This is a discussion thread titled "4WD question......", within the Tundra forum, part of the Truck Forums category.
Old 12-30-2007, 05:56 PM
Dealer : Toyota of Greenville
riptide36v's Photo Albums
Last Online: 10-19-2008 07:31 PM
riptide36v is on a distinguished road.
Default 4WD question......
Is it recommended that all wheels be spinning at the same rate when putting in 4wd when shifting-on-the-fly or is it okay to shift while tires are spinning like say in the mud and you are going about 20 mph? Also, can you put in 4wd while you are backing up as in going up an incline?
Thanks,
Don
Old 12-30-2007, 06:24 PM
Dealer : Mid City Toyota
- Other -
Skyhammerz's Photo Albums
Last Online: Yesterday 08:53 AM
Skyhammerz is on a distinguished road.
Default Re: 4WD question......
Don't switch to 4wd when the rear tires are spinning. Take your foot off the throttle then switch to 4wd.
2007 Tundra DC, 5.7, Limited, 4X4
TRD, NAV,TOW
Afe Stage 2
Xlerator Exhaust
Desert Sand Mica
mhadden's Avatar
Dealer : Toyota Of Merrillville
2007 Toyota Tundra 5.7 CrewMax
mhadden's Photo Albums
Last Online: 04-08-2008 02:03 PM
mhadden is on a distinguished road.
You can try to engage in all those instances, but it may not be a smooth transition. You may get a clunk, or it may hesitate to engage. if you need 4wd, its better to engage it before you need it rather than it being too late.
2008 Honda CR-V EX AWD
2008 Honda Civic LX
Old 12-30-2007, 06:41 PM
rockstate45's Avatar
Dealer : Roger Smith & Sons Toyota
rockstate45's Photo Albums
Last Online: Today 04:29 AM
rockstate45 is on a distinguished road.
Agreed. Yesterday I needed it because I didn't want to back down 100 feet to get a running start. What happened was I was going up this steep hill in a neighborhood. The other guy coming my way didn't want to yield to the parked cars on his side of the street so I had to come to a stop. Couldn't get going again with all my might so I needed to put it in 4wd. It worked well but for some reason I ALWAYS have slip initially, even though I always wait for it to become fully engaged in neutral.
It's hard on the truck to engage 4wd when your foot is on the throttle. Inclines are pretty hard but I've had to use mine on inclines and so far haven't had any problems with engagement or disengagement.
-rockstate
Old 12-30-2007, 07:19 PM
OneOfTheSick's Avatar
Dealer : Dorschel Toyota
- Other - 1991 Dodge Stealth,
2008 Toyota Tundra DCLB
OneOfTheSick's Photo Albums
Last Online: Today 08:41 AM
OneOfTheSick is on a distinguished road.
I'm not sure how much damage it does, but I put it in 4wd while spinning the rear tires once in my 2000 and it jolted the truck pretty hard. When engaging 4wd something has to match the speed of the front and rear tires so if its not you its the truck, and unfortunately it doesn't have a synchro for that. As for reverse there shouldn't be a problem with that.
Old 12-30-2007, 08:27 PM
Dealer : Cedric Theel Toyota
2008 Toyota Tundra 4x4, Black
dafoot's Photo Albums
Last Online: Yesterday 08:18 PM
dafoot is on a distinguished road.
Oneofthesick, Where did you get your hitch cover? Thanks
Old 12-30-2007, 08:28 PM
Dealer : Noral Motors
Someguy123's Photo Albums
Last Online: Yesterday 09:41 PM
Someguy123 is on a distinguished road.
you gotta think about what that is doing to the truck. if you have even a minor speed difference between front and rear wheels. that will shock the hell out of the driveline. you have quite a bit of rolling mass on the front end. when you shift to 4x4, it engages a gear in your transfer case to connect the front to the rest of the driveline. so the front end doesnt have time to get up to speed. it goes instantly from whatever speed it is travelling, to the speed of the driveline. with spinning tires, you run a good chance of breaking a gear in the transfer case. not sure if toyota warranty will cover that??
2007 Tundra LTD CrewMax, Black
2006 Chrysler 300 SRT8, Brilliant Black, Tinted Windows, Full Stereo, 22" wheels, Magnaflow hi-flo cats, Corsa cat-back exhaust, VORTECH SUPERCHARGED
2005 Yamaha R1, Blue
Old 12-30-2007, 08:29 PM
Billy Bob's Avatar
Dealer : Northtown Toyota
Billy Bob's Photo Albums
Last Online: 10-24-2008 08:17 AM
Billy Bob may have some regrets.
If your going STRAIGHT down a road you can put the truck into 4 HIGH at anytime. Just don't make ANY turns on hard pavement. I do this at least once a month to lube the 4 wheel drive components. The owners manual recommends you do this for 10 miles each month but I have never gone that far in 4 wheel drive.
Silver Sky / All Black Interior 4X4 DC 4.7 L
Truxport Soft Roll Up Tonneau Cover
Bridgestone REVO'S 265-70-18
WeatherTech Floor Liners
Rampage Running Boards
Wheelskin Leather Wrap
Auto-Dim Mirror
Old 12-30-2007, 09:27 PM
Dealer : Prestiqe Toyota
2007 Toyota Tundra,
2003 Toyota Camry
guntech's Photo Albums
Last Online: Today 01:06 AM
guntech will become famous soon enough.
You should always let up on the gas when you shift into 4X4. Will you get away with it if you don't? Maybe, maybe not. I'm not about to take that chance.
Old 12-30-2007, 10:35 PM
Dealer : Bob Tyler Toyota Scion
DesertSandAZ's Photo Albums
Last Online: 11-28-2008 05:48 PM
DesertSandAZ is on a distinguished road.
I do the same thing. I've switched to 4H going 45 mph before. Shifted smoothly and everything. Yeah, after it changes, its a bitch to turn, but you can easily shift into 4wd at anything under 62 mph, which is what toyota says is the top speed.
Old 12-31-2007, 03:03 AM
Got it on ebay two years ago. I think this is the same one/same seller. eBay Motors: Toyota Tundra Trailer Hitch Plug - Receiver Cover (item 200186645652 end time Dec-31-07 16:38:33 PST)
Old 12-31-2007, 10:43 AM
AlaskaCub's Avatar
Dealer : Auto Service Company
2005 Toyota 4Runner SR5 4x4,
2007 Toyota Tundra TRD 5.7L DC SR5 4x4
AlaskaCub's Photo Albums
Last Online: Today 01:18 AM
AlaskaCub is on a distinguished road.
Theres a difference between driving and putting it in 4wd and spinning the wheels and engaging 4wd (dont do that). I shift into 4 wd at speeds up to 55mph or so and its not a big deal, I just let off the gas for a second or and then reapply throttle. Like others stated, its a pretty big shockload on you drivetrain if you switch to 4wd while the tires are spinning and somethings got to give, may not do it the firs time, but I wouldn't make it a habit.
07 Tundra DC TRD 4WD 5.7L Desert Mica
Oh and I dont use spell check!
Old 12-31-2007, 11:01 AM
Thanks, that was what I needed to know. So, you can do the same while going in reverse, just not the 55mph part!!
Old 12-31-2007, 06:01 PM
AlaskaCub's Avatar
Yes reverse is the same thing, just wait for the VSC off light to come on and the 4HI symbol to light up. Takes less than a second or so and then get after it!
