LinkBack (5) Thread Tools Display Modes
  5 links from elsewhere to this Post. Click to view. #1 (permalink)
Old 01-02-2008, 11:04 PM
Dealer : Star Toyota
Last Online: 10-18-2009 09:45 PM
Totex is on a distinguished road.
Totex's Photo Albums
Default Bigger gas tank.
Do you people think the same way I do about the gas tank being too small? Does any body knows if there is a safe after market option for this purpose?
Tundra DC, 5.7 CAI (by AFE) 22 inch Magnaflow, long bed, 4x4, leather, 6 inch Pro Comp lift, Hypertech in line speedometer calibrator module, 5000 lbs Ride Rite air bags on rear,35's Toyos, 18x8 1/2 polished black rims, rear view camera, rear sonar, spray on liner, bug shield, Tint front wdws (20% to match de rear), nerf bars, tool box, pioneer nav with JBL amp, blue tooth, XM radio, DVD player, 6 CD, Hunter bull bar (kept towing hooks), KC lights, tow mirrors, all weather mats, Viper 5900 alarm.
Old 01-02-2008, 11:13 PM
07bsmcrewmax's Avatar
Dealer : Fred Anderson Toyota of Raleigh
Last Online: Yesterday 11:10 PM
07bsmcrewmax is on a distinguished road.
07bsmcrewmax's Photo Albums
Default Re: Bigger gas tank.
A bigger gas tank would be nice. It does cost alot to fill up now (coming out of a civic!). And even though it would cost even more with a bigger tank, its gas, you will use it eventually. I dont know of any aftermarket gas tanks available for the tundra. As hard as it is to get a frickin tuner or a decent stereo, it will probably be a while for a gas tank.
Old 01-02-2008, 11:16 PM
willy's Avatar
Dealer : Mic Mac Motors
- Other - '41 Chevy 1/2 ton,
2007 Toyota Tundra DC 4WD LB
Last Online: 09-06-2009 09:10 AM
willy will become famous soon enough.
willy's Photo Albums
I know of no Tundra specific replacement larger tanks. Most of those are made for Ford, Dodge, and GM as they are obviously more prevelant in industry use. However, there's tons of in-bed auxillary tanks available. Here's some links.
AeroTanks-we specialize in auxiliary fuel tanks.
ATTB - Auxiliary Fuel Tanks
Aftermarket and OEM Fuel Tank Systems
Northwest Metal Products - Since 1977
With the aux. tank in the bed of my wk truck, I have an 800 mile range and it's great. I'm thinking of building an auxillary tank to go underneath the bed of my Tundra, as I have a longbed and there's tons of room down there. You could also have a local shop build you one to your specs. There's nothing real technical to them. A 26 gallon tank is useless, and makes no sense when there's clearly room for a 40+ gallon tank under there.
Insert witty signature here...
Old 01-03-2008, 12:31 AM
Dealer : Toyota of Huntington Beach
Last Online: Today 02:07 AM
wells service is on a distinguished road.
wells service's Photo Albums
Since i have a shell and a raised carpet kit, i am thinking of putting the spare in the bed and mount a 20 gal in place of the spare. i will either use a low pressure pump to transfer the fuel or tap into the bottom of the stock tank and let the gas flow down. do you think 46 gal is enough?
Old 01-03-2008, 12:55 AM
Well if you are toyota, the 20 gallon tank would still leave you with about 6 gallons after the gas light came on. J/K That extra 20 gallons would be nice. Im not to educated on these matters so pardon my ignorance, but would you have to have a separate fill neck or would it work with the factory one? Im guessing an extra one
Old 01-03-2008, 08:06 AM
Dealer : Leith Toyota
2007 Toyota Tacoma
Last Online: 07-31-2009 05:05 AM
Tundra Man 2007 is on a distinguished road.
Tundra Man 2007's Photo Albums
I am not very patiently waiting for Transfer Flow to come out with one. I bet thiers will be +40 gallons. In my Duramax they put a 45 gallon where a 28 gallon used to be. I just don't understand why people build trucks with such small tanks but all of the manufactuers do it.
Kirk
2007 Black 5.7 DC 4 x 4
Dual Borla Exhaust
Old 01-03-2008, 08:23 AM
willy's Avatar
Transfer Flow's website (Aftermarket and OEM Fuel Tank Systems) doesn't state that they make replacement takes for any makes besides Dodge, Ford, and GM. Do you have information to the contrary, or are you just hoping?
Old 01-03-2008, 08:29 AM
I WOULD PROBABLY HAVE TO USE A SEPERATE FILL NECK .
Old 01-03-2008, 08:35 AM
cwit's Avatar
Dealer : New Country Toyota
2007 Toyota Tundra,
2006 Toyota Camry-Solara black moon roof
Last Online: Today 07:31 AM
Images: 3
cwit is on a distinguished road.
cwit's Photo Albums My eBay
I want to buy gas where I want to not were my gague tell. I do a lot of towing and a lot of times I have to stop at a poor place to get in and out of ,or a interstate that is very high priced because of the gotya factor. I like the spare tire area this .is a good place for the tank, lots of room.
Charlie & Linda
Old 01-03-2008, 08:38 AM
willy's Avatar
When it's an additional tank, in most cases yes - you just put a second filler neck on them. You can route that fill neck in a number of locations, including the wheel well, near the back bumper (convert to a drop down license plate? - maybe the hitch is in the way), or possibly even squeeze it in next to the existing fill neck so that'd it be accessed behind the same fuel door. Putting it in the wheel well is most common.
If you want to put an inbed tank in a bed that has a pickup shell on it, then that's no big deal either, as you can run a fill neck through a camper shell (see example near bottom of this link, Transfer Flow cross-the-bed tanks). That's how mine is setup on my work truck, although both the tank and the fill neck through the shell setup were made locally. The auxillary tank gravity feeds to the main tank, but I'd recommend a pump for the only reason that I forget to shut off the (gravity feed) valve sometimes, and when they're both near full and I leave the valve open over night, it will overfill the main tank and push fuel out of the fuel system via the fuel system breathers in the engine compartment.
With a 46 gallon fuel capacity, as one of you asked about, assuming an average of 16 mpg, that'd give you a range of 736 miles. What I would recommend is that if you're going to go to the trouble to run a second tank, then get the largest auxillary tank that you can fit without sacrificing your ground clearance (if it's underneath) or taking up more room then you can afford to lose (if it's an inbed tank).
I live in the middle of nowhere, in a town of 4,000 people. It's 200 miles in any direction to a larger town. I do a lot of highway driving both alone and on family trips. It's nice not to have to fill up every time you have to stop for the bathroom, and with a larger tank you can avoid filling up in the middle of nowhere where the gas prices are sometime through the roof. Gas is currently $3.30/gal in my town.
Old 01-03-2008, 09:50 AM
Dealer : Swope Toyota
Last Online: 10-07-2009 04:51 AM
Jonesky is on a distinguished road.
Jonesky's Photo Albums
I would love a 100 gallon tank on mine under the bed. Probably not enough room but still...........
Old 01-03-2008, 11:26 AM
2007 Toyota Camry HV,
2007 Toyota Tundra CM, 5.7, Limited
Last Online: 09-15-2009 12:13 PM
ag4ever is on a distinguished road.
ag4ever's Photo Albums
I e-mailed Transfer flow a few months back, and they said if the demand was great enough they would make one.
We just need to keep sending them demands for them via e-mail or phone calls so they know we are willing to buy one.
My name is on the list, is yours?
Old 01-03-2008, 11:48 AM
TX RN's Avatar
2005 Toyota Avalon Touring Package,
2007 Toyota Tundra DC Timberland Mica
Last Online: 11-01-2009 06:12 PM
TX RN will become famous soon enough.
TX RN's Photo Albums
Wouldn't it be alot less expensive to buy 4 five gallon gas cans and keep them strapped down in the bed? There is the extra 20 gallons of fuel and no mounting worries. Less convienent but less costly.
Ride hard, die young and leave a good looking corpse. Now that I'm older...
07' DC 4x2 SR5, TRD CAI, TRD Dual Exhaust, TRD Sway Bar, Line-X
Old 01-03-2008, 12:07 PM
Last Online: 04-02-2009 01:48 AM
TUNDRA786 is on a distinguished road.
TUNDRA786's Photo Albums
x2
Do they make Gas Cans for vehicles??? the ones i usually see at Walmart are meant for lawn equipment and i donno if the nozzle will fit our trucks.
Those 5 gallon Blitz cans cost like 8-9bucks each.
TUNDRA786
2007 Tundra Crew Max 4.7 TRD 4x4
285/65/18's with BF Goodrich All Terrain KO's
BedRug, Undercover, Bed Extender, Husky Liners
Old 01-03-2008, 01:09 PM
Banned
Dealer : San Francisco Toyota
2007 Toyota Tundra 5.7 Double Cab 4X4
Last Online: 01-12-2008 11:20 PM
Rustywrenches is on a distinguished road.
Rustywrenches's Photo Albums
I would be a little concerned that a fuel tank mounted where the spare tire used to live could be rather dangerous in a crash situation where the truck is hit hard in the rear. It could produce a large fiireball simular to the old Ford Pinto when rear ended. If you are intent on using that space, go for a Nascar style fuel cell so if it is impacted, it might keep you and your family safe. I'm not criticizing your idea, just trying to point out a possible hazard that could become deadly in the right combination of unfortuante incidents.
LinkBack to this Thread: http://www.tundrasolutions.com/forums/tundra/120812-bigger-gas-tank/
Posted By For Type Date
Ford Pinto Skandal, Ford Pinto Production, Ford Power Stroke Fuel Tanks - Hoodpiercings This thread Refback 03-08-2009 04:59 AM
Trailer Life Directory Open Roads Forum: extra fuel capacity / 07 Tundra This thread Refback 02-21-2009 03:50 PM
Woodalls Open Roads Forum: Tow Vehicles: extra fuel capacity / 07 Tundra This thread Refback 02-06-2009 11:05 PM
Trailer Life Magazine Open Roads Forum: extra fuel capacity / 07 Tundra This thread Refback 02-06-2009 10:21 PM
RV.Net Open Roads Forum: Tow Vehicles: extra fuel capacity / 07 Tundra This thread Refback 02-06-2009 09:46 PM
