4 DC 5.7 SR5
  #49 (permalink)
Old 12-17-2007, 01:47 PM
Sorry if I was doing that
My thinking however is that their are 2 issues, one of a harmonic one and one of where some Cali people are experiencing on bad roads, they may have something in common but not quite the exact same issue.
  #50 (permalink)
Old 12-17-2007, 02:04 PM
apintheca's Avatar
Dealer : Ventura Toyota Scion
Last Online: Today 12:37 AM
Images: 3
apintheca is on a distinguished road.
apintheca's Photo Albums
This Did Not Work For Me!!!
The only time I ever feel the bed bounce is on slab freeways here in SoCal. Everywhere else it is fine. It has to just be that it is that stiff. Especially considering I have a RCSB 2wd and the same leafs that would be on a Crewmax 4x4.
The truck handles like a dream! But even when I climb onto the tailgate the truck doesn't even drop down a 1/4inch! When I jump up and down it might compress 1/2inch if i'm lucky. I only way 160lbs but still this thing is HD to the max. When I had a lil over 1000lbs in the bed it didn't even sag the rear end at all it was still way up there.
The tonneau helped tons though! Especially with off the line traction, traction around corners and traction in the rain.
I'll be installing the Ground Force Lowering kit on my tundra at the beginning of January and i'll let you know how it rides after that. It comes with all new front coils and rear leafs.
Performance: TRD Big Brake Kit, TRD Rear Sway Bar, Donahoe Racing Coilovers, Rancho RS9000XL Rear Shocks, Toyota Carve 20's with 285/55/20 BFG G-Force KDW2's, Volant CAI, Gibson Catback, DT Headers
Lighting: 4300k HID Lows and Fogs, 4100k Silverstar Ultra Highs, Blacked out Headlights, Reverse Light Mod with 50watt each back up bulbs, Bed Light mod with 50watt each bulbs
Exterior: Limo Tint All the way around, Leer 550 Tonneau Cover,
Stereo: Pioneer AVIC-Z2, Infinity Basslink II, Polk DB650's, Polk 3.5 Dash Speakers
Mods To Come: TRD Supercharger, DR Rear Brace, Painting Rear Calipers Red, Smoking out Taillights
http://youtube.com/watch?v=TuaS5NIXfYA
  #51 (permalink)
Old 12-17-2007, 03:12 PM
apintheca's Avatar
Images: 3
Pickup Truck Traction Control System, Full Size Truck Bed Weight, Axle, Wheel Hop
  #52 (permalink)
Old 12-17-2007, 03:50 PM
Dealer : Modesto Toyota World
Last Online: 04-20-2008 01:55 AM
sloopy is on a distinguished road.
sloopy's Photo Albums
I’m sure anyone with an engineering background would understand the bed bounce issue. All trucks have it under certain conditions. Just because you don’t recognize it, or experience it doesn’t mean it isn’t there. Nothing is perfect for every usage so all is a compromise. Under certain conditions, this condition is annoying enough to warrant trying to come up with a remedy for these people.
The cause has to do with the shocks, springs, frame and their geometry to one another. Regardless, it makes since that using the tire as a counter balance to dampen the oscillations may work. An air ride suspension with variable rate shocks would be a great alternative, however unrealistic in the price range that most trucks fall into. I have heard that the new Dodge ½ ton may be coming up with a totally new rear drive train, suspension and geometry. From what I have read, it may be a major break through and has the potential to deal with many of these issues. First thing, is that it will not use any leaf springs.
  #53 (permalink)
Old 12-17-2007, 05:43 PM
Dealer : Gander Toyota
2008 Toyota Tundra CM LTD Salsa Red,
2000 Toyota Avalon XLS with Moon Roof
Last Online: Today 02:43 PM
stuball is a glorious beacon of light. stuball is a glorious beacon of light. stuball is a glorious beacon of light. stuball is a glorious beacon of light. stuball is a glorious beacon of light. stuball is a glorious beacon of light. stuball is a glorious beacon of light.
stuball's Photo Albums
I drove my '08 Tundra back from South Carolina to British Columbia 3300 miles and my only encounter with bed-bounce was on I-25 north of Denver to the Wyoming State Line. I watched the bed bounce through my rearview mirrors. IMO, the cause of bed bounce in Tundras is not a Toyota design issue, but due to some freeways badly in need of repair. The freeway wasn't designed or built that way.... just allowed to deteriate to it's present poor condition.
Stuball
  #54 (permalink)
Old 12-18-2007, 12:05 AM
Canadian_Yoda's Avatar
Dealer : Northern Toyota
Last Online: Yesterday 12:34 PM
Canadian_Yoda is on a distinguished road.
Canadian_Yoda's Photo Albums
Originally Posted by dillinja666 View Post
ya ill rip that bizzle out tommorow and go for a drive...
Sweet! Let us know how that works out.
  #55 (permalink)
Old 12-18-2007, 01:50 AM
Dealer : Toyota Carlsbad
Last Online: 06-23-2008 03:32 AM
iamnid is on a distinguished road.
iamnid's Photo Albums
Originally Posted by medicdubs View Post
A great example is the 710 and 91 freeways. You locals know what I'm talking about. So Basically what I'm getting at here is, guys from Texas and Colorado shouldn't be flipping out about never feeling the bed bounce, like I shouldn't flip out because my truck doesn't drive well in the snow or my de-icer doesn't work when there heavy ice on my mirrors. What the hell would I know about snow and Ice conditions?
Amen.... or try driving the 101 from Sherman Oaks to Ventura - thought my teeth were going to fall out.
And personally, I think "bed bounce" is a misnomer -- the ENTIRE TRUCK bounces up and down. Stuff falls of the seats, drinks spill out of the top of the can and the center console pops open because everything is shaking so bad in the cab on these stretches of the freeway.
  #56 (permalink)
Old 12-18-2007, 11:49 AM
Last Online: 05-05-2009 04:26 PM
tundrahq is on a distinguished road.
Send a message via AIM to tundrahq tundrahq's Photo Albums
I'm disappointed that some people can't acknowledge and respect this problem -- the results of the bed bounce survey we did show that it's a significant and real problem independent of geography, wheel base, cab type, TRD package, etc. If you feel like being critical of the people having this issue, maybe you should keep your thoughts to yourself.
ANYWAYS...
So far it looks like only a couple of you have tried this out. I noticed that one of you used foam that was 1" thick, and that one of you didn't specify.
When we were putting this article together, we tried to determine what kind of foam was being used and we haven't figured it out yet. However, this is a difference between "closed cell" foam and other types of foam you'll find at the hardware store, etc. We'll try and find a cheaper source of foam and buy it in bulk if this cure works like we hope it will.
Also, our reader that came up with the fix suggested tweaking the tightness of the spare tire to get the best results.
We've got a couple of volunteers waiting for the pad to arrive at their door. Once it gets there they'll install it and let us know how it went for them.
Nuts about the new Toyota Tundra. Visit Tundra Headquarters for tips, tricks, news and reviews.
  #57 (permalink)
Old 12-18-2007, 12:16 PM
mxsjw's Avatar
Jedi Ninja in Training
Dealer : Toyota of Puyallup
- Other - 2003 VW Passat,
Images: 10
mxsjw's Photo Albums
No it showed that you got only 102 people to agree to whine about it.
You didn't even provide a section for all the people that don't want to complain to be surveyed.
I stand by the fact...THIS IS A NON ISSUE AND TOYOTA WILL DO NOTHING ABOUT IT.
Petition your state and local governments to fix your roads, you'll get more than 102 people to agree with you and they will drive every make and model vehicle.
But for you 102 people, sorry you feel something is wrong with your trucks, hope you figure something out.
Majority is going to win on this issue, and the complaints are the minority...FACT
Beer please!
  #58 (permalink)
Old 12-18-2007, 12:26 PM
FlatironsDreamer's Avatar
Dealer : Ehrlich Toyota
Last Online: 11-02-2009 04:51 PM
FlatironsDreamer is on a distinguished road.
FlatironsDreamer's Photo Albums
We'll add you to the "bed bounce denier" group. Why do you feel compelled to criticize and deny what others are experiencing? And how do you know you're in the majority based on an Internet forum? I would argue only Toyota knows the answer and they're telling people a fix is in progress.
  #59 (permalink)
Old 12-18-2007, 12:35 PM
Jdmcx's Avatar
Dealer : Jordan Toyota
Last Online: 10-30-2009 11:15 PM
Jdmcx is on a distinguished road.
Jdmcx's Photo Albums
This is just off the top of my head I got to thinking of how a fluid dampener worked and this is what I came up with.
How about some type of high-density rubber tube (inner tire tube) filled with fluid silicone based ECT. That might work to cancel out the oscillation
  #60 (permalink)
Old 12-18-2007, 12:49 PM
Sounds like a good idea, I was just thinking anyone remember those stretch toys you could stretch their arms and legs like a mile (toy from the 70's) ... they made the "Hulk" and a bunch of others ... well mine busted open when I was a kid and there was some kind of very heavy Red Gel inside them ... one thing I remember was punching the one I had and that thing would absorb energy like nobodies business ... something with that stuff in it, between the tire and frame would prolly work fantastic.
I am in no was saying using a "Hulk" but I pictured that thing between the tire and the frame and it did seem sort of funny lol
LinkBack to this Thread: http://www.tundrasolutions.com/forums/tundra/119409-possible-tundra-bed-bounce-cure-found/
Posted By For Type Date
Consumer Reports 2008 Hybrid Cars, Consumer Report Reviews Buick Rendezvous, Consumer Reports Best Car Tires - Classiccommercials This thread Refback 03-08-2009 03:40 AM
Toyota Tundra Bed Bounce Issue: Our Position | Tundra Headquarters . com This thread Refback 02-06-2009 11:00 PM
PickupTrucks.com Forums: Yet another sign of Toyota's "Superior quality"... This thread Refback 06-06-2008 10:31 PM
RV.Net Open Roads Forum: Tow Vehicles: Tundra problems/Consumer reports - Are they real? This thread Refback 05-07-2008 12:35 PM
F-150 vs Tundra - Page 2 - ClassicBroncos.com Forums This thread Refback 04-28-2008 07:56 PM
RV.Net Open Roads Forum: Tow Vehicles: Tundra problems/Consumer reports - Are they real? This thread Refback 04-21-2008 10:26 PM
Good Sam Club Open Roads Forum: Tundra problems/Consumer reports - Are they real? This thread Refback 04-21-2008 09:45 PM
Trailer Life Magazine Open Roads Forum: Tundra problems/Consumer reports - Are they real? This thread Refback 04-21-2008 08:24 PM
RV.Net Open Roads Forum: Tow Vehicles: Tundra problems/Consumer reports - Are they real? This thread Refback 04-21-2008 06:05 PM
Woodalls Open Roads Forum: Tow Vehicles: Tundra problems/Consumer reports - Are they real? This thread Refback 04-21-2008 02:50 PM
Trailer Life Magazine Open Roads Forum: Tundra problems/Consumer reports - Are they real? This thread Refback 04-21-2008 12:13 PM
RV.Net Open Roads Forum: Tow Vehicles: Tundra problems/Consumer reports - Are they real? This thread Refback 04-21-2008 12:09 PM
