air pressure sensors
+ Reply to Thread
Page 1 of 2 12 LastLast
Results 1 to 15 of 18
Thread: air pressure sensors
  1. #1
    Lurking Member toywitu's Avatar
    Join Date
    Jan 2008
    Location
    howell,nj
    Posts
    39
    Liked
    0 times
    Rep Power
    8
    Default air pressure sensors
    i put new rims on my truck and didnt do the sensors in new rims is there any way of shutting the light offf or disableing that system
  2. Remove Advertisements
    Toyota Tundra Forum
    Advertisements
  3. #2
    Veteran Member ballin's Avatar
    Join Date
    May 2007
    Location
    Lakeland,TN
    Posts
    820
    Liked
    0 times
    Rep Power
    10
    Default Re: air pressure sensors
    electrical tape
    07 tundra 5.7, 4x4,trd, dc, sr5 blk-readylift,1'' toytec block,305/65/18 bfg's,chrome door handles,tint,hatchie bottoms custom seat covers, true duals flowmaster 10 series race mufflers w/h-pipe
  4. #3
    Join Date
    Jan 2008
    Location
    howell,nj
    Posts
    39
    Liked
    0 times
    Rep Power
    8
    Thread Starter
    lol its like my other truck i have bagged i removed evap and had check engine light and also put billet steerign wheel so i hada airbag bulb on also so i had to remove the bulbs lol
  5. #4
    Hall of Fame Member Mr. Creosote's Avatar
    Join Date
    Apr 2006
    Location
    Posts
    32,593
    Liked
    1527 times
    Rep Power
    269355
    Quote Originally Posted by ballin View Post
    electrical tape
  6. #5
    Join Date
    Jan 2008
    Location
    Upstate South Carolina
    Posts
    61
    Liked
    0 times
    Rep Power
    8
    Build a TPMS pressure tank. ie. PVC tube with a valve stem. Works great!
  7. #6
    Supporter DavidT.'s Avatar
    Join Date
    Jul 2006
    Location
    NorCal
    Posts
    1,530
    Liked
    0 times
    Rep Power
    1996
    I broke the bead on my spare tire and stuck all my tire sensors into the spare tire and then air'd it back up to 35 psi.
    2007 Tundra CrewMax SR5 4x4 TRD 5.7
    |Corsa Sport Exhaust|TRD Intake|Optitrons|Eclipse DVD/GPS|Factory 20's|Rapid Hitch|Headache Rack|Delta Toolbox|
  8. #7
    Veteran Member L R H's Avatar
    Join Date
    May 2002
    Location
    GA, USA
    Posts
    1,108
    Liked
    0 times
    Rep Power
    15
    Quote Originally Posted by DavidT. View Post
    That works, but if you ever need the spare to use as an actual spare, you will destroy 4 sensors. Make a pressureised PVC container for them.
  9. #8
    Join Date
    Jul 2006
    Location
    NorCal
    Posts
    1,530
    Liked
    0 times
    Rep Power
    1996
    Quote Originally Posted by L R H View Post
    They are taped on the wheel. Even if they did get loose, when the tire spins they get pushed onto the outside and roll along just fine due to the momentum and air pressure.
  10. #9
    Supercharged Member HOGWILD's Avatar
    Join Date
    May 2006
    Location
    Albuquerque
    Posts
    3,510
    Liked
    7 times
    Images
    12
    Rep Power
    578
    Quote Originally Posted by toywitu View Post
    did ya keep the original sensors and are they servicable? if so you can do what majority of people mentioned build a pressure chamber outta PCV and install it under truck. or take light bulb out?
  11. #10
    Supporter cwit's Avatar
    Join Date
    May 2007
    Location
    keeseville ny
    Posts
    1,355
    Liked
    9 times
    Images
    3
    Rep Power
    914
    I priced Ford & chevy why are Toyotas so expensive.
    Charlie & Linda
  12. #11
    Join Date
    May 2006
    Location
    Albuquerque
    Posts
    3,510
    Liked
    7 times
    Images
    12
    Rep Power
    578
    I have been trying to find a cheap replacement Toyota part for years without luck my 93 truck has had a group of expensive replacemnt parts recently and my 92 Camry started using a few of them just before i got rid of it!! Good Luck with your hunt!
  13. #12
    Junior Member krut29's Avatar
    Join Date
    Aug 2007
    Location
    Newnan, GA
    Posts
    107
    Liked
    2 times
    Rep Power
    108
    Question Re: air pressure sensors
    Just wondering, but can you reset the TPMS to accept zero PSI. I know some guy's have aired there tires down slightly, then reset the computer at the lower psi, then air the tires back up to normal PSI. Just an idea
    07 Tundra, 5.7, 4X4, ToyTec 3" level kit with rear add a leafs. Smitty Built Step Bars, Bull Bar, Pro Comp Lights, Rear Seat Mod, Falken 10Ply E Rated Tires Firestone Ride Rite airbags.
  14. #13
    veteran member Big_Al1's Avatar
    Join Date
    May 2005
    Location
    Lake Charles,LA
    Age
    35
    Posts
    1,756
    Liked
    12 times
    Images
    16
    Rep Power
    1100
    Quote Originally Posted by krut29 View Post
    No.But would be nice.
    Independent dealer at AMSOIL. http://www.amsoil.com/index.aspx?zo=5072667
  15. #14
    Join Date
    Feb 2008
    Location
    Good O'll Ok State
    Posts
    40
    Liked
    0 times
    Rep Power
    8
    y cant the pressure sensors be used in aftermarket tires? if you can remove them from the stock tires and put them into a custom pressure chamber, y couldent you epoxy them into your aftermarket rims and rebalance your tires? or put a counter weight on the other side?
  16. #15
    Veteran Member wildbill129's Avatar
    Join Date
    Nov 2007
    Location
    The State of Jefferson (Redding, CA)
    Posts
    984
    Liked
    14 times
    Images
    10
    Rep Power
    539
    Quote Originally Posted by rwblank View Post
    You can, depending on which wheels you have. You can also buy replacement for other types of wheels.
    2007 Crewmax 4x4 Limited - Silver, 2.5" OME Front Lift w/Toytec 1" Diff Drop, 1" Toytec Block rear w/Bilstein 5100 shocks, 18" Ultra Grinder Wheels, 285/70/R18 Toyo Open Country M/T, Line-X Bed Liner, Undercover Tonneau (Only in winter), Weathertech Floor Liners, Back-up Cam (Toyota/Rostra), 2008 JBL NAV, IPOD Adapter, Console Vault
    CBTMA Member
Quick Reply Quick Reply
Register Now
Your postal zip code.
Where you live.
Log-in
Human Verification
Posting Permissions
  • You may post new threads
  • You may post replies
  • You may not edit your posts
