My truck is 2 days old..help! VSC Off, 4LO blinking etc...
First off; I have a 2008 Tundra Crewmax SR5 4x4 5.7L.
I used this brand-new truck for the last 2 days with no problems at all. I get in it this morning and notice the dash is all lit up.
The "VSC Off" light blinking, "4LO" light blinking, "Check Engine" light is on and the Slip Indicator light is on while driving. When I stop, put it in Neutral to try to switch to 4LO I get a constant beeping alarm.
When I push the Slip Indicator light, nothing happens. I hold it for 3 seconds to lock the diff, nothing happens. I am bringing it to the dealer right now and get this mess straightened out.
If anyone else has dealt with this or knows what could be the possible cause, please post here and let me know what's going on!
They told me "its covered under warranty" I would hope so! I've only burned half a tank of gas and there are less than 300km on it!
So, in closing, just thought I'd post again to follow up just in case someone has gone through, or will go through a similar problem. Thanks to everyone for their input!
same thing happened to me after a week of having the truck...all them pretty little lights went flashing on the dash. i had a defective radiator that they replaced (under warranty).
2008 Tundra 5.7L DC
Tundra owner since Feb. 2, 2008
Flowmaster 50 Series - installed 2/22/08
5 window tint - installed 3/21/08
20" KMC XD Series Rockstar rims - installed 3/31/08
275/60R20 Cooper Zeon LTZ tires - installed 3/31/08
Truxxedo Roll-up Tonneau cover - installed 4/17/08
Westin black nerf bars - installed 5/01/08
Black headlight mod - completed 6/14/08
Black front emblem mod - completed 6/14/08
Re: My truck is 2 days old..help! VSC Off, 4LO blinking etc...
This happened to me this past weekend. I stopped the truck and restarted and it went away. 17k miles.
Also have a new problem where the truck surges in and out of warm-up rpm. Not very pleased with the quality of this truck. Will be going into the shop for the 4th time in less than a year.
my truck is going back to the dealer with the same problem
-4LO light flashing
-VSC Off light flashing
-Check Engine light flashing
-Traction Control light on
first time i brought it in they said Cylinder 7 was misfiring and changed the ignition coil
second time they said nothing appeared to be wrong and reset the lights
now its happened again and I'm about to pull my hair out. Its Thursday now and they can't look at it until Tuesday!
to make the worst of it, I haven't even made my first monthly payment yet!
anyone have an idea what this problem might be? and has anyone else had this problem?
__________________ 2008 Tundra Crewmax SR5 5.7L 4x4 Pro Compustar 2-way 900MHz remote start Black Headlight Mod Line-X bedliner Kenwood DNX8120 Head Unit
Homelink Rearview Mirror OEM back up camera Fully De-badged Color-Matched Grille Surround Truxedo Lo Pro QT Box Cover Sequoia Door Handles (w/BMW style orange LEDs)
I suggest demanding you get a complimentary loaner car till they can figure out the problem and fix it for good. If they can't figure it out, I think it's time for a replacement truck compliments of the dealership.
-4LO light flashing
Research your local lemon laws? I would make a call to Toyota Corporate as well and I would call the Regional Toyota Manager. Good Luck
__________________ 2007 CrewMax SR5 4x4 5.7Nautical Blue My Pictures
TRD Rear Sway Bar, Pioneer FH-P8000BT w/ Sirius, Carriage Works Black Replacement Grille + Top Insert, Color Matched Sequoia Door Handles, Bench Seat, Dual Headrest DVD, back up camera w/monitor, Nüvi 660, Line-x, undercover, Tekonsha P3, debadged, enjoyed since 7/20/2007
FUTURE MODS -
25-30 ft Travel Trailer....... bye bye Pop-Up
the truck seems to be working fine; but the inconvenience of bringing it in every week or two is extremely annoying. I'll post in this thread when/if everything gets resolved!
