This is a discussion thread titled "Drivers side lean?", within the Tundra forum, part of the Truck Forums category.
Old 02-24-2008, 02:19 PM
Dealer : Lorensen Toyota
2008 Toyota Tundra Timberland Mica
mtelow's Photo Albums
Last Online: 06-11-2008 02:11 PM
mtelow is on a distinguished road.
Default Drivers side lean?
I probably would have never noticed if I hadn't lifted the front with the Top Gun spacers, but on my truck measuring on level ground, there is about a 1/2 to 3/4" between the left front and right front with the driver's side being lower. The back is also a little bit lower on the drivers side also. Has anyone else put a tape measure to their's to see if it sits level? I have a 1/2 tank of gas right now and I am going to remeasure when the tank is empty.
Old 02-24-2008, 03:11 PM
DanielAcosta's Avatar
Dealer : Earnhardt Toyota
DanielAcosta's Photo Albums
Last Online: Yesterday 06:51 AM
DanielAcosta is on a distinguished road.
Default Re: Drivers side lean?
Every Tundra I have measured sits about 1/4 inch lower on the left, both front and back. I had the spacers on my lift machined 1/4 taller both front and rear on the left for this very reason.
07 DC SR5 TRD 4x4 5.7 TRD exhaust, 33K miles, 17 mpg city after battery disconnect reset & removing extra (charcoal?) air filter. Truxedo Lo-Pro with deck rails.
Front Susp: Stock coilovers, 4" lift (http://www.tundrasolutions.com/forum...6-4-inch-lift/), just swapped extra spacers for Bilstein 5100s on lowest setting, wheel well height still 41.5."
Rear Susp: ProComp ES3000 #326510 (2.25" taller than stock), 1.25" blocks plus PRG mini-pack (http://www.tundrasolutions.com/forum...and-new-truck/) gives 2.25" total lift, parking brake cable bracket spacers, wheel well height 43."
Front diff and rear ds drop; trailer hitch electrical harness tucked up above bumper.
After 20K miles swapped 305/65/18 BFG AT for 285/75/18 Toyo AT, still on stock 18x8x60 offset TRD wheels, about 1/8" clearance to sway bar. Like the extra height but miss the width. Next time either 305/70/18 or 35x12.50/18.
Added 5th 285/75/18 Toyo AT as spare. Foam pad above spare to help with bed bounce.
Bed Bounce: Stiffer E-tires are worse than stock P-metric; biggest improvement from PRG mini-pack, slight improvement from shocks and foam pad above spare. Still a stiff ride but tolerable now.
Best things about this truck: 5.7 and transmission, interior size and comfort, very quiet at high speed.
Worst things about this truck: bed bounce, no VSC in 4wd, mileage sucks above 70.
Old 02-24-2008, 11:27 PM
Tampadave's Avatar
Dealer : Wesley Chapel Toyota
2007 Toyota Tundra,
2004 Toyota 4Runner
Tampadave's Photo Albums
Last Online: 10-03-2008 12:23 AM
Tampadave is on a distinguished road.
Yes, mine is about 1/2" also and it drives me crazy (even posted the problem here awhile back) Tilting Tundra?
Dealer said that they wouldn't do anything to correct it, and NO it doesn't have anything to do with gas in the tank, and NO every Tundra doesn't have the problem. Measured 10 of them at the dealer and only two leaned 1/2" or more. Not sure what I'll do about it.....but I hate it! Only thing about this great truck that really bugs me.
TampaDave
Photo Link: http://wbdi.net/tundra
Old 02-24-2008, 11:55 PM
gkeas's Avatar
Dealer : Pedersen Toyota
2007 Toyota Tundra Black LTD 4x4
My eBay gkeas's Photo Albums
Last Online: 10-01-2008 10:52 PM
gkeas is on a distinguished road.
An option besides the custom machining of the lift parts my be to have your passenger outweigh you by a couple of hundred pounds. That should level things out.
Do you really care what truck I have or what mods I've done? Probably not, but here they are any way:
Loaded 07 LTD 4x4 DC 5.7. ARE Cap, Yakima Rack, Toytec 3" Lift, ProComp 8166 Wheels, Nitto Terra Grappler 305/55/20's, Bullhide Spray-In Liner, Volant CAI, Black Headlight Mod, Zoomers Cat back exhaust.
Still to Come: Headers? Speaker/Sub upgrades? What else? Supercharger........? I'm sure I'll think of something.
Old 02-25-2008, 10:42 PM
Dealer : Carson Toyota Scion
2005 Toyota Tacoma,
lbrito's Photo Albums
Last Online: 10-05-2008 05:38 PM
lbrito is on a distinguished road.
I have a similar problem on my 08 crew max, though sometime you can't tell, other times it seems to be more obvious. Maybe its due to how the shocks are currently positioned or something when I park.
I have the same problem on my 05 Tacoma. Both are lifted, though. However, when I drive behind both, they look very very level, with no noticeable lean.
Old 02-26-2008, 01:12 AM
Dealer : Vandergriff Toyota
ShaunM's Photo Albums
Last Online: Yesterday 03:40 PM
ShaunM is on a distinguished road.
If you go look at almost every truck made, you should notice the vehicle leans to the driver side. Some trucks are worse than others. My Tundra does it alot less than my Silverado that I had. Cars even do it, again some are more noticealbe than others.
Old 02-26-2008, 04:06 AM
DavidTaylor9's Avatar
Dealer : Fairfield Toyota
2003 Toyota Sequoia
My eBay DavidTaylor9's Photo Albums
Last Online: 09-24-2008 10:29 PM
DavidTaylor9 is on a distinguished road.
Gas Tank!!!!
Old 02-26-2008, 07:14 AM
millsp's Avatar
Dealer : Lipton Toyota Scion
2007 Toyota Tundra Crew Max Silver TRD
My eBay millsp's Photo Albums
millsp will become famous soon enough.
Originally Posted by DavidTaylor9 View Post
Gas Tank!!!!
And Steering columns weigh a lot too.
Old 02-26-2008, 07:48 AM
semcoll's Avatar
Dealer : Panama City Toyota Scion
semcoll's Photo Albums
Last Online: Yesterday 03:15 PM
semcoll is on a distinguished road.
Look at it this way : when you are out on the highway, your truck looks perfectly level, due to the crown in the road.
5.7L 2WD DC Salsa Red Pearl SOS 2/4 drop, 18" Enkeis w/BFGs, TRD anti-sway bar, Hella Optilux driving lights, Flowmaster 50 dual in/out w/baffled Hooker tips, LineX, DeeZee black diamond toolbox,filled color-matched grille shell w/CarriageWorks insert, Blacked-out headlights, Beltronics 955 radar unit
http://seminolecollision.com/
Old 02-26-2008, 08:49 AM
Dealer : Toyota Scion of Roswell
07BlackCrewMax's Photo Albums
Last Online: 10-09-2008 09:41 PM
07BlackCrewMax is on a distinguished road.
It's a design carry over from NASCAR... helps you gain another tenth on those left hand turns!!!!
07 Tundra CrewMax Limited 4x4 5.7L
Black/Red Rock, Borla Dual Exhaust, XM Satellite Radio, Navigation, Sunroof, 20" Wheels, Sonar, Line-X, Front Window Tint, Undercover, TRD Sway Bar
Old 02-26-2008, 12:37 PM
Dealer : Texas Toyota of Grapevine
- Other -
CardShark's Photo Albums
Last Online: 05-06-2008 12:28 PM
CardShark is on a distinguished road.
My truck had a lean of about 1.5" on the driver's side before I got the shocks replaced, which raised it enough so that there's only about a 1/2" difference now.
Here is a summary of the advice I got from several truck experts:
"Do yourself a favor and try to forget about it. Trying to get it perfectly level is going to drive you crazy. There is more weight on the driver's side to begin with (gas tank, etc.), so even though trucks may be designed to counteract the lean, it's not unreasonable for them to do so, especially when the difference is less than an inch."
And by experts I mean people I know that have driven and customized trucks their whole lives. Personally, their advice was good enough for me and I almost never think about it anymore. *almost*
Old 02-26-2008, 02:50 PM
Tampadave's Avatar
2007 Toyota Tundra,
2004 Toyota 4Runner
Gas Tank!!!!
Definately not.....it leans exactly the same whether the tank is full or empty.
TampaDave
Old 02-26-2008, 04:41 PM
I brought it in for an alignment at Town Fair tire and they also mentioned a 1/2" droop on the drivers side, so it was noticable to them. The dealer was a mile down the road so I took a ride over there to see what they had to say. They blamed it on the Top Gun 2.25" lift in the front. I asked them how that can be since it is on top of the shock and not preloading the spring. They said it changed the geometry of the suspension and there is nothing they can do. I also tried measuring between a full and empty tank of gas and there is no change.
Old 02-26-2008, 07:09 PM
ballin's Avatar
Dealer : Alexander Toyota of Franklin
2007 Toyota Tundra,
2004 Toyota 4Runner
ballin's Photo Albums
Last Online: Yesterday 08:26 PM
ballin is on a distinguished road.
i measured mine before and after my lift and the driver side and the back is 1/4'' lower, so dont let them blame it on the lift. i thought it might be the gas tank, but its not. its not that big of a deal, but it does drive me crazy.
07 tundra 5.7, 4x4,trd, dc, sr5 blk-readylift,1'' toytec block,305/65/18 bfg's,flowmaster super40,chrome door handles,tint,hatchie bottoms custom seat covers
Old 02-26-2008, 09:40 PM
Tampadave's Avatar
2007 Toyota Tundra,
2004 Toyota 4Runner
Originally Posted by ballin View Post
i measured mine before and after my lift and the driver side and the back is 1/2'' lower, so dont let them blame it on the lift. i thought it might be the gas tank, but its not. its not that big of a deal, but it does drive me crazy.
I agree, it's a cop-out if they blame it on a leveling lift. You can go to any dealers lot and find a few stock Tundras with the same lean that we are talking about (no lifts and very little gas in them). From my unscientific investigation at various dealers, I'd say about 30% have a 1/2" or more.....so why are the other 70% level, or at least near level? I know I'm just supposed to ignore this problem, but I'm a graphic designer and my eye is trained to spot things that are "out of balance". Many vehicles over the years have had this problem, just do a Google search for "driver's side lean" and you'll get all kinds of hits....and no good solutions. Still bugs the crap out of me though.
TampaDave
