Old 03-16-2008, 10:42 PM
zbfb10's Avatar
Dealer : Phil Bachman Toyota
2007 Toyota Tundra Super White
Last Online: 11-01-2009 09:09 PM
Images: 8
zbfb10 is on a distinguished road.
Send a message via AIM to zbfb10 zbfb10's Photo Albums
Question Biggest Tires Possible on Stock Rims w/ Leveling Kit?
okay, so i have been debating about getting rims or not, i figure just get bigger tires on my stock rims now then save up and get rims and tires later, maybe this summer. okay so i will be installing the Truxxx leveling kit with the 3'' in front and 1'' in the back. so what is the biggest size tire i can fit on the stock SR5 18 inch alloy wheels? i'm lookin at like between a 33 and 35 inch tire, just dont know if a 35 will fit without rubbing. i dont want any rubbing either. i have the Bridgestone Duelers and absolutely hate them, they suck in the rain, no traction at all. anyway appreciate the help guys!
also, i want an all-terrain tire...any suggestions or preferences?
-Brad
07 Tundra DC 5.7L w/ Sports Appearance Pkg
SUPER WHITE
Mods: Husky Liner Floor Mats~Billet Grill~Pioneer DEH-9800BT head unit~
Color Keyed Door Handles~Brushed Stainless Step Boards~Tow Mirrors~Truxxx 3'' front 1'' rear Leveling Kit~20x9 Ultra Goliaths Chrome~305/55/20 Pro Comp Xtreme A/T tires~AFE Cold Air Intake~Draw-Tite Hitch~Polk Audio db6501 Component Speakers~Polk Audio db5251 Component Speakers~Rockford Fosgate P3 Shallow Mount 10'' Sub~Alpine PDX-5 Amp~Flowmaster 50 Series - Dual Out w/ 4" rolled tips
My Truck - CarDomain
Old 03-17-2008, 01:08 AM
DanielAcosta's Avatar
Dealer : Earnhardt Toyota
2007 Toyota Tundra,
2009 Toyota Venza,
- Other - 05 Honda Odyssey
Last Online: 11-06-2009 08:07 AM
Images: 13
DanielAcosta is on a distinguished road.
DanielAcosta's Photo Albums
Default Re: Biggest Tires Possible on Stock Rims w/ Leveling Kit?
If you are willing to trim the skid plate, you can fit some (but not all) brands of 35x12.50x18 or smaller. The Toyo AT 285/75/18 I run is 35x11.50x18, great height but not as good looking as the BFG AT 305/65/18 I used to run.
07 DC SR5 TRD 4x4 5.7 TRD exhaust, 46K miles, 17 mpg city after battery disconnect reset. Truxedo Lo-Pro with deck rails. Front Susp: Stock coilovers, 4" lift (http://www.tundrasolutions.com/forum...6-4-inch-lift/), swapped extra spacers for Bilstein 5100s on lowest setting, wheel well height still 41.5." Rear Susp: ProComp ES3000 #326510 (2.25" taller than stock), 1.25" blocks plus PRG mini-pack (http://www.tundrasolutions.com/forum...and-new-truck/) gives 2.25" total lift, parking brake cable bracket spacers, wheel well height 43." Front diff and rear ds drop; trailer hitch electrical harness tucked up above bumper. After 20K miles swapped 305/65/18 BFG AT for 285/75/18 Toyo AT, still on stock 18x8x60 offset TRD wheels, about 1/8" clearance to sway bar. Like the extra height but miss the width. Next time either 305/70/, 295/70, or 35x12.50/18. Added 5th 285/75/18 Toyo AT as spare. Bed Bounce: Stiffer E-tires are worse than stock P-metric; biggest improvement from PRG mini-pack, slight improvement from shocks. Still a stiff ride but tolerable now. Best things about this truck: 5.7 and transmission, interior size and comfort, very quiet at high speed. Worst things about this truck: bed bounce, no VSC in 4wd, mileage sucks above 70.
Old 03-17-2008, 07:44 AM
zbfb10's Avatar
Images: 8
so you think i should go with a 305/65/18 BFG? thats what i was thinkin. because in the end i wanna add 20 inch rims and a 305/55/20 tire. the only difference between those two tires is like .4 of an inch with the 305/65/18 being taller. so will the 305/65/18 fit on the stock rims and fit without rubbing with my truxxx lift kit?
-Brad
SUPER WHITE
Old 03-17-2008, 08:40 AM
2007 Toyota Tundra,
2009 Toyota Venza,
Images: 13
Yes if you are willing to bend or trim the skid plate.
Old 03-17-2008, 09:42 AM
NYPDBLUE's Avatar
Dealer : Maroone Toyota Scion
Last Online: 06-18-2009 10:04 PM
Images: 25
NYPDBLUE is on a distinguished road.
NYPDBLUE's Photo Albums
Here are my 305 / 65 / 18 BFG on Stock Wheels with ReadyLift 2.5" & SKID PLATE CUT ..
Make note: I get a new truck every 2 - 3 years so I rushed the cut of the skid plate as I couldnt give a crap what it looked like since im returning the truck after the lease and getting a new tundra.
Pics attached.
Biggest Tires Possible on Stock Rims w/ Leveling Kit?-beach-new-tires-2.jpg   Biggest Tires Possible on Stock Rims w/ Leveling Kit?-cimg0808.jpg   Biggest Tires Possible on Stock Rims w/ Leveling Kit?-cimg0809.jpg   Biggest Tires Possible on Stock Rims w/ Leveling Kit?-cimg0883.jpg   Biggest Tires Possible on Stock Rims w/ Leveling Kit?-driver-side-step.jpg
LIFE IS A BEACH EVERYDAY !
2007 Tundra DC 5.7 4x4 SR5 (Black Ext./ Tan Int. Cloth), 2.5" Readylift w/ BFG 305/65/18 AT on Stock 18x8 Wheels, Husky Floor Liners front and Rear, Milemarker 9000lbs rear mounted winch setup w/ double ball w/ 1 7/8' & 2 " combo
Old 03-17-2008, 12:39 PM
2007 Toyota Tundra,
2009 Toyota Venza,
Images: 13
Note that it is not necessary to cut the skid plate. You can just bend the sides up so they are parallel with the sway bar.
Old 03-17-2008, 12:44 PM
mxsjw's Avatar
Jedi Ninja in Training
Dealer : Toyota of Puyallup
- Other - 2003 VW Passat,
Images: 10
mxsjw's Photo Albums
True...
Like this
Before
and After
Beer please!
Old 03-17-2008, 12:48 PM
larsenvega's Avatar
Dealer : Nye Frontier Toyota/Scion
2006 Toyota RAV4 4WD Sport,
2007 Toyota Tundra 5.7L 4X4 DC
Last Online: 11-04-2009 11:07 PM
Images: 5
larsenvega is on a distinguished road.
larsenvega's Photo Albums
I am running the BFG 305/65R18's as well, and all I had to do was bend the skid plate back. It is more pliable than you would think. I turned each wheel to the full extent of each direction and bent it back with a pair of pliers. Took a grand total of about 5 minutes for both sides, and I haven't had a problem or rub since.
2007 5.7L TRD DC 4X4 Pyrite Mica w/Westin bull bar, Line-X spray liner, ARE CX Series topper, 305/65R18 BFG AT/KO's, 2.5" front/1" rear RevTek lift, Viper 2-way remote starter w/alarm, WeatherTech floor liners, JBL BlueTooth option, stainless Toyota running boards, mudguards & cold kit.
Old 03-18-2008, 02:24 PM
Dealer : Checkered Flag Toyota
Last Online: 10-08-2009 02:34 PM
bds13 is on a distinguished road.
bds13's Photo Albums
I have the Truxxx 3" front and 1" rear lift with 285/75/18 Toyo ATs (34.8" x 11.3") on stock TRD rims. I trimmed the skidplate slightly and now there is no rubbing. See my gallery for pics.
Old 03-18-2008, 09:07 PM
zbfb10's Avatar
Images: 8
i must say i do like your truck and tires...i still like the aftermarket rims tho but not sure i wanna spend the money for them
-Brad
SUPER WHITE
