Re: Schematic for center console
If you do rig some sort of switch, you flip it, your reverse lights will come on. Your reverse position tells the nav to turn on the backup camera. I dunno if thats for sure, but I strongly do think so. One easy way I could think of is to find where the gear position unit is, most likely on the side of the transmission, and go in there with a tester with the truck in the R position and see what wire has power. Then rig a switch from that wire to the battery or a positive current and try it.
09 Peterbilt 387, 06 Corolla CE, 02 4Runner SE 4x4 A/T
1991 Toyota Cressida 5spd M/T Turbo Charged
Originally Posted by MT Groove
Nitrous is like a hot chick with an STD. You want to hit it, but you fear the consequences.
