Re: 325x60x18??????
Originally Posted by tundra3250
Just ordered some cooper discover stt's 325x60x18 for my 07 tundra with a 2.5" leveling kit. The postings I have seen say that they will not fit however my dealer said they would fit with the stock rims. What is the right answer?????
I personally tried 325/65/18 BFG AT on stock 18x8 TRD rims and they rubbed on the UCA. I doubt yours will fit on the stock wheels without a spacer of 1/4 to 1/2 inch and recommend doing a test fit before commiting $$.
At the time I tried the tires on mine, I had a Revtek kit, which claims to be 2.5 inches but is really closer to 1.5 inches. As wide as a 325 is, I don't think the lift will make a difference as you will rub the UCA going straight ahead.
07 DC SR5 TRD 4x4 5.7 TRD exhaust, 35K miles, 17 mpg city after battery disconnect reset & removing extra (charcoal?) air filter. Truxedo Lo-Pro with deck rails.
Front Susp: Stock coilovers, 4" lift ( http://www.tundrasolutions.com/forum...6-4-inch-lift/), just swapped extra spacers for Bilstein 5100s on lowest setting, wheel well height still 41.5."
Rear Susp: ProComp ES3000 #326510 (2.25" taller than stock), 1.25" blocks plus PRG mini-pack ( http://www.tundrasolutions.com/forum...and-new-truck/) gives 2.25" total lift, parking brake cable bracket spacers, wheel well height 43."
Front diff and rear ds drop; trailer hitch electrical harness tucked up above bumper.
After 20K miles swapped 305/65/18 BFG AT for 285/75/18 Toyo AT, still on stock 18x8x60 offset TRD wheels, about 1/8" clearance to sway bar. Like the extra height but miss the width. Next time either 305/70/18 or 35x12.50/18.
Added 5th 285/75/18 Toyo AT as spare. Foam pad above spare to help with bed bounce.
Bed Bounce: Stiffer E-tires are worse than stock P-metric; biggest improvement from PRG mini-pack, slight improvement from shocks and foam pad above spare. Still a stiff ride but tolerable now.
Best things about this truck: 5.7 and transmission, interior size and comfort, very quiet at high speed.
Worst things about this truck: bed bounce, no VSC in 4wd, mileage sucks above 70.
