I just want to know if anyone here has experienced the craziness that happens after driving over a speed-bump at about 10 mph. Once my truck's back wheels clear the bump the back oscillates for a few seconds up and down. I am a member of the 'bed-bounce" community and just want to know if this goes hand and hand with the issue. I recently got to drive a members truck and tried it out because he doesn't have the "bed bounce" issue and lo and behold no oscillations on his CM truck. On a side not he didn't believe me when I told him about the ride quality of my truck but after he drove it his exact words were, "Holy s***, dude, that's not normal."
My truck does a little wobble if I go over a speed bump at any speed other than the granny crawl. Only 2-3 oscillations then its good to go. No biggie to me.
Ride hard, die young and leave a good looking corpse. Now that I'm older...
07' DC 4x2 SR5, TRD CAI, TRD Dual Exhaust, TRD Sway Bar, Line-X
That is how my '07 DC reacts when it goes over a speed bump at speeds greater than 3 mph. My father in law has an '07 CM and his didn't seem to have quite as much vibration. I don't think that I suffer from bed bounce but his truck seemed to vibrate a little less.
My bro has a chevy 3500 and if you hit a speed bump at more than crawling speeds the whole back end bounces around like crazy but that is just because of the stiffer suspension.
If I were you, I would kill myself.
The wobble is a lateral movement of the suspension. I just had the TRD sway bar installed and the next time, (it will be after the 1st of Jan because of all the psycho Christmas shoppers and after Christmas returns), I am in a parking lot I will test the wobble reduction capacity of the sway bar.
Shocks reduce abruptness of the suspension compression and rebound. I don't think the stiffer Bilstein shocks in the TRD package would significantly reduce the lateral wobble. I'm no engineer or mechanic so one of those folks please chime in...
I reported on this several months ago on a bed bounce thread. My oscillation is quite pronounced at 3-10 mph over 'most' speed bumps. I have an 07 DC 4x4 and have added the TRD Anti Sway bar so the thread above saying this helps is wrong. Logic would have it that the problem lies in the frame stiffness and potentially the rear suspension. the sway bar addresses side to side movement not up and down.
__________________ Hman - Sacramento
2007 Tundra Silver DC 5.7
4x4 Limited with Navigation
Brushed Stainless Running Boards
Borla Dual Side Exit Stainless Exhaust
20" Alloys, Sonar, TRD ASB,
R1 sport pedals, Bedrug
Very interesting thread............Am I reading this correctly; no Crewmax on the list???
Crewmax here, (TRD) and no wierdness.
'07 Cmax, SR5, 4X4, 5.7......'01 Ford F-250 Crew Cab, V10.....'95 T-100, 2.7L......and about 10 other vehicles that I don't want to bore you with.
Here's another DC that does it. It doesn't bother me much though. I'll be installing that "bed bounce fix" (the pad under the tire) soon, maybe that will help.
I have several speed bumps on the street in front of my office building. My 07 TRD DC acts quite normal when going over the bumps regardless of speed. It does not have the sway bar.
I have also yet to find any roads that lead to any abnormal bed bounce. Matter of fact, this is the smoothest riding truck I have ever owned or riden in.
__________________ Keith 2007 Toyota Tundra SR5 TRD Double Cab - 5.7L - Super White
I hope the fix works for you, gun, I did it already with no improvement on the bumps.
