Anyone Install a Dump Kit?
+ Reply to Thread
Results 1 to 6 of 6
Thread: Anyone Install a Dump Kit?
  1. #1
    Rookie Ruusta is on a distinguished road. Ruusta's Avatar
    Join Date
    Feb 2008
    Location
    Branford, CT
    Posts
    12
    Liked
    0 times
    Rep Power
    0
    Default Anyone Install a Dump Kit?
    Thinking about maybe turning my 2003 Tundra into a Dump Truck, I have seen a number of kits out there..wondeirng up much it affects load capacity and wondering if there is anythign else i need to consider
    2003 Limited with lift package and 17" american Racing Wheels - Branford, CT
  2. #2
    Hall of Fame Member Mr. Creosote wants you off his porch. Mr. Creosote wants you off his porch. Mr. Creosote wants you off his porch. Mr. Creosote wants you off his porch. Mr. Creosote wants you off his porch. Mr. Creosote wants you off his porch. Mr. Creosote wants you off his porch. Mr. Creosote wants you off his porch. Mr. Creosote wants you off his porch. Mr. Creosote wants you off his porch. Mr. Creosote wants you off his porch. Mr. Creosote's Avatar
    Join Date
    Apr 2006
    Location
    Posts
    32,680
    Liked
    1517 times
    Images
    5
    Rep Power
    263671
    Default Re: Anyone Install a Dump Kit?
    How about a dump trailer?
  3. #3
    Join Date
    Feb 2008
    Location
    Branford, CT
    Posts
    12
    Liked
    0 times
    Rep Power
    0
    Thread Starter
    thought about gettng a trailer, but cost of the trailer is same or more as one of the kits, then also you have a trailer to get a plate for and store in the yard somewhere,,just one more thing to worry about...these just seem so easy
    Dump Hoists Kits Hydraulic
    but if they dont work well, ad tons of weight, kill gas mileate and decrease load capacity, then i dont thinkI will bother and will just shovel the bed out and unload by hand
  4. #4
    Veteran Member fire_mike is a splendid one to behold. fire_mike is a splendid one to behold. fire_mike is a splendid one to behold. fire_mike is a splendid one to behold. fire_mike is a splendid one to behold. fire_mike is a splendid one to behold. fire_mike is a splendid one to behold. fire_mike is a splendid one to behold. fire_mike is a splendid one to behold. fire_mike is a splendid one to behold. fire_mike is a splendid one to behold. fire_mike's Avatar
    Join Date
    Feb 2008
    Location
    Northern AZ
    Posts
    844
    Liked
    0 times
    Rep Power
    19
    I will definately decrease your load acrrying capacity. The dump components have weight to them, so adding it to your truck is just like throwing a bunch of metal into your truck bed. I think you best bet would be to get a dump trailer.
  5. #5
    Leader of Group Evil DevinSixtySeven wants you off his porch. DevinSixtySeven wants you off his porch. DevinSixtySeven wants you off his porch. DevinSixtySeven wants you off his porch. DevinSixtySeven wants you off his porch. DevinSixtySeven wants you off his porch. DevinSixtySeven wants you off his porch. DevinSixtySeven wants you off his porch. DevinSixtySeven wants you off his porch. DevinSixtySeven wants you off his porch. DevinSixtySeven wants you off his porch. DevinSixtySeven's Avatar
    Join Date
    Oct 2001
    Location
    Snowy Highlands
    Posts
    10,421
    Liked
    49 times
    Images
    22
    Rep Power
    34450
    The best I could tell ya is that the Tundra is a play truck you can work with, whereas most of the trucks (there's one small one??) they picture are work trucks you can play with.
    1st-gen Tundras use a semi-float rear axle and small leaf springs. It's inexpensive and rides comfortably. In my opinion "doing it right" would involve a lot more than a dump conversion...a full-floater rear and higher spring rate. These trucks aren't built like the old-school 1-ton dually mini trucks.
    The trailer is probably a better solution, or just loading and unloading by hand.
    -Sean
    GFX by FreedomEagle50
    Manual Hubs
    OB's cup size: 36DD
    "some people will call you stupid but its worth a try because i know i also want one more inch."--SouthernTundraSC
  6. #6
    Supporter cwit has disabled reputation cwit's Avatar
    Join Date
    May 2007
    Location
    keeseville ny
    Posts
    1,341
    Liked
    8 times
    Images
    3
    Rep Power
    912
    Most aftermarket dumps also take away your towing because the box dumps but the bumper don't.
    Charlie & Linda
Posting Permissions
  • You may not post replies
  • You may not edit your posts
