  #16 (permalink)
Old 04-04-2008, 02:20 AM
FIVEPOINTSEVEN's Avatar
Dealer : Stadium Toyota Scion
Last Online: 07-22-2009 10:31 AM
Images: 17
FIVEPOINTSEVEN will become famous soon enough.
FIVEPOINTSEVEN's Photo Albums
Default Re: ReadyLift vs. Truxxx - Some unanswered questions
Originally Posted by agswin View Post
I thought So Cal Supertrucks has a 4" kit?
From the looks of their site they offer the Truxxx 3" lift kit, control arm kits, and the Donahoe Coilovers which give up to 3.5" of lift...No 4" kits...
DCSB SR5 2WD
-THE MONSTROUS 5.7, 6SPD AUTO, TOW PACKAGE W/4.30 GEARS BABY!, STEBEL 300HZ TRUCK HORN+2 FACTORY HORNS, K&N 77 SERIES INTAKE, TOYTEC 3" LIFT, DEBADGED SYLVANIA H9 LOW BEAM MOD (2100 LUMENS), HIR1 HI BEAM MOD (2350 LUMENS), SILVERSTAR EURO SIGNALS, BLACK HEADLIGHT MOD, BLACK BADGE, JBL 440W SYSTEM W/ NAV W/ BACKUP CAM, SONAR, ESCORT PASSPORT 8500 X50 RADAR, MOTO METAL 951 18" RIMS, MAGNAFLOW 14" 2 IN/2 OUT CATBACK EXHAUST -SYSTEM WITH 4" MAGNAFLOW TIPS, BFG TA KO 285/65/18's!!(32.7"), PIONEER PREMIER SPEAKERS, 2 PREMIER 10" SUBS, 2 KICKER AMPS!!!
  #17 (permalink)
Old 04-04-2008, 07:05 PM
Last Online: 04-15-2008 11:52 AM
soredogg is on a distinguished road.
soredogg's Photo Albums
Originally Posted by Team Readylift View Post
The advantage of a 3" over a 2.4 is purely subjective and up to the consumer to decide. It merely provides for a taller look while in most cases allowing for a 35" tire with a few minor modifications. A block is provided with the kit to re-level as it were, the weight transfer of the vehicle which is beneficial for towing or hauling.
You can run a 35 with a 2.4, but you are going to run into some interference issues that will have to be addressed. The offset of your wheel of choice will have a lot of determining factor. This is why we only recommend a 33" tire with that kit. A 33 will fit with no issues which is what most general consumers prefer.
Just curios as to any potential damage it would cause to just install the 3" lift in front and leave the rear of my truck stock. I have a CM 4x2 w/ TRD and just want to bring my front end up a little past level w/ the back. Would I lose any power or towing capabilities by installing the 3" lift in front and not installing the block in the rear?
Thanks!!!
  #18 (permalink)
Old 04-04-2008, 07:10 PM
Images: 17
Thanks!!!
You won't lose any towing or anything like that...just may lose some mpg because the higher you raise the front of the truck the worse your aero gets. Also you'll have the sagging *** look if thats what you're going for and it will get much more pronounced when towing.
DCSB SR5 2WD
