This is a discussion thread titled "Sonar Malfunction when Raining", within the Tundra forum, part of the Truck Forums category.
I know a few people here have reported the same problem....one (or more) of the sonars falsely emit the "obstacle warning" during or after a hard rain.
Do we know what the fix is???
It rained fairly hard here yesterday and mine didn't start to beep.
I'm not sure how you would 'fix' it if it beeped when it rained so hard it set it off. After all, a vast quantity of water is an obstacle - the sonar doesn't know if its water or a solid object.
If its raining hard then just hit the 'sonar' button and turn it off.
Mine did this one time during and rain and has not done it since. It had to be about four or five months ago and I just let them dry out.
__________________ 2007 Tundra CrewMax, SR5, 4x4, 5.7L, TRD MODS: DVD Headrests, Access Lorado Tonneau, BFG All-Terrain T/A's, Brushed Stainless Running Boards, Zoomers Exhaust, TRD Cold Air Intake, and Backup Camera
The sensors are acting just like they should in that they're sensing an object that's close. It just happens to be that the object in your case is heavy rain or snow/ice stuck on the sensor. There's nothing wrong with them. The "fix" is to shut them off when needed.
No, it is malfunctioning. It is always the same sensor (Rear Passenger only). I can wipe it off to no avail. It will still chime. Yes turning it off stops the alarm, but that is not a fix.
thanks though
thanks though
I got a crazy idea...take it to the dealer.
Beer please!
thanks though
That sonar may be a hair more sensitive, but nothing wrong. If you believe there is, do like he said above.
__________________ Crewmax Salsa Red Pearl Loaded.
Rhino Liner
Diamond Gloss
Remote Start
Undercover Tonneau
Pistol in the console
Or maybe water is getting in, shorting out something. Is it slow beep --- beep ---- beep, or fast or one long beeeeeeeeeeeeeep. If it doesn't change with different amounts of rain, or if it's an all or nothing you may have a bad sensor or a leak in it.
Take it back. . . you didn't pay $500 for something you have to remember to turn off and on all the time. . .
__________________ Radiant Red 2007 Double Cab Limited w/Graphite Leather Interior
Factory Nav, Sonar, and 10 spkr 440W JBL stereo with Sirius (sweet) Cold Weather Pkg and Block Htr. Brushed SS Stepboards,
Upgraded Tires: BFG A/T KO LT265 65 R 18,
Curt Front Receiver, with Warn 8000lb winch back/front mountable, Diamondback Tonneau Cover.
Tekonsha Prodigy Brake Controller
DSP 16,000 lb 5th wheel hitch
Firestone Ride Rite 2445 Air Bags
I am having a similar problem and will take it to the dealer the next time I am in the city. My rear sensors sound continuously after every time I wash the truck. Given it is -20C I have checked for snow or ice on the face of the sensor but they are perfectly clean. I do wash the underside and believe water is getting into the connections or sensor and shorting them out. My problem does eventually go away after a couple warmer days or a day in a heated garage, but I agree this is BS. Since others are having issues in the rain it likely is a leaking connection, I just hope the dealer will step up and agree because of coarse there won't be a problem when it is sitting in their shop (but I will make sure to hose them down good before taking it in).
I have had problems with mine so I usually just leave it off...Can't stand another beep when I start the thing too. Plus I thought sonar was only supposed to work on under water sea animals and submarines...??
DCSB SR5 2WD
-THE MONSTROUS 5.7
-6SPD AUTO
-STEBEL 300HZ TRUCK HORN+2 FACTORY HORNS
-K&N 77 SERIES INTAKE
-TOYTEC 3" LIFT
-DEBADGED
-SYLVANIA H9 LOW BEAM MOD (2100 LUMENS)
-HIR1 HI BEAM MOD (2350 LUMENS)
-SILVERSTAR EURO SIGNALS
-BLACK HEADLIGHT MOD
-BLACK BADGE
-JBL 440W SYSTEM W/ NAV W/ BACKUP CAM
-SONAR
-ESCORT PASSPORT 8500 X50 RADAR
-MOTO METAL 951 18" RIMS
-MAGNAFLOW 14" 2 IN/2 OUT CATBACK EXHAUST -SYSTEM WITH 4" MAGNAFLOW TIPS
-BFG TA KO 285/65/18's!!(32.7")
-CHROME TOYOTA NERF BARS
-BEDLINER
Mine was wet from rain last night and it didn't emit a single beep until I was only inches from the garage door, which is quite different from its usual behaviour.
