This is a discussion thread titled "Can Toyota tell me what sensor is bad?", within the Tundra forum, part of the Truck Forums category.
Old 03-17-2008, 04:47 PM
Wildbill Tundra's Photo Albums
Last Online: 11-20-2008 11:02 PM
Wildbill Tundra is on a distinguished road.
Default Can Toyota tell me what sensor is bad?
When I got the new rims and tires the retard at discount broke one of my sensors. Discount ordered me a new one and now it still doesn't work. My light is still on and it wont reset. Maybe the new one they got is bad or maybe they damaged one of the others also. Can Toyota hook it up and see what one is malfunctioning? Discount is paying for everything
07 Salsa Red Pearl 5.7 DC..TRD, Leather, JBL radio.
MODS: Readylift...20 inch chrome Ultra Goliaths...Nitto Grapplers 305/55/20...Volant Intake...TRD Shifter...Led's
Old 03-17-2008, 04:52 PM
Dealer : Dave Mungenast Alton Toyota
Boynamedsue's Photo Albums
Last Online: 11-24-2008 07:34 PM
Boynamedsue is on a distinguished road.
Default Re: Can Toyota tell me what sensor is bad?
if they are paying for it i would take it to toyota and not mess with it. Ive replaced these at work and they are kinda fragile and can be easily damaged if you dont pay attention. one may be been visually damaged but they may have done damage to another thats not noticeable.
2007 Tundra RCSB 4.7L SR5. Debadged
1968 Chevelle tall deck big block 468. Everyone loves that A body Shuffle
Old 03-17-2008, 05:01 PM
Wacked's Avatar
Dealer : Atkinson Toyota
2007 Toyota Tundra Salsa Red Crewmax,
1995 Toyota Truck 4x4 Extra Cab
Wacked's Photo Albums
Last Online: Today 09:36 AM
Wacked is on a distinguished road.
IIRC they have to use a TechStream to program the new sensor I.D. into the computer, if Discount Tire did not do it that way someone will have to take the tire off the rim to get the I.D. then program it into the computer. Take it to the dealer and have them pull the tire/tires off and reprogram.
2007 Salsa Red Limited Crewmax
Nav, Sonar, 20" Carved Wheels
Born in TEXAS Built by TEXANS
Old 03-17-2008, 05:22 PM
Shogren65's Avatar
Dealer : Harr Toyota
Shogren65's Photo Albums
Last Online: Today 10:16 AM
Shogren65 is on a distinguished road.
Send a message via AIM to Shogren65
To answer your question YES they can tell you which sensor is not reading. I had wheels put on and they broke a sensor. Couldn't figure it out myself so I called a friend of mine who is a Toyota tech and he was able to tell me that the right front sensor was not reading and he was right.
'07 DCSB Radiant Red TRD w/ Black Cloth
Mods: Toytec 3" w/ PRG Mini Pack, Pro Comp 6066 w/ 305/55/20 BFG AT K/O's, Complete LED interior, V-LED's Dual Color front signals, Backup Camera, Magnaflow Cat-Back, TRD CAI, Uni-Chip w/ Flux Display, TRD Sway-Bar, RS9000XL, N-FAB bars, Extang Top, 20% Tint, Wet Okoles, Strada Nav, Color Matched Grill
Updated: 11-10-08
Future Mods: LED Tail Lights.
08' RXP-X - Riva X-Charger @ 12#s of Boost, 50# Inj., Gibson Exhaust w/ J-Pipe, Gen-1 IC w/ Alum. Tubes, Reduction Nozzle, Catch Can, Impros 15/22, RE Block Offs, Riva Grate, Riva Sponsons, Cut Bucket, 4 Flow-Rites, Black Grills, Riva Seat Cover, and Livorsi Boost Gauge.
Old 03-17-2008, 05:28 PM
DanielAcosta's Avatar
Dealer : Earnhardt Toyota
DanielAcosta's Photo Albums
Last Online: Today 08:18 AM
DanielAcosta is on a distinguished road.
Been through this twice with Discount. You need the number off the old broken and new replacement sensor. Take both numbers to your dealer. They have to plug in Techstream, record the remaining 3 sensor numbers, erase all of them, then type in the 3 old plus fourth new one. If you and Discount are lucky, the dealer will not charge for this. They might charge 1/2 hour labor. If they want to charge more, they are just taking advantage.
On the other hand, if you don't have the old and new codes, then you have to break the bead to record the number on all 4 sensors. Expect to pay an hour labor if you have to go that route.
07 DC SR5 TRD 4x4 5.7 TRD exhaust, 35K miles, 17 mpg city after battery disconnect reset & removing extra (charcoal?) air filter. Truxedo Lo-Pro with deck rails.
Front Susp: Stock coilovers, 4" lift (http://www.tundrasolutions.com/forum...6-4-inch-lift/), just swapped extra spacers for Bilstein 5100s on lowest setting, wheel well height still 41.5."
Rear Susp: ProComp ES3000 #326510 (2.25" taller than stock), 1.25" blocks plus PRG mini-pack (http://www.tundrasolutions.com/forum...and-new-truck/) gives 2.25" total lift, parking brake cable bracket spacers, wheel well height 43."
Front diff and rear ds drop; trailer hitch electrical harness tucked up above bumper.
After 20K miles swapped 305/65/18 BFG AT for 285/75/18 Toyo AT, still on stock 18x8x60 offset TRD wheels, about 1/8" clearance to sway bar. Like the extra height but miss the width. Next time either 305/70/18 or 35x12.50/18.
Added 5th 285/75/18 Toyo AT as spare. Foam pad above spare to help with bed bounce.
Bed Bounce: Stiffer E-tires are worse than stock P-metric; biggest improvement from PRG mini-pack, slight improvement from shocks and foam pad above spare. Still a stiff ride but tolerable now.
Best things about this truck: 5.7 and transmission, interior size and comfort, very quiet at high speed.
Worst things about this truck: bed bounce, no VSC in 4wd, mileage sucks above 70.
Old 03-17-2008, 05:31 PM
You have a smarter than average tech. Would still need the number off the new sensor, as you can't scan it electronically like you can with Nissan. Otherwise you will still have to break the bead to record the number off the new sensor.
The other limitation I already pointed out: you can't just enter the new sensor number in place of the bad one. You have to write them all down, delete them, then enter all four. Cumbersome imo.
Old 03-17-2008, 05:59 PM
HOGWILD's Avatar
Dealer : American Toyota
2006 Toyota Tundra,
1993 Toyota Truck,
2007 Scion tC
HOGWILD's Photo Albums
Last Online: Today 12:06 AM
HOGWILD will become famous soon enough.
Politicians and Electronics gotta love it! I would hope toyota could tell you what sensor was bad, if not i would change dealerships!
Old 03-17-2008, 06:51 PM
Banned
Dealer : Gray Daniels Toyota
blanksb's Photo Albums
Last Online: 07-01-2008 09:44 PM
blanksb is on a distinguished road.
This is incorrect. I just went through this on Friday. They don't have to break the bead on all four tires as long as you know which tire was replaced. All they have to do is pull the tire that was replaced and get the new ID number. When they first plug it up BE SURE and write down all 5, yes 5 includes the spare, numbers. Start by typing in your new sensor id # as tire 1. If that doesn't work try it as tire 2 and so on. No need to pull all tires and if there was it would be pulling 5 tires because the spare also has a sensor in it that must be recorded. Your dealer should be able to do it without a problem.
Old 03-17-2008, 07:13 PM
If you read what I wrote you will see you are saying exactly what I said, although you did point out that if you are smart enough to know which tire has the new sensor, then worst case you only need to break the bead on that one tire. There are plenty, though, who have done it the hard way and broken down all 4 tires.
The 07's, btw, do NOT have sensors in the spare.
Old 03-17-2008, 09:17 PM
Banned
I have an 07 and while I have not seen the sensor in my spare I do know that when hooked up to the computer, there are 5 different sensor ID numbers and the service tech that was writing down the numbers said that it did indeed have one in the spare.
Old 03-17-2008, 09:27 PM
HOGWILD's Avatar
2006 Toyota Tundra,
1993 Toyota Truck,
2007 Scion tC
07's schematic for TPMS does not mention a sensor in spare. Says it only monitors the 4 on the ground! other year models do have 5 as in my 06 DC and i wished it had "0" the tool will work on more than one model Tundra
Old 03-17-2008, 09:33 PM
It is true there are locations in the truck's computer for 5 sensors, because I saw it myself with the Techstream hooked up. However, the line for the spare is blank. Owner's manual also mentions no sensor in the spare iirc.
If your tech found an actual entry for the spare, then you have something the rest of us with an 07 don't have, or your tech didn't know what he was doing.
Old 03-18-2008, 06:08 PM
Dealer : Right Toyota
bretsuaz's Photo Albums
Last Online: 11-28-2008 08:34 PM
bretsuaz is on a distinguished road.
Around here Toyota charges 150.00 just to reprogram.
Old 03-18-2008, 07:29 PM
Big_Al1's Avatar
Dealer : Lake Charles Toyota
2005 Toyota Tundra,
2008 Toyota Sienna XLE
My eBay Big_Al1's Photo Albums
Last Online: Today 07:54 AM
Big_Al1 is on a distinguished road.
Send a message via Yahoo to Big_Al1
Talk about a rip-off got mine for under $40.
