This is a discussion thread titled "Tailgate fix: It ain't too pretty but works...", within the Tundra forum, part of the Truck Forums category.
I bought the Tundra to be able to carry a snowmobile and quad (if i ever get a quad) in the bed and was concerned about the weakness in the tailgate. Also, a snowmobile has metal carbides under the skis which could scratch the hell out of the unprotected bed. While line x looks great, it does not address the weakness in the tailgate and the snowmobile carbides would make a mess out of it.....
A common liner in the oil patch is plywood. Many guys running trucks use these plywood liners. Finding one for a GM or Ford is no problem (a company uses a template to cut the wood for it and ships it to the retailer who does the install). Finding one for the Crewmax was more of a problem. Anyway found a store that sourced the template (mine was the first Crewmax) and did the install. The notch in the tailgate is for my fold a cover.
Like the title says, it ain't too pretty but it should solve the weak tailgate issue.....The photos were using my phone so the pictures are not the best.
Re: Tailgate fix: It ain't too pretty but works...
so how much does a plywood liner cost???
__________________ 2007 CrewMax SR5 4x4 5.7Nautical Blue My Pictures
TRD Rear Sway Bar, Pioneer FH-P8000BT w/ Sirius, Carriage Works Black Replacement Grille + Top Insert, Color Matched Sequoia Door Handles, Bench Seat, Dual Headrest DVD, back up camera w/monitor, Nüvi 660, Line-x, undercover, Tekonsha P3, debadged, enjoyed since 7/20/2007
FUTURE MODS -
25-30 ft Travel Trailer....... bye bye Pop-Up
since plywood is cheap, a plywood liner should be cheap. Now if Cliff would be so kind as to post dimensions of those plywood peices any of us could cut up the planks and fit together our own plywood liner....
I like it...
Question, what's the notch for at the edge of the gate?
and
Looking at your pictures, you just gave me an idea to "lock" in my rail system tie down points so they don't easily grow legs....couple stainless washers, ny-lok nuts and bolts at each end. Then it would take wrenches to remove them, like your cap mount points...thanks.
Beer please!
Are you serious, $425? A sheet of 3/4" plywood is what, $80 now? For a couple of hundred you could get a sheet of diamond plate steel and have it plasma cut to size. I plan on a sheet of cheap 3/8" sheet steel and have it line-x'd to match my bed.
__________________ 2007 Tundra CrewMax SR5 4x4, Desert Sand Mods:Line-X, JCW Black Nerf Bars, Bug Guard, K&N filter, removed HC filter Audio:RAAMaudio, Polk 650 & 690's, Kicker ZX700.5 Amp, Kicker 12" shallow sub, Future mods: Nav system
Originally Posted by Sequoia2003
Sorry man, but that looks so ghetto!
Why did you not use a liner or a spay liner and maybe put a plate of diamond plate on the rear gate?
Looking at your truck I hear Jeff Foxworth in the back of may head saying, "You know you're a red neck when you..."
Did you even rear his post. He said the Ski would eat up a spary in liner. I think it looks fine for a truck, some people actually use their trucks as trucks.
3/8 " steel would weigh to much . the tail gate would slam down because it weighs so much even 3/16 " steel would be more then enough . the issue is to tie the top of the out side sheet metal to the inside of the tail gate . not to make the inside of the tail gate pick axe proof .
Double cab long box 4x4 5.7 L slate grey . would have bought a limited if available with long box
