This is a discussion thread titled "Calibration and Hello...", within the Tundra forum, part of the Truck Forums category.
Just dropping by to say Howdy to everyone here. I have a 08`Tundra CrewMaxx 4x4 lifted 6" with 35"x12.5x20" wheels. Is there some way to have it calibrated,dealer does not do it, 4 wheel parts does not do it either, who`s left? Any suggestions would be helpful...
Thanxs,
TALTXN
Do a search. There is an aftermarket kit you can buy, or you can just use your gps. 35" tires, which is what I run, are about an 8% difference from stock.
__________________ 07 DC SR5 TRD 4x4 5.7 TRD exhaust, 35K miles, 17 mpg city after battery disconnect reset & removing extra (charcoal?) air filter. Truxedo Lo-Pro with deck rails.
Rear Susp: ProComp ES3000 #326510 (2.25" taller than stock), 1.25" blocks plus PRG mini-pack (http://www.tundrasolutions.com/forum...and-new-truck/) gives 2.25" total lift, parking brake cable bracket spacers, wheel well height 43."
Front diff and rear ds drop; trailer hitch electrical harness tucked up above bumper.
After 20K miles swapped 305/65/18 BFG AT for 285/75/18 Toyo AT, still on stock 18x8x60 offset TRD wheels, about 1/8" clearance to sway bar. Like the extra height but miss the width. Next time either 305/70/18 or 35x12.50/18.
Added 5th 285/75/18 Toyo AT as spare. Foam pad above spare to help with bed bounce.
Bed Bounce: Stiffer E-tires are worse than stock P-metric; biggest improvement from PRG mini-pack, slight improvement from shocks and foam pad above spare. Still a stiff ride but tolerable now.
Best things about this truck: 5.7 and transmission, interior size and comfort, very quiet at high speed.
Worst things about this truck: bed bounce, no VSC in 4wd, mileage sucks above 70.
