LinkBack (3) Thread Tools Display Modes
  3 links from elsewhere to this Post. Click to view. #1 (permalink)
Old 01-26-2008, 09:10 PM
RONE's Avatar
Dealer : Little Apple Toyota
2008 Toyota Tundra 5.7L SR5 4x4 DC
Last Online: Today 11:36 AM
RONE is a splendid one to behold. RONE is a splendid one to behold.
RONE's Photo Albums
Default How to install a block heater:
I ordered a "dry" type block heater for my 5.7L Tundra. This means you do NOT have to drain/refill the antifreeze and there is no chance of leaking coolant, as this heater does not immerse in the coolant. The hole for installation is present on all of our motors, it's as simple as buying the $30 part and spending 30 minutes installing it.
Here's the link for ordering the block heater:
00213-00900 - Toyota Block Heater (see description) Parts and Accessories
You will only need 1 tool for this installation, and that's a pair of wire cutters for clipping the ends off the zip ties you use when routing the wires. You'll also need some zip ties as there are only 6 included with the block heater and I didn't think that was enough.
All of the photos of the install process are at the end of the post. The first several pictures are to get you oriented so you can locate the hole for the block heater, and the last couple show how I chose to run the power cord.
Step 1: open box and make sure you have all the necessary parts (heating element, power cord, thermal grease, zip ties).
Step 2: lie down next to the driver's side door, with your head towards the engine.
Step 3: slide under the truck and locate the exhaust on the driver's side of the engine. Just behind the header you'll be able to see the hole for the block heater.
Step 4: you'll see an electrical connection mounted just beneath where you need to work. Pull the connector off the metal mounting bracket to allow yourself a little extra slack in the cables so you can squeeze your hands further up.
Step 5: once you've located the hole for the block heater, go ahead and liberally apply the thermal grease to the heating element - be sure to not get any of the grease on the prongs that the power cord hooks onto. Now put the rest of the grease (should be about 1/2 the container of grease) directly into the hole on the engine. My only tip for making this easier is after applying the grease to the heating element, cut the entire end of the grease packaging off so that it comes out very easily (because when you jam your hands between the exhaust and the engine there isn't much room to be trying to squeeze the grease tube).
Step 6: put the heating element into the hole, but be sure and make note of the alignment of the clip on the heating element and the spot on the engine block where the clip will hook to. You'll be in an awkward position with your arms shoved above your head and not able to see anything, but keep at it and you'll finally get the heating element in the hole. At this point the block heater will slide into the hole, but because it is a snug fit and a blind-ended hole, the pressure inside the hole will keep trying to push the heating element back out. I found it easiest to force the element all the way in the hole by using only my right hand, with my palm against the engine and my thumb on the end of the heating element. Again, no really easy way to do this, just find some body position that allows you to apply enough force to clip the element into place.
Step 7: come back out from under the engine, and feed the power cord down from the engine bay. You're trying to drop it as close to the heating element as possible, so the closer to the fire wall you can drop the power cord, the better.
Step 8: return to underneath the truck, and plug the power cord onto the heating element.
Step 9: route the power cord. Be sure and start with the portion of the power cord that is closest to the heating element, and work your way toward the front of the truck. I know that seems like common sense, but I was so anxious to find a place to mount the standard plug in the grill that I ended up with my power cable running over a coolant hose that I would have rather had it running underneath. No big deal and it's not going to affect anything, I just would have preferred it the other way.
Here are all the images I have:
I will have to pop the hood every time I want to hook up the heater, but that doesn't bother me, as I was more interested in making the plug as hidden as possible.
Old 01-26-2008, 09:25 PM
Dealer : Tom Scott Toyota
2007 Toyota Tundra,
2007 Toyota Camry white xle v6,
- Other - 77 celica gt one own
Last Online: Today 11:04 AM
mgsw530 is on a distinguished road.
mgsw530's Photo Albums
Default Re: How to install a block heater:
Great info. Good detailed information! Love the dry method as I have a 1977 celica gt (one owner) w/ the wet heater and it has driped for years and I just never could make it stop. Fortunately my tundra stays in a garage every nite and I probably don't need a heater, but anyway, great info for those that need one.
Old 01-26-2008, 09:44 PM
Dealer : Autoway Toyota
Last Online: 10-08-2009 09:45 PM
fla_guy is on a distinguished road.
fla_guy's Photo Albums
Wow, excellent writeup. Thanks for that!!!!! Nice to know a block heater is not too expensive and no need to deal with frost plugs and coolant etc. Good job!
2007 Tundra DC TRD 4x4
Pyrite Mica
Bucket Seats
Cold Kit
Deck Rails
Tow Mirrors
Door sill protectors
Old 01-26-2008, 10:14 PM
Dealer : Universal Toyota
Last Online: 04-08-2009 07:01 PM
djb383 is on a distinguished road.
djb383's Photo Albums
Does it heat one side of the block only? Also, excellent write-up.
'07 RCSB 5.7L SR5 Silver Sky Metallic (The Silver Bullet) Yep....it's gotta HEMI
Never argue with an idiot. They will bring you down to their level and beat you with experience!
Old 01-28-2008, 07:26 AM
daless2's Avatar
Dealer : Toyota On Nicholasville
Last Online: 08-07-2009 07:26 AM
daless2 will become famous soon enough.
daless2's Photo Albums
Great Write-up! Thanks for taking the time to share your work.
Well Done,
Frank
Old 01-29-2008, 12:15 AM
Dealer : Molle Toyota
Last Online: 11-04-2009 12:07 AM
Images: 13
Mang is on a distinguished road.
Mang's Photo Albums
So how was the start up today?
Old 02-04-2008, 09:07 AM
RONE's Avatar
RONE's Photo Albums
The truck has never had trouble actually starting, but after running the block heater for an hour when it was under 30 degrees was noticeable in how much more quickly the truck warmed up. Before I pulled onto the highway near my house I was able to blow warm air from the heater.
Old 02-04-2008, 04:12 PM
Dealer : Toyota of Chula Vista
2008 Toyota Tundra Timberland TRD Ltd.
Last Online: 02-03-2009 06:34 PM
SanteeRuss is on a distinguished road.
SanteeRuss's Photo Albums
Great job & thanks for all the pics~!!!
Old 02-04-2008, 04:30 PM
RONE's Avatar
RONE's Photo Albums
Sure thing! I figure if I'm going to do an install I might as well spend an extra 5 minutes and document it.
Old 02-04-2008, 09:03 PM
300 ULTRA's Avatar
Happy Member
Dealer : Stone's Town & Country Toyota
2007 Toyota Tundra DC 4x4 LTD TRD,
2008 Toyota Rav4 Black LTD
Last Online: 10-12-2009 10:24 PM
300 ULTRA may have some regrets.
300 ULTRA's Photo Albums
I did mine sat. took about 2 hours in the cold. Had to use a 18" piece of broom handle to keep pressure on heater to let the lub and trapped air get out. Thumb got tired. Easy install. Thanks RONE for the great info.
Old 01-02-2009, 06:16 PM
Images: 13
Mang's Photo Albums
Rone, thank you so much for this excellent write up, it was a life and time saver. I have a few other names for the 'Very Annoying Wire'!!! The most difficult part was connecting the wire to the plug, but I finally got it in there.
On your common sense part: Open your hood while working underneath as the extra light is VERY helpful!!!
Oh and I wanted to let everyone know that I was able to order the heater through my local dealer for around $37 and it is not a normal Toyota part number, but some sort of 'special' number so make sure to tell the parts guy that.
Hate to say it, but I am looking forward to the next cold day!
KU creates special atmosphere
by: Hubert Davis
posted: Sunday, March 2, 2008 | Print Entry
Watching Kansas at Allen Fieldhouse is the best place to watch a college basketball game. The atmosphere is perfect. No luxury seats, all bench seating, and every seat has a good view. The students sit close to the floor and everybody cheers from one hour before the game to the final seconds. By the end of the game, whether you are a Jayhawk fan or not, I promise you will be singing "Rock, Chalk, Jayhawk."
Old 01-02-2009, 07:40 PM
Gr8one692's Avatar
Dealer : Valley Toyota - Chilliwack
Last Online: 10-20-2009 11:46 PM
Images: 10
Gr8one692 is on a distinguished road.
Gr8one692's Photo Albums
Awsome write up Rone. Curious, I have the Cold package and I don't seem to have the block heater. I would have thought this came installed on mine. I think this should be a DIY Sticky perhaps?
Old 01-02-2009, 08:32 PM
lotust's Avatar
Dealer : Competition Toyota Scion of Middle Island
2008 Toyota Tundra 5.7L 4x4 silver DC
Last Online: Yesterday 11:22 AM
Images: 5
lotust is on a distinguished road.
lotust's Photo Albums
I installed the same heater on my 06 tacoma. I did not think the time and effort was worth it. I did not really notice a difference with it pluged in for 2 hours when the temps were below 32*. I think its really ment to be pluged in over night.
Incab LEDS all around,35w 5000k HIDs
Curt 2" Front hitch,JBA SS single Cat back.. sounds nice
N-Fabs
Old 01-02-2009, 10:30 PM
RONE's Avatar
RONE's Photo Albums
Glad I was able to help you guys. As for the cold weather package, no, it does not include the block heater. Doesn't make a lot of sense, does it?
Old 01-03-2009, 08:54 PM
pfischer1213's Avatar
Dealer : Toyota of Naperville
Last Online: Today 12:20 PM
pfischer1213 has done just about everything. pfischer1213 has done just about everything. pfischer1213 has done just about everything. pfischer1213 has done just about everything. pfischer1213 has done just about everything. pfischer1213 has done just about everything. pfischer1213 has done just about everything. pfischer1213 has done just about everything. pfischer1213 has done just about everything. pfischer1213 has done just about everything. pfischer1213 has done just about everything.
pfischer1213's Photo Albums
quick question, is the "hole" ready to go or is it capped or plugged??
thanks!
CBTMA Member, 2008 Tundra DC, SR 5, Salsa Red Pearl, 5.7, Running Boards, Bed Liner, TRD Package,White LED Lights in Interior, Alpine SPS -1752 Speakers, Extang Tonneau
LinkBack to this Thread: http://www.tundrasolutions.com/forums/tundra/123159-how-to-install-a-block-heater/
Posted By For Type Date
DIY (Do-It-Yourself) & User Knowledgebase - Tundra Geeks :: The Toyota Tundra Enthusiast Forum This thread Refback 09-15-2009 07:45 AM
DIY (Do-It-Yourself) & User Knowledgebase - IBTO Toyota Tundra Forum This thread Refback 07-06-2009 09:32 PM
DIY (Do-It-Yourself) & User Knowledgebase - IBTO Official Forums This thread Refback 06-13-2009 07:33 PM
