This is a discussion thread titled "Can tranny temp be read on OBDII bus?", within the Tundra forum, part of the Truck Forums category.
Old 03-31-2008, 12:10 PM
kd5byb's Avatar
Dealer : Bill Penney Toyota
2007 Toyota Tundra CrewMax 5.7L SR5 TRD
kd5byb's Photo Albums
Last Online: 07-12-2008 03:51 PM
kd5byb is on a distinguished road.
Question Can tranny temp be read on OBDII bus?
Good afternoon all,
Does anyone know if you can read any of the Tundra's transmission temperatures through the OBD-II computer interface?
I've been thinking about getting a ScanGauge II and can't find anything on their pages that says if or not you can view tranny temperature on a 2007 Tundra with the six-speed tranny...
thanks,
ben
Old 03-31-2008, 12:11 PM
Sanosuke's Avatar
Dealer : High River Toyota
2007 Toyota Tundra SR5 w/4x4
Sanosuke's Photo Albums
Last Online: Today 10:20 PM
Sanosuke is on a distinguished road.
Send a message via ICQ to Sanosuke Send a message via AIM to Sanosuke Send a message via MSN to Sanosuke Send a message via Yahoo to Sanosuke
Default Re: Can tranny temp be read on OBDII bus?
If your Tundra comes with the tow package, you get the transmission temperature gauge in the left side portion of the console.
Note photo I took below to illustrate:
Sanosuke!
Old 03-31-2008, 03:06 PM
HOGWILD's Avatar
Dealer : American Toyota
2006 Toyota Tundra,
1993 Toyota Truck,
2007 Scion tC
HOGWILD's Photo Albums
Last Online: Today 09:47 PM
HOGWILD will become famous soon enough.
Free call to ask and i thought the 07 and 08's had a different connector and OBDII was for 06 and older systems, but i have been wrong recently
ScanGaugeII - Contact Linear-Logic
Old 03-31-2008, 07:29 PM
kd5byb's Avatar
Hey guys, thanks for the read and responses. I do have the towing package and the transmission temperature gauge - but was hoping the actual temp would be on the OBD-II bus so I could correlate the gauge indication with an actual temperature. Or, better said - the gauge is nice, but is half-way 100 deg F or 200 deg F? I don't know and I would like to know...
Interestingly, the tranny ATF level check procedure seems to show that it is available. As part of the procedure, it says to use the Intelligent Tester tool and look under the DIAGNOSIS / ENHANCED OBD II / DATA LIST / A/T OIL TEMP 2 and check to see if it is between 115 to 133 def F before checking the level.
Perhaps I will contact ScanGauge and see what they've got to say...
thanks,
ben
Old 03-31-2008, 09:16 PM
djb383's Avatar
Dealer : Universal Toyota
djb383's Photo Albums
Last Online: Today 09:24 PM
djb383 is on a distinguished road.
OBDII is '96 and newer.
'07 RCSB 5.7L SR5 Silver Sky Metallic (The Silver Bullet) Yep....it's gotta HEMI
Never argue with an idiot. They will bring you down to their level and beat you with experience!
Old 03-31-2008, 09:26 PM
daless2's Avatar
Dealer : Toyota On Nicholasville
daless2's Photo Albums
Last Online: 10-06-2008 05:49 AM
daless2 will become famous soon enough.
thanks,
ben
Hi Ben,
To answer your question directly, yes the tranny temp is available via the OBDII/CAN system port under the steering column.
That said, you will need to get the ScanGuage People to recognise the HEX code for the tranny temp. The new ScanGuage units can do this, but they have to give you the proper code to input into there unit to enable it to read the code for tranny temp.
The data is available via the port, and I beleive the SG can read it.
Will they do the work required to read it and give you the needed code to enter is another question.
I'd give them a call.
Have a great night,
Frank
Old 03-31-2008, 09:29 PM
alreadydead's Photo Albums
Last Online: 09-03-2008 07:41 PM
alreadydead is on a distinguished road.
While we are on this....can it read a number for oil pressure, temp too? I wish the gauges had numbers.
Old 04-01-2008, 12:17 AM
Sanosuke's Avatar
Talking Re: Can tranny temp be read on OBDII bus?
Yes, the other temperatures can be read also through the OBDII bus.
Sanosuke!
Old 05-12-2008, 07:54 AM
JD and Beastlet's Avatar
Dealer : Bel-Air Lexus Toyota
2005 Toyota Sequoia Ltd 4x4 Arctic Frost
JD and Beastlet's Photo Albums
Last Online: 09-03-2008 10:02 AM
JD and Beastlet is on a distinguished road.
Default Not by a ScanGauge II...
I emailed Linear Logic (makers of the ScanGauge II)... here's what they have to say about it:
Hi,
I'd like to confirm that you currently do NOT have a code for transmission temperature monitoring for a 2005 Toyota Sequoia. I didn't see anything that would qualify, but since new codes are always becoming available I thought I'd check.
Thank you.
You are correct. For now we still do not have Toyota specific commands. I know we keep saying we are working on it and we don't like leading people on but unfortunately we don't know when we might fix the issue we are having with Japanese vehicles.
Regards,
Joey Snyder
Linear Logic
click the pic...
