Ok, here goes...
Bought an AVS Bug Deflector II and installed it. During the tightening of the drivers side under hood "corner" nut I hear a "crack" Look, and sure enough it cracked right were it comes out of the grill. The sharp edge of the grill looks like it just cracked/ripped it.
Inquired about a replacement, and ended up sending it back.
Got the replacement this week, and just decided to put it back on. I now have some "install" experience and know what I'm doing.
I line everything up, and in fact I try my best to make it so as little pressure is on the bug deflector where it comes out of the grill. I tighten all the bolts / nuts except for the corner ones. I have them snug, but not tight. I tighten them just a little more so they aren't going to fall off (mind you they are not "tight").
Everything is lined up dead center, but when I go to shut the hood I here "crack" This time it's the passenger side. It doesn't seem to be as bad, but I don't understand what I'm doing wrong here.
It's a pretty straight forward install, and I'm no where near new to modifying cars/trucks etc... Very rarely do I let anyone work on any of my cars/trucks.
Anyone else had or seen this problem with the AVS brand bug deflectors?
Right now I have no plans to return this one, I plan to leave it as is until it gets bad enough that I have to remove it, and then I'll try something else.
The only reason I have this thing on is for protection. It looks *ok* but if it keeps the front of my hood chip free then it's doing it job. If it flings a few bugs up over the windshield then that's a bonus.
Within the first 700 miles that I owned the truck I got a small chip in the pain right behind where the bug deflector would protect
Any help and/or ideas would be appreciated.
