This is a discussion thread titled "Hardwire a radar detector, how to?", within the Tundra forum, part of the Truck Forums category.
Just looking at hard wiring a radar detector using something in the upper console if it's possible. I searched some of the links and either browsed over it or didn't see anything there to help with this. I have an 07' CM and I just want to run a short power plug from the overhead center console to a detector to mount somewhere instead of having a power cord hanging down.
Any help would be greatly appreciated.
Try snaking a wire down to the power plug you put the regular detector power corrd into and splicing in a connection to the power. Ground the other wire and viola, you have a "on only when the truck is on" plug. Better option than runnign it off the stereo wires, but you could also check the forum for the wiring in the overhead console. I think 2 of those wire sets have 12v, for the bluetooth and the backup cam wiring....
You should be able to wire it in right up in the overhead console. I have seen it done on some of my dad's cars and I have also had mine hardwired in that way in previous cars. But yea you should be able to place the detector up towards the top of the window and just splice the stock detector wire in with a power wire up in the overhead console where the lights are. Seen it done that way in numerous vehicles. Which detector do you have btw?
DCSB SR5 2WD
-THE MONSTROUS 5.7
-6SPD AUTO
-STEBEL 300HZ TRUCK HORN+2 FACTORY HORNS
-K&N 77 SERIES INTAKE
-TOYTEC 3" LIFT
-DEBADGED
-SYLVANIA H9 LOW BEAM MOD (2100 LUMENS)
-HIR1 HI BEAM MOD (2350 LUMENS)
-SILVERSTAR EURO SIGNALS
-BLACK HEADLIGHT MOD
-BLACK BADGE
-JBL 440W SYSTEM W/ NAV W/ BACKUP CAM
-SONAR
-ESCORT PASSPORT 8500 X50 RADAR
-MOTO METAL 951 18" RIMS
-MAGNAFLOW 14" 2 IN/2 OUT CATBACK EXHAUST -SYSTEM WITH 4" MAGNAFLOW TIPS
-BFG TA KO 285/65/18's!!(32.7")
-CHROME TOYOTA NERF BARS
-BEDLINER
Currently just a cheap cobra unit from wally-world. Leaving for Iraq again next month so I didn't wanna buy an expensive one until I return.
Ah...I have a few friends in Iraq currently. Hats off to you man. I have been through a few Cobra detectors and they are really good for the price. Never got a ticket with one of them. My friend who worked at Circuit City for a long time got me a really really good deal on a new BEL 995...like $120 off so I had to get it. If you're ever in the market for a really top notch detector then BEL is the way to go or even the Valentine One. My dad swears by the V1.
DCSB SR5 2WD
-THE MONSTROUS 5.7
-6SPD AUTO
-TOYTEC 3" LIFT
-DEBADGED
-BLACK BADGE
-SONAR
-BEDLINER
Yeah I was looking at the V1 as well as a couple others. My main thing is I hate the cord hanging around and I don't trust wireless/battery operated radar detectors.
Yup...The BEL 995 and V1 always are right up at the top of the radar tests different mags and online sites do.
DCSB SR5 2WD
-THE MONSTROUS 5.7
-6SPD AUTO
-TOYTEC 3" LIFT
-DEBADGED
-BLACK BADGE
-SONAR
-BEDLINER
DCSB SR5 2WD
-THE MONSTROUS 5.7
-6SPD AUTO
-TOYTEC 3" LIFT
-DEBADGED
-BLACK BADGE
-SONAR
-BEDLINER
What type of cord is it? Some of them use a standard phone line that you can cut and splice another section in to extend it. Here's how I just mounted my Passport Escort in the Camry Hybrid to give you an idea how you can mount them: Thread in TCH section.
2007 Suzuki GSX-R1000 - Blue/White (0-180mph 18sec)
2006 Toyota Tundra - Phantom Gray Pearl (V8 4x4 Double Cab)
1995 Toyota Supra - Quicksilver (soon to be turbo & methanol injection)
2007 Toyota Camry Hybrid - Blue Ribbon Metallic (loaded)
=-----> DO NOT SHIP W/DAS (DEPENDABLE AUTO SHIPPERS)!! <----=
I actually looked at that for a reference but wasn't sure about what wiring is already in my overhead that I could pull from. I don't want to mess anything in the overhead up because in the future I plan on adding the prewired auto-dimming mirror and then eventually installing a moonroof.
There was a thread awhile back with pics couldn't find it again but I did woks great. There is a small hole in the center of the headliner for you to ran your wire to overhead console I used the light blue +12v ign. on and white black gnd hope this helps
My Passport is wired via using a phone jack cord. I looked up the wiring scheme for the jack on Google and simply found a 12v lead in one of the larger wiring harnesses - the one to the moonroof and jammed a small wire into the back of the harness and taped it down. No cutting or splicing.
2007 5.7 CrewMax Limited 2WD; Pyrite Mica/ Red Rock Leather
20" Alloy | Nav-JBL | Moonroof | Sonar | Cold Kit | Daytime Running Lights | BedRug | ConsoleVault | SoftTopper | TRD sway bar | Weatherguard Tool Box
NAV Mods: Speed Pulse Generator | AUX video input
Buy your truck outside of the Gulf States Toyota monopoly if you don't want to compromise.
there should be power to the rearview mirror. but to be quite honest, i havent looked. but you would need it to have an auto dimmingmirror. so 2 of the wires back there will be power and ground. so cut your cord, and solder on some cheap spoon connectors. and plug them in behind the mirror.
thats gotta be the easiest way to do it. ill have to go physically look at the mirror to make sure there is a plug. it may be wired internally.
2007 Tundra LTD CrewMax, Black
2006 Chrysler 300 SRT8, Brilliant Black, Tinted Windows, Full Stereo, 22" wheels, Magnaflow hi-flo cats, Corsa cat-back exhaust, VORTECH SUPERCHARGED
Most of the better RD's offer a hard wire kit. I hard wired mine by running the wire up to the windsheild from the dash used the cig lighter power. There is also a remote signal that mounts lower on the dash for running in stealth mode.
__________________ 2007 Tundra DC SR5 TRD Nautical Blue, 5.7, 4X4, Toytec 2.5" front lift, 1" rear block, Diff. drop kit, BFG AT KOs 305/65R/18, JVC KW-AVX810 head unit, HD Radio, Sirius, JVC CH X1500 12 disc CD changer, Scosche piano black dash kit, Alpine 550 4 channel amp 90 watts per channel, Focal 165 V1 components front, Cliff Designs CD60-4C Components rear, Pioneer 10" sealed sub box, Clarion 10" shallow sub, Alpine 450 mono amp 220 watts, R/F 1 farad digital capacitor, All 4 doors and rear wall DynaMatt, Hard wired Escort Passport 8500 X50, Boyo VLT 300 rear veiw camera.
