Had a Revtek, which advertised 2.5 but was closer to 1.5 inch lift. Planned a 6-inch but couldn't find a way to do it without wheels that pushed the tires out beyond the fenders.
Kept the differential and driveshaft drops but scrapped the rest of the Revtek. RIM1 Custom Wheels best source for FOOSE,DUB,TIS.... made a 4-inch lift by adding a custom-milled portion from a Trailmaster kit to a full Daystar kit, as shown in the photos in my gallery. On the back we made 2.25-inch blocks with extenders for the brake line brackets to keep the lines off the leafs. Stock wheels, coil overs, and shocks all around.
Ride is better without the Revtek spring pre-load, yet no more than stock lean around high-speed corners. Southern California bed-bounce is significantly reduced, probably from the combination of less spring pre-load up front and less rake than stock. Plenty of room left in the headlight adjusters.
Our goal was the most lift possible while keeping the stock suspension. I think we got it about right, as 3 of the 4 adjusters for the front end alignment are now maxed out.
305/65/18 BFG AT's look small now. With 20,000 miles, they have about half their tread left. Once they wear out, I will be going to at least 35 if not 37's. RIM1 Custom Wheels best source for FOOSE,DUB,TIS.... does lifts and wheels for the local dealers, so I will be returning to them for wheel well mods when it's time for the 37's. I have about 3 inches left to the top of my 7-foot garage, so it should still fit with the bigger tires.
Right now my front wheel well sits 5 inches taller than stock, but still 3 inches shorter than Tundras with a 6-inch lift and 35's. We did a before and after measurement and I gained 2.5 inches in height up front compared to the Revtek kit.
I was getting 14 in town, but that recently jumped to 17 with the battery disconnect reset. I have the towing package and gears, so there is still plenty of power with the oversize tires; I suspect it will still be fine going to 37's.
I know pictures aren't as good as the real thing, but they are in my gallery just the same. Let me know if you have questions.
Update: discovered rear blocks left minimal travel with the stock shocks, so used this as a good excuse to put longer, softer shocks that will hopefully eliminate what's left of the bed bounce. Going to Meguiar's class in March, which will give me a chance to see if the ride is better on I-10.
__________________ 07 DC SR5 TRD 4x4 5.7 TRD exhaust, 46K miles, 17 mpg city after battery disconnect reset. Truxedo Lo-Pro with deck rails. Front Susp: Stock coilovers, 4" lift (http://www.tundrasolutions.com/forum...6-4-inch-lift/), swapped extra spacers for Bilstein 5100s on lowest setting, wheel well height still 41.5." Rear Susp: ProComp ES3000 #326510 (2.25" taller than stock), 1.25" blocks plus PRG mini-pack (http://www.tundrasolutions.com/forum...and-new-truck/) gives 2.25" total lift, parking brake cable bracket spacers, wheel well height 43." Front diff and rear ds drop; trailer hitch electrical harness tucked up above bumper. After 20K miles swapped 305/65/18 BFG AT for 285/75/18 Toyo AT, still on stock 18x8x60 offset TRD wheels, about 1/8" clearance to sway bar. Like the extra height but miss the width. Next time either 305/70/, 295/70, or 35x12.50/18. Added 5th 285/75/18 Toyo AT as spare. Bed Bounce: Stiffer E-tires are worse than stock P-metric; biggest improvement from PRG mini-pack, slight improvement from shocks. Still a stiff ride but tolerable now. Best things about this truck: 5.7 and transmission, interior size and comfort, very quiet at high speed. Worst things about this truck: bed bounce, no VSC in 4wd, mileage sucks above 70.
Reason: Added info on rear shocks
You should really at least get a upper control arm. That stock suspension isn't meant for that big of a geometry change. You may end up replacing quite a few upper ball joints in the life of the truck not accounting for any other problems. The upper arm will correct the jacked up camber to a better angle as well as giving you a 1" uniball which is by far better then any balljoint.
If I were you I would shell out the money and do a lift kit right. I've had nothing but bad experiences with cheap lifts. Something like this will give you an excellent ride, especially off-road http://www.camburg.com/images/2007%2...Full%20Kit.jpg
2007 Tundra 5.7 6-spd 2wd
Silver, double cab, short bed
TRD package
yeah i agree...that stock ball joint has to be at it's limit...do it right
__________________ 2007 DoubleCab Tundra TRD 4x4
Silver Sky Sway-a-way Coliovers Total Chaos UCA's
Mickey Thompson Baja ATZ 35x12.50x20
BMF Novacane wheels
SnugTop camper shell
Black headlight mod
Plated body mount
Kenwood DNX7100 Nav/ipod/backup camera
Problem with the Camburg is I am not sure it would fit with the stock wheels. I am not interested in decreasing offset and having tires that stick out beyond the fender. I do appreciate the advice, though, about keeping track of the ball joint wear.
I can tell you there is more travel left than with a similar arrangement I had on my 05 Frontier. With that truck, the suspension would top out on large bumps; no negative effects noticed so far with the Tundra.
I would give them a call about the stock wheels. I'm pretty sure they will allow for stock wheels with their light setup since it's only coilovers and upper arms. Now the long travel kit is something I will only be dreaming about, if you've ever ridden in a long travel truck it's addicting!
TRD package
I believe the Camburg kit you are describing only gives 3 inches of lift, not to mention the question of whether it would clear stock wheels with oversize tires. My current set up only has about 1/2 inch clearance to the UCA, and of course needed the usual skid plate tweak.
Added info to my original post regarding rear shocks.
Im fro the west valley area. I have a 2007 TRD 4x4 DC with the Toytec 3" lift. I like your setup! what did the custom lift cost you to install with the parts and who did it? Acosta I would like to see your truck in person to see the height difference with my Toytec. I still have stock wheels and tires. Let me know. Thanks Bro
There is a link to the shop RIM1 Custom Wheels best source for FOOSE,DUB,TIS.... in my original post. They do wheel, tire, and lift work for several local dealers. Their consumer direct pricing was very competitive.
Verify this for yourself at your local dealer: stock front wheelwell is 36" high. Mine is 41" front, just over 42" rear. I am guessing your front wheelwell is around 39". You are more than welcome to see mine in person anytime, just let me know. I usually have the truck in Tempe on Fridays just around the corner from the shop that did my lift (RIM1 Custom Wheels best source for FOOSE,DUB,TIS....). I could meet you there in case you wanted to talk to the owner or techs.
Hey nice sounding setup! I'm going to be putting a Truxxx 3" and 305/55 20s on my truck in the spring and I'm a little worried about how its going to ride. I've asked a few times and have never really gotten an answer about a softer shock for these trucks. I have the TRD package and I think its already a bit stiff and know its going to be much worse with the lift and bigger tires and rims. So I'm wondering how you like you're ES3000s on you're truck? I was planning on Bilsteins 5100s but from what I've heard they are stiffer than the stock Bilsteins and give it better "control". So do the Pro-Comps give a softer ride? Sorry for the long *** post for a very simple question lol. Thanks
__________________ My baby: 08 rc/sb TRD 4x4 SR5 Tundra with the 5.7 in pull me over red still can't get the stupid grin off my face Previous trucks:
81 1-ton Chevy 7.4
89 Full size Blazer 5.7
00 1500 Sierra 5.3
00 1500 Silverado 6.0
01 2500 Silverado D-max LB7
02 2500 Sierra D-max LB7
05 1500 Silverado 5.3
07 2500 Sierra D-max LMM- traded for the Tundra
The ride is better with the softer hydraulic shocks in the rear, but I haven't had a chance to take it off road or over to California to test it on I-10 yet. Those will be the more definitive tests. Normal driving, though, yes the ride is better. Your instincts to go softer rather than firmer than the stock TRD set-up is right on.
Awsome thanks! Thats just what I wanted to hear, sounds like ES3000s are going in at the same time as the lift then. I live in New Hampshire so I have never had the bed bounce problems, I just get whole truck bounce on frost heaves 3/4 of the year. Thanks for the quick responce and the answer I was looking for! Hope they help with your' bed bounce problems.
81 1-ton Chevy 7.4
00 1500 Sierra 5.3
Well I went on 4wheelparts last night and the web site had the ES3000s listed for the 07 tundra so I almost ordered them for front and rear but something seamed a little fishy so I decided to wait and call to conferm today. The guy that I talked to claimed that the only shocks they carry for the Tundras are Bilsteins and that Pro-Comp doesn't make shocks that will fit our trucks. Do you know if Pro-Comp makes ones that will fit the front? Thanks
81 1-ton Chevy 7.4
00 1500 Sierra 5.3
Check out my original post and signature block. My lift shop (RIM1 Custom Wheels best source for FOOSE,DUB,TIS....) picked the shocks to fit the extra length I needed in the back; I posted the exact part number they used for convenience. I know that ProComp will not list this exact part number for the Tundra because stock wouldn't have 2.25 inch blocks. But I have seen this exact part number for the ES3000 on their website, the part number just determines the length. The lift shop measured my ride height, then picked the shocks with the right length to match.
Anyway, all of this was for the rear; the front still has the oem coilovers and shocks.
so what do you guys think about camburg coilovers, upper controll arms limmit straps
and truxxus spacers above the camburgs adjust the cambur for a total of 4 inches to 4.5 inches of front lift. i think it would be the best of both worlds as the camburg shocks blow pro comp out of the water but add a little more lift with the blocks
now i need to think of dropping down the diff in a nice way , not just a couple of washers! any ideas???
