  #241 (permalink)
Old 04-08-2008, 07:12 PM
DanielAcosta's Avatar
Dealer : Earnhardt Toyota
2007 Toyota Tundra,
2009 Toyota Venza,
- Other - 05 Honda Odyssey
Last Online: Yesterday 10:15 AM
Images: 13
DanielAcosta is on a distinguished road.
DanielAcosta's Photo Albums
Default Re: Rides Like a BRAND NEW Truck!
Originally Posted by rackman View Post
I have the TRD and a factory tow hitch. I tried the Rancho adjustables and any improvement was on the softest setting, but it was minimal. I removed them when I met with the factory rep. and put the Bilsteins back on because I didn't want to hear any BS about the shocks. (they are sitting in my basement) I'm beginnig to think that I need a stiffer spring and softer shock set-up. I also want to compare shackle types. Over all I like the truck but as a first time Toyota owner, I'm not to happy with their (lack of) response to this problem. T -2 years to trade and back to Chevy?
As a previous 01 Silverado Ext Cab Z71 4x4 owner, the 07 Silverado was on my short list when I bought my 07 Tundra TRD 4x4 DC. My guess is the 07 Silverado would probably ride better on I-10 through Beaumont, similar to how my 01 rode better than the Tundra. However, there are so many things I like better on the Tundra than the Silverado that I would still choose the Tundra. The PRG mini-pack improvement to the ride just makes the Tundra that much more enjoyable.
In contrast to what you said, I think the combination of the mini-pack, which is softer than the stock overload, along with softer shocks than the Bilsteins is what has given me a better ride. The stiff stock overload spring seems to be the main cause of the bed bounce, as virtually everyone has said the ride is significantly better when they swap the overload for the mini-pack, even with the stock shocks. In fairness, I believe there have been two in this thread who reported the ride wasn't "significantly" better.
07 DC SR5 TRD 4x4 5.7 TRD exhaust, 46K miles, 17 mpg city after battery disconnect reset. Truxedo Lo-Pro with deck rails. Front Susp: Stock coilovers, 4" lift (http://www.tundrasolutions.com/forum...6-4-inch-lift/), swapped extra spacers for Bilstein 5100s on lowest setting, wheel well height still 41.5." Rear Susp: ProComp ES3000 #326510 (2.25" taller than stock), 1.25" blocks plus PRG mini-pack (http://www.tundrasolutions.com/forum...and-new-truck/) gives 2.25" total lift, parking brake cable bracket spacers, wheel well height 43." Front diff and rear ds drop; trailer hitch electrical harness tucked up above bumper. After 20K miles swapped 305/65/18 BFG AT for 285/75/18 Toyo AT, still on stock 18x8x60 offset TRD wheels, about 1/8" clearance to sway bar. Like the extra height but miss the width. Next time either 305/70/, 295/70, or 35x12.50/18. Added 5th 285/75/18 Toyo AT as spare. Bed Bounce: Stiffer E-tires are worse than stock P-metric; biggest improvement from PRG mini-pack, slight improvement from shocks. Still a stiff ride but tolerable now. Best things about this truck: 5.7 and transmission, interior size and comfort, very quiet at high speed. Worst things about this truck: bed bounce, no VSC in 4wd, mileage sucks above 70.
  #242 (permalink)
Old 04-08-2008, 09:38 PM
Dysan911's Avatar
Dealer : Arlington Toyota Scion
Last Online: Today 07:57 AM
Dysan911 is on a distinguished road.
Dysan911's Photo Albums
Quick question.. Not sure if most of you that installed your mini-pak installed that little bolt that encloses the C-clip piece on either end. I know Thirdhorseman said they end up squeeking/rattle so he left his off.
Would those have any capability of causing any sort of bind or prevent the mini-pak from rebounding like it should. Maybe I should remove mine or do you think they make no difference at all.
  #243 (permalink)
Old 04-08-2008, 09:47 PM
2007 Toyota Tundra,
2009 Toyota Venza,
Images: 13
I have mine installed. No squeaks or rattles.
  #244 (permalink)
Old 04-08-2008, 09:50 PM
guntech's Avatar
Benny Hill
Dealer : Prestiqe Toyota
2003 Toyota Camry,
Images: 71
guntech has done just about everything. guntech has done just about everything. guntech has done just about everything. guntech has done just about everything. guntech has done just about everything. guntech has done just about everything. guntech has done just about everything. guntech has done just about everything. guntech has done just about everything. guntech has done just about everything. guntech has done just about everything.
guntech's Photo Albums
Mine are installed also. I also have no squeaks or rattles.
  #245 (permalink)
Old 04-08-2008, 11:42 PM
Dealer : Carson Toyota Scion
Last Online: 02-26-2009 11:33 PM
e22mmit is on a distinguished road.
e22mmit's Photo Albums
I went ahead and installed my Ranchos today. Put them on setting #1, then went for a ride. Still vibrated. It shakes really bad at 75 mph. Anyway, When I got home I went ahead and changed the setting to #4. Will see if that makes a difference in the morning. I am debating if I should remove one of the leafs from the mini pack. Will talk to greg in the morning. Any here is a picture of the mini pack installed and my truck.
Rides Like a BRAND NEW Truck!-img_7205.jpg   Rides Like a BRAND NEW Truck!-img_7212.jpg   Rides Like a BRAND NEW Truck!-img_7206.jpg
  #246 (permalink)
Old 04-09-2008, 12:26 AM
2007 Toyota Tundra,
2009 Toyota Venza,
Images: 13
Are you saying it vibrates all the time at 75, or it bounces excessively on choppy roads at 75? 75 is a common speed for vibration from wheel imbalance. If your vibration is there on asphalt, that sounds like a very different problem than the more classic Tundra bed bounce on choppy surfaces like southern California's freeways.
  #247 (permalink)
Old 04-09-2008, 04:44 AM
los211's Avatar
Dealer : Piercey Toyota Scion
2007 Toyota Tundra,
2005 Toyota Sienna The wifes "bus"
Last Online: Today 05:46 AM
Images: 6
los211 is on a distinguished road.
los211's Photo Albums
still waiting for mine to come in.
'07 SR5 DC 5.7 silver sky metalic
5% tint rear windows, 2 Flowmaster 40 series w/ dual tips out the back, Carriage Works polished grill overlay w/emblem, 3-piece bumper inserts (not CW), Airaid, Ground Force rear shocks, DJM 3" arms, belltech flip kit, 22" BOSS 329 w/ 305/45/22 General grabber UHP, G2 bakflip.
  #248 (permalink)
Old 04-09-2008, 07:31 PM
The vibration occurs on concrete freeways only. It actually rides good on asphalt. Setting #4 on the shocks didn't change much. I am going to move it up to #6.
  #249 (permalink)
Old 04-10-2008, 09:31 AM
Dealer : Poway Toyota
- Other -
Last Online: Yesterday 10:25 PM
mlinder is on a distinguished road.
mlinder's Photo Albums
Well,
After installing my mini pack last week, I finally got to drive the bad sections on I-52 here in San Diego.
Although city street driving and my backroads commute to work are improved, the experience was actually WORSE on the interstate than before the springs were installed.
I have Ranchos on the rear, set to the softest number (0), which may be my problem. I guess I have to find a setting on the shocks that is a happy medium between city driving and highway driving.
Mark
  #250 (permalink)
Old 04-10-2008, 11:15 AM
2007dctundra4x4's Avatar
Dealer : Appleway Toyota
Last Online: Yesterday 07:57 PM
2007dctundra4x4 is on a distinguished road.
2007dctundra4x4's Photo Albums
i've never had bed bounce of any kind, not sure if the weight of the camper shell alleviates this, but i didn't notice anything with the topper off either...i have driven all the way across the country and back...with no bounce...i ordered a set anyway to soften the ride and for the extra inch of lift, but i think i am not going to install them and i am going to return them...i just bought a new travel trailer and do not want to lose the payload...
2007 DoubleCab Tundra TRD 4x4
Silver Sky
Sway-a-way Coliovers
Total Chaos UCA's
Mickey Thompson Baja ATZ 35x12.50x20
BMF Novacane wheels
SnugTop camper shell
Black headlight mod
Plated body mount
Kenwood DNX7100 Nav/ipod/backup camera
  #251 (permalink)
Old 04-10-2008, 03:42 PM
Dealer : Toyota of Morristown
Last Online: 06-23-2009 08:12 AM
rackman is on a distinguished road.
rackman's Photo Albums
After seeing the pics of the mini-pack posted by e22mmit I decided to order the SS7 supersprings. I am hoping they extend outward more and I have a feeling the problem lies more in the top (longer) leafs. I was thinking about having a pair of springs made, but I just don't know how far and how much time and $$$ I want to go with this. I'll try them with the Bilsteins and the Ranchos and, I think their are two different pre-loads on the SS's. Again, I don't have the bed bounce at highway speeds, probably because on the east coast we have POLICE with RADAR and besides, I don't drive 100 MPH on the highway. But I'll post results on the bed aftershock jiggle thing once the springs are in.
  #252 (permalink)
Old 04-10-2008, 03:46 PM
ThirdHorseman's Avatar
Apocalyptic Wit
Dealer : Toyota Of Turnersville
Images: 14
ThirdHorseman has blessed us with their presence. ThirdHorseman has blessed us with their presence. ThirdHorseman has blessed us with their presence. ThirdHorseman has blessed us with their presence.
ThirdHorseman's Photo Albums
Good luck! Let us know how they work.
  #253 (permalink)
Old 04-10-2008, 06:23 PM
s3av8r's Avatar
Dealer : Foothills Toyota
2007 Toyota Tundra 5.7 SLATE CM TRD 4X4
Last Online: 11-14-2009 12:50 AM
s3av8r is on a distinguished road.
s3av8r's Photo Albums
Actually, at that speed, you would not have any bounce.
Fast or Slow = GOOD
Normal Highway Speed = BAD
Please let us know how the SS7s turn out.
FLY NAVY
  #254 (permalink)
Old 04-10-2008, 06:32 PM
mxsjw's Avatar
Jedi Ninja in Training
Dealer : Toyota of Puyallup
- Other - 2003 VW Passat,
Images: 10
mxsjw's Photo Albums
Supersprings have 4 settings from soft to hard...but they are actual overload springs, I don't see how they are going to help the complaint.
I have them (SSA7's) and they serve a purpose, to carry extra weight without sagging, but when unloaded the back end is a bit stiffer.
I guess I am confused on how you think they are going to help.
I don't have this excessive bounce thing and never have.
Beer please!
  #255 (permalink)
Old 04-10-2008, 07:00 PM
Dealer : Oakbrook Toyota In Westmont
2002 Toyota Tundra,
1999 Toyota Camry,
2005 Toyota Camry,
2007 Toyota Tundra DC 4x4 1D6/Black Bnh
Last Online: Today 01:38 AM
RichR is on a distinguished road.
RichR's Photo Albums
I also have not experienced the bounce.
I have a DC TRD with a shell on the rear.
I did have a short test drive in a DC without the TRD.
I felt some bouncing motion.
I'll get my first road trip at the end of the month!
Former Dodge Boy
Now a Toyota Man
Proud to be doing
Life@TS
