Old 03-17-2008, 12:52 PM
Barney_Fife's Avatar
Dealer : Toyota of Plano
2007 Toyota Tundra,
- Other - 2007 Mercedes C230
Last Online: Yesterday 10:39 PM
Images: 123
Barney_Fife is more than famous, they're infamous. Barney_Fife is more than famous, they're infamous. Barney_Fife is more than famous, they're infamous. Barney_Fife is more than famous, they're infamous. Barney_Fife is more than famous, they're infamous. Barney_Fife is more than famous, they're infamous. Barney_Fife is more than famous, they're infamous. Barney_Fife is more than famous, they're infamous. Barney_Fife is more than famous, they're infamous. Barney_Fife is more than famous, they're infamous. Barney_Fife is more than famous, they're infamous.
Barney_Fife's Photo Albums
Default anyone warp brake rotors yet?
i'll admit i kinda do drive my truck a little hard- not as hard as the patrol car at work but i feel work habits rubbing off on my personal life. plus i tow a boat all summer long as long as the weather is nice so....i noticed yesterday in a sudden brake situation when some dumbaz cut me off on the highway that my rotors are warped....ive got 13k on the ticker...anyone else have to have the rotors turned yet and how much? im not complaining about the issue because i dont think its a flaw....i think its driver induced so oh well.
Old 03-17-2008, 01:04 PM
DanielAcosta's Avatar
Dealer : Earnhardt Toyota
2007 Toyota Tundra,
2009 Toyota Venza,
- Other - 05 Honda Odyssey
Last Online: 02-17-2010 11:51 PM
Images: 13
DanielAcosta is on a distinguished road.
DanielAcosta's Photo Albums
Default Re: anyone warp brake rotors yet?
Yours is the first I have heard. I am at 23,000 miles, and there are others here with a lot more miles than that.
07 DC SR5 TRD 4x4 5.7 TRD exhaust, 48K miles, 17 mpg city after battery disconnect reset. Truxedo Lo-Pro with deck rails. Front Susp: Stock coilovers, 4" lift (http://www.tundrasolutions.com/forum...6-4-inch-lift/), swapped extra spacers for Bilstein 5100s on lowest setting, wheel well height still 41.5." Rear Susp: ProComp ES3000 #326510 (2.25" taller than stock), 1.25" blocks plus PRG mini-pack (http://www.tundrasolutions.com/forum...and-new-truck/) gives 2.25" total lift, parking brake cable bracket spacers, wheel well height 43." Front diff and rear ds drop; trailer hitch electrical harness tucked up above bumper. After 20K miles swapped 305/65/18 BFG AT for 285/75/18 Toyo AT, still on stock 18x8x60 offset TRD wheels, about 1/8" clearance to sway bar. Like the extra height but miss the width. Next time either 305/70/, 295/70, or 35x12.50/18. Added 5th 285/75/18 Toyo AT as spare. Bed Bounce: Stiffer E-tires are worse than stock P-metric; biggest improvement from PRG mini-pack, slight improvement from shocks. Still a stiff ride but tolerable now. Best things about this truck: 5.7 and transmission, interior size and comfort, very quiet at high speed. Worst things about this truck: bed bounce, no VSC in 4wd, mileage sucks above 70.
Old 03-17-2008, 01:07 PM
RONE's Avatar
Dealer : Little Apple Toyota
2008 Toyota Tundra 5.7L SR5 4x4 DC
Last Online: Yesterday 06:09 PM
RONE is the One. RONE is the One. RONE is the One. RONE is the One. RONE is the One. RONE is the One. RONE is the One. RONE is the One. RONE is the One. RONE is the One. RONE is the One.
RONE's Photo Albums
I assume because it is a wear item Toyota will not cover it (I realize you are not asking for them to, but should anyone else have this same problem). Do you downshift to help your braking when you are towing?
Old 03-17-2008, 02:35 PM
CrewMaxCrushinU25's Avatar
Dealer : Toyota Scion of Hollywood
Last Online: 01-05-2010 02:37 AM
CrewMaxCrushinU25 is on a distinguished road.
CrewMaxCrushinU25's Photo Albums
happened to me too at 10k replaced em in a week no more porblems and i drive my tundra like i stole from the day i drove it off the lot its been nothing but abuse and she loves it
CrewMax Crushin U SR5 4x4 TRD
Old 03-17-2008, 02:40 PM
thumbster's Avatar
Moderator
Dealer : Capitol Toyota
2005 Toyota Corolla,
2007 Toyota Tundra 5.7 RC SB SR5 Sport
Last Online: Yesterday 06:55 PM
thumbster is the One. thumbster is the One. thumbster is the One. thumbster is the One. thumbster is the One. thumbster is the One. thumbster is the One. thumbster is the One. thumbster is the One. thumbster is the One. thumbster is the One.
thumbster's Photo Albums
If you're backing into the water or you park your truck outside during rain it's quite possible you have some hard spots on the rotors from residual surface rust that embedded itself into the rotor material. In this case they are technically not warped, but you feel the shaking from the pads intermittently grabbing better onto the softer parts of the rotor. If your pedal isn't pulsating you have hard spots - the only way to get rid of those is to have the rotors machined or replaced. Driving through large puddles with hot brakes will do the same.
Most older toyotas I've owned had this problem - mostly from the brakes being too small for the vehicle's weight. The tundra's brakes should be better than average due the size, but it's possible to warp any brakes if you ride them alot putting lots of heat into them, especially when towing.
1995 Mercury Villager - the man van
Old 03-17-2008, 02:45 PM
cwit's Avatar
Dealer : New Country Toyota
2007 Toyota Tundra,
2006 Toyota Camry-Solara black moon roof
Last Online: Yesterday 05:14 PM
Images: 3
cwit is a glorious beacon of light. cwit is a glorious beacon of light. cwit is a glorious beacon of light. cwit is a glorious beacon of light. cwit is a glorious beacon of light. cwit is a glorious beacon of light. cwit is a glorious beacon of light.
cwit's Photo Albums My eBay
If you were doing a hard stop could it bee ABS pulsing.
Charlie & Linda
Old 03-17-2008, 02:51 PM
thumbster's Avatar
Moderator
Good point!
Old 03-17-2008, 03:11 PM
shadyskins's Avatar
Dealer : Tri County Toyota
2007 Toyota Tundra Crewmax Bench Seat,
- Other - 2008 Civic Si Sedan,
1999 Lexus LX470 SOLD - 182,000 Miles
Last Online: 02-09-2010 10:59 AM
Images: 14
shadyskins is on a distinguished road.
shadyskins's Photo Albums
I have done that myself on more then 1 occasion now.....
2007 CrewMax SR5 4x4 5.7 Nautical Blue
My Pictures
TRD Rear Sway Bar, Pioneer FH-P8000BT w/ Sirius, Carriage Works Black Replacement Grille + Top Insert, Color Matched Sequoia Door Handles, Bench Seat, Dual Headrest DVD, back up camera w/monitor, Nüvi 660, Line-x, undercover, Tekonsha P3, debadged, enjoyed since 7/20/2007
FUTURE MODS -
25-30 ft Travel Trailer....... bye bye Pop-Up
Old 03-17-2008, 03:44 PM
2007 Toyota Tundra,
Images: 123
naw. i know what that is...its definetly a jigglein sensation from warped rotors....i do routinely downshift when slowing but the hardest ive ever braked was last summer when the lady was standing in the middle of the highway attempting suicide in front of our truck with boat in tow....i stood on the brakes and it stopped well. i dont feel it under normal driving only when slowing from oh lets just say upwards of 70mph... but not hard enuf for ABS to engage jsut enuf to squeeze on the brakes a bit. ill have them check them next tiem i go in for service and see what they want to turn them...and no, i dont hack in far enuf to get into the water - trailer tongue much too long to need to do taht....but i do occasionally splash a water puddle for fun....
Old 03-17-2008, 03:55 PM
mral1515's Avatar
Dealer : Vandergriff Toyota
2007 Toyota Tundra,
2006 Toyota 4Runner,
- Other - 1983 Celica Supra
Last Online: 01-16-2010 07:10 PM
mral1515 is on a distinguished road.
mral1515's Photo Albums
I am in the middle of changing jobs. Next week I will be a team leader at Vandergriff Toyota. If you want to bring it to me next week or so I will see what I can do for you.
Matt
Master Toyota Tech
ASE Master Tech
Shop Foreman
16 years with Toyota
Old 03-17-2008, 05:15 PM
Banned
2008 Toyota Tundra SR5 CM TRD 4x4 5.7,
- Other - Toyota FJ60
Last Online: 07-18-2008 12:35 PM
Sequoia2003 may have some regrets.
Sequoia2003's Photo Albums
Brakes are a touchy subject. I am very gentle with my brakes and they seem to last forever. I never hold the brake down after a long hard stop as the contact of the pad to the disc will contribute to warping the rotors. I will usually either put in park and release the rear brake or move forward a foot every few seconds to put contact to other areas of the rotor. My last Tundra had warped rotors at 27k miles so we'll see and it had over size mud tires so do all my trucks and this Tundra will be now different prior to winter. I'll keep you posted, but right now with 850 miles not warping yet.
Old 03-17-2008, 05:33 PM
2007 Toyota Tundra,
Images: 123
Matt
PM sent and this is what forums and this type of online community is all about. we need more people like him.
Old 04-05-2008, 12:12 AM
Dealer : Hobbie Toyota
Last Online: 02-04-2010 03:13 PM
rxbike is on a distinguished road.
Send a message via Skype™ to rxbike rxbike's Photo Albums
Mine are warped at 28xxx miles. Pads are fine with lots of life. Minor warping , noticed them most when coming down the grapevine the other day. (in california on I-5).
Dealer wants 180 to cut rotors and recommend new pads ~60 at the same time too.
I drove her hard when I first got her but not in the last 15000 miles though. Guess the beefy looks don't hold up to use. Never had this problem on my ford dually
salsa red DC reg bed.
Truxedo Lo-Pro, bed extender.
Pioneer AVIC-D3 Navi w/ backup camera and bluetooth/ipod controller
Polk Audio 6.5" and 5.25" seperates -mids/highs
Pioneer 10" shallowmount sub under rear drivers
Memphis Audio 4ch and Infinity Reference Mono Amp
Dual headrest 7" DVD system
H11 and 9005 HID upgraded headlights.
TRD CAI and TRD Sway Bar
Limited 20" wheel/tires combo
Future: TRD Supercharger
Old 04-05-2008, 02:40 AM
Dealer : Centennial Toyota Scion
2007 Toyota Tundra CM, SR5, 4X4, 5.7,
1995 Toyota T100 2.7L,
- Other - '01 Ford F-250 Crew Cab, V10
Last Online: Yesterday 02:10 PM
Time4change has much to be proud of. Time4change has much to be proud of. Time4change has much to be proud of. Time4change has much to be proud of. Time4change has much to be proud of.
Time4change's Photo Albums
Interesting.
In need of my 3rd set of rotors on my '01 Super Duty in less than 70,000 miles.
Prior to '05, the Ford brakes were tiny in comparison to the current Tundra's rotors.
Even after '05, the 3/4 ton >Super Duty rotors are "almost" as large as the 1/2 ton Toyota's.
In 10,000 fairly hard miles, my Tundra brakes are pulsate/warpage free.....
'07 Cmax, SR5, 4X4, 5.7....'08 Shelby GT-500....'07 Lincoln MKZ.....'99 Fleetwood 34' class A (Ford Power)....'95 T-100, 2.7L......and about 7 other vehicles that I don't want to bore you with.
Old 04-05-2008, 02:51 AM
hihocarp's Avatar
Dealer : Country Hills Toyota
2005 Lexus RX330,
2007 Toyota Tundra 5.7 LTD DC,
- Other - 74 Challenger 493
Last Online: 03-02-2010 10:04 PM
hihocarp is on a distinguished road.
hihocarp's Photo Albums
Originally Posted by Time4change View Post
Interesting.
My Super duty made it to 110,000 km before it needed a set of front pads. Didn't turn the rotors but they are starting to pulsate now at 159,000 km. That was pulling a 12,000 lb 5th wheeler.
The Tundra has 25,000 km & so far no issues.
[/SIGPIC]07 Slate metallic DC 5.7 Limited.
Mods:
Truxx 3'' & 1'' lift kit
Sirius interface
Pioneer amp & dual 10'' shallow mount subs
Line x bed liner
Access roll up tonneau cover
Driv Moonshine 20'' wheels
Toyo OC 305/55/20 tires
Weather tech bug deflector
Ranger nerf bars
Red painted calipers
Window tint to match rear windows.
Dual DVD headrests
Ghost Flames
Door sill protectors
Dual exhaust [V force]
Other Cars: 05 Lexus RX 330, 03 Superduty, 74 Challenger, 67 Firebird convertible
