08 tundra backup camera use in motion
+ Reply to Thread
Page 1 of 2 12 LastLast
Results 1 to 15 of 16
Thread: 08 tundra backup camera use in motion
  1. #1
    Join Date
    Feb 2008
    Location
    richmond, va
    Posts
    25
    Liked
    0 times
    Thanks
    0
    Rep Power
    8
    Default 08 tundra backup camera use in motion
    does anyone know how to set a switch so i can use my backup camera to check the load and hitch, while moving forward? any help woould be appreciated, thanks
  2. Remove Advertisements
    Toyota Tundra Forum
    Advertisements
  3. #2
    Join Date
    Jun 2005
    Location
    Southeast Texas
    Posts
    19
    Liked
    0 times
    Thanks
    0
    Rep Power
    0
    Smile Re: 08 tundra backup camera use in motion
    You would have to feed a 12v power source to the monitor line. It is the green line located behind the plastic cover along the driver side window pillar. You CANNOT just put 12v on it, the computer will think that you are in reverse while your in forward, and the check engine, 4 wheel, and reverse lights in the back and the inside will light up like a Christmas tree; NOT GOOD. You will have to solder in 2 general purpose diode(1N4003) from Radio Shack. You will have to cut the green wire and and solder the two cathode end(the side with the strip) to the lead that goes up to the monitor. Now one side of the diode, you would have to solder the other end of the green line to it (it is the power source when you put it in reverse). The other end of the other diode is where you solder the other power source(grey wire in picture) from your switch (where ever you desire it to be). I put mine next to the TOW button and got my 12v from the cig. lighter. I posted a picture to help. If picture don't come out, just check my photo gallery. If you did it right then you can have the switch on anytime you like, even when it already in reverse. I like it on when I'm towing my boat, also help when you hitching up, cause if you misjudged and put in forward, the camera is useless. This way you can see it in forward or reverse. Hope this will help out.
  4. #3
    Join Date
    Feb 2008
    Location
    richmond, va
    Posts
    25
    Liked
    0 times
    Thanks
    0
    Rep Power
    8
    Thread Starter
    Default Re: 08 tundra backup camera use in motion
    will this work even in my limited tubdra. I have the in dash nav. Will this work with it?
  5. #4
    Junior Member 2007dctundra4x4's Avatar
    Join Date
    Jul 2007
    Location
    From Philly / McGuire AFB, NJ
    Posts
    463
    Liked
    5 times
    Thanks
    0
    Rep Power
    15
    i did it with my aftermarket nav and i just used a SPDT rocker switch, center contact went to monitor - the two power came from reverse light and switched ignition....works like a champ
  6. #5
    Join Date
    Feb 2008
    Location
    richmond, va
    Posts
    25
    Liked
    0 times
    Thanks
    0
    Rep Power
    8
    Thread Starter
    how would i install one? because the nav and the camera use the same screen. thanks
  7. #6
    Join Date
    Jul 2007
    Location
    Posts
    463
    Liked
    5 times
    Thanks
    0
    Rep Power
    15
    Quote Originally Posted by tundra-holic View Post
    yeah so does mine...not sure how yours is set up...but on mine, find the reverse sensing wire, dike it, that will be the center contact..on the other side of the spdt switch will be your two power inputs...the one from the reverse and another one you wire up to a swiched ignition source....i leave the switch down (normal sys op) works as soon as you put into reverse, if i wanna see whats going on behind me, i flip it up---instant camera
  8. #7
    Join Date
    Mar 2008
    Location
    Bel Air, MD
    Posts
    3
    Liked
    0 times
    Thanks
    0
    Rep Power
    0
    Question Re: 08 tundra backup camera use in motion
    Quote Originally Posted by ccscorpion200 View Post
    Hi, I just installed the OEM camera & Monitor, bought on ebay for $506, how easy was it to get to the reverse sensing wire in the door pillar? Also what type switch did you use? Thanks nice pics.
  9. #8
    Junior Member RisingSun's Avatar
    Join Date
    Mar 2002
    Location
    rising sun,maryland,usa
    Posts
    225
    Liked
    0 times
    Thanks
    0
    Rep Power
    14
    Quote Originally Posted by 2007dctundra4x4 View Post
    Ditto on my JVC KW-AVX810. Its kind of like riding a roller coaster when you're going down the road looking back.
    5.7 Crewmax SR5 4x4 Silver Sky Metallic
    TRD Wheels
    Undercover Hard Tonneau
    Carriage Works Polished Billet Grill
    Spray in Liner
    Westin Tube Steps
    KC 35w Amber Fog Lamps
    Weathertech Visors
    Sirius Satellite
    Flowmaster 50 SUV Dumped
    JVC KW-AVX810 Head
    Kicker 12" Sub
    Boston Acoustic Speakers
    Boyo Rear Camera
    Extreme Amp
    Putco LED Dome Lights
    Chrome Door Handles
    60" Fire and Ice rear LED lights
    Recon 62" Side Running Lights
    Viper 5701 LE Alarm and Remote Start
    (all sensors except proximity)
    Truxxx 3/1 Lift
    Xenon H11 8000K HID Lights
    ** Sunroof being added soon
  10. #9
    Junior Member needatundra's Avatar
    Join Date
    Aug 2007
    Location
    Milton, Ontario
    Posts
    103
    Liked
    0 times
    Thanks
    0
    Rep Power
    8
    Anyone else try ccscorpion200's mod?
    I want the camera on also and want to try this mod, but I would like to know how easy it is to do first...
    2007 Tundra DC SR5 Slate TRD 5.7 4X4 JBL/bluetooth B/U Cam.
  11. #10
    Senior Contributor Barney_Fife's Avatar
    Join Date
    Jan 2008
    Location
    mansfield, texas
    Posts
    7,461
    Liked
    16 times
    Thanks
    0
    Images
    216
    Rep Power
    7361
    Quote Originally Posted by RisingSun View Post
    u think thats odd...i hate to even mention a buddy of mine and i tried this but when we first got our digital camera systems in our patrol cars- they have a small monitor mounted on the ceiling- gotta be like a 5 in LCD or whatever, anyway, closed course of course, it is like a huge video game if you watch the screen while driving around....sense of depth perception, speed, all that is out the window. feels like a huge video game.
  12. #11
    Join Date
    Aug 2007
    Location
    Milton, Ontario
    Posts
    103
    Liked
    0 times
    Thanks
    0
    Rep Power
    8
    thanks to ccscorp. for his help. I finally got the camera Hooked up to a switch now I can turn the montior on anytime I want (a real essential option IMO).
    Thanks again.
  13. #12
    Banned
    Join Date
    Sep 2007
    Location
    Los Angeles, CA
    Age
    44
    Posts
    248
    Liked
    0 times
    Thanks
    0
    Rep Power
    0
    Anyone thought of adding a momentary switch to the overhead console behind the flip down monitor. flipping the monitor down would activate the display regardless as to the direction of travel. simply fold it up when you want to turn the display off. seems like perfect sense to me.
    Quote Originally Posted by needatundra View Post
    Thanks again.
  14. #13
    Junior Member pedro66's Avatar
    Join Date
    Apr 2007
    Location
    Bartow
    Posts
    233
    Liked
    1 times
    Thanks
    0
    Images
    77
    Rep Power
    8
    Quote Originally Posted by ponyuk View Post
    Working on that this week will update
  15. #14
    Banned
    Join Date
    Sep 2007
    Location
    Los Angeles, CA
    Age
    44
    Posts
    248
    Liked
    0 times
    Thanks
    0
    Rep Power
    0
    I am looking forward to your write up. I just ordered a couple of diodes and a "through the hole" microswitch. I intend to drill a tiny whole behind the monitor and just allow the switch lever to protrude through it. It shouldn't be under any real stress, so I'm just going to hot-glue the switch in place.
    It will be next weekend before I have the parts in hand to get started.
    Quote Originally Posted by pedro66 View Post
    Attached Images Attached Images
  16. #15
    Join Date
    Apr 2007
    Location
    Bartow
    Posts
    233
    Liked
    1 times
    Thanks
    0
    Images
    77
    Rep Power
    8
Quick Reply Quick Reply
Register Now
Log-in
Human Verification
Posting Permissions
  • You may post new threads
  • You may post replies
  • You may not edit your posts
