Help....cd stuck in the nav slot
+ Reply to Thread
Results 1 to 4 of 4
Thread: Help....cd stuck in the nav slot
  1. #1
    Join Date
    Aug 2007
    Location
    Myrtle Beach SC
    Posts
    98
    Liked
    0 times
    Rep Power
    1011
    Default Help....cd stuck in the nav slot
    Alright, this really isn't involving my Tundra, but rather my 07 Escalade. This is the only message board i frequent involving automobiles, so please forgive me. Plus everyone here is knowledgeable and quick to respond.
    Wife and young daughter go to the mall today. Daughter buys a cd. On the ride home, she inserts it into the Navigation/Map DVD slot instead of the CD slot. The cd will not come out when you press eject. The slot is obviously designed to hold one disc, a nav disc. So there are 2 in there now, and all it does is make a clicking noise when you press eject. After a bit, on the screen, it pops up with "Map DVD error".
    So how in the heck do you get a disc out of there that doesn't belong??? I've tried sliding a butter knife in the when I press eject and it starts clicking, hoping I get under the disc and could lift up on it, but no luck. Does the player have to be taken out of the dash and it taken apart to remove it?
  2. Remove Advertisements
    Toyota Tundra Forum
    Advertisements
  3. #2
    Junior Member Lightning Rod's Avatar
    Join Date
    Mar 2007
    Location
    MA
    Posts
    108
    Liked
    1 times
    Rep Power
    15
    Default Re: Help....cd stuck in the nav slot
    Try looking for a paper clip size hole in the front somewhere (its a manual eject). If it has one you can usually stick in a straight side of a paper clip and it will manually eject.
    Good luck
  4. #3
    Join Date
    Feb 2002
    Location
    San Diego, CA
    Age
    48
    Posts
    126
    Liked
    0 times
    Rep Power
    14
    Was this ever resolved. Curious how this worked out...
    This has only happened to me in Toyotas and the only fix was for the dealer to remove the unit and ship it back for a fac. refurb unit.
    2010 4Runner V6 Limited 2WD (Magnetic Grey)
    2006 4Runner V8 Limited 2WD (Nautical Blue)
  5. #4
    Join Date
    Dec 2007
    Location
    south texas
    Posts
    33
    Liked
    0 times
    Rep Power
    8
    If your vehicle is still in warranty, take it the dealer and they will replace the unit. I work with a car audio supplier and see this all the time.
    If not under warranty, the take a pen flash light and see if you can see the second disc. The second disc should have not load all the way since there was a disc already inside. The second disc was pushed over the mechanical parts that support the disc. Then take the thinnest needle noise and pull out the second disc. As you know, this may damage your second disc.
    If you can't see the disc, then you must remove the radio, disassemble and remove the disc manuel. This radio was supplied by Delphi and it is very easy to disassemble. Just remove the top cover and it will expose the DVD playing mechanism.
    Hope this helps.
Quick Reply Quick Reply
Register Now
Log-in
Human Verification
Posting Permissions
  • You may post new threads
  • You may post replies
  • You may not edit your posts
